Question about HP Officejet 5610 All-In-One InkJet Printer
Receiving a fax
Sorry, I am lost as to how to receive a fax. I can send a fax really easy..
Help.
Thanks!!
  • 1 more comment
  • Dana Venture Mar 14, 2008
    ok never mine, I got it figured out!!!
  • strawn405 Dec 13, 2008
    I don't know how to set the machine for incoming fax.
  • thatcat61 May 11, 2010
    Thank you very much NewbieAV. I had lost the manual and couldn't remember and had to get it done fast. Gracias!
The answer mode determines whether your HP All-in-One answers incoming calls or not.
If you set the HP All-in-One to answer faxes automatically, the HP All-in-One will answer all incoming calls and receive faxes. Set the Auto Answer setting to On.If you set the HP All-in-One to answer faxes manually, you must be available to respond in person to the incoming fax call or your HP All-in-One will not receive faxes. Set the Auto Answer setting to Off. For more information on receiving faxes manually, see Receive a fax manually. If you do not know which answer mode to use, see Choose the recommended answer mode for your setup.
To set the answer mode 1 Press Setup. 2 Press 4, and then press 2. This selects Basic Fax Setup and then selects Auto Answer.
3 Press right arrow to select On or Off. 4 Press OK to accept the setting.
Posted on Mar 17, 2008
SOURCE:
How do I make my workcentre printer ring when it receives a fax?
Sorry to read about your problem, I hope this helps you out.
you really dont have a ring on the machine, since the system is made to send the fax to your emails,
they dont have a ring...just hook up a phone to the machine..to have it ring..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Xerox WorkCentre 6400X multifunction (...
I have new canon pixma mx 328. how to do fax operations of sending and receiving
Hi!
It is very easy
To Send Fax:
1. Place the documents facing down in the flatbed scanner glass or insert in the ADF unit with the documents facing up.
2. Press the Fax button
3. Key in the number of the receiver then press the black or color START button.
4. Listen to the dial tone and see in the lcd display the message "transmitted" to confirm that the documnets have been sent.
Using the phone is attached to your printer (documents is already load to the printer)
1. Call the number of the receiver.
2. Ask for a fax tone.
3. Once you heard the fax tone, press the Black or Color Start button
To Receive Fax (Set up first the number of calls before automatic giving fax tone to caller)
1. When someone is trying to send a fax to you, don't answer the ring on the phone, let the printer give the fax tone.
To receive the fax on the printer with the user's help.
1. When someone is calling, just press the Black or Color Start button.
To receive fax when you answer a phone
1. While the phone is lift up, press the Black or Color Start button to receive the fax.
Hope that information will guide you.
You can thank me by just rating this help.
Thank you for using Fixya.
Dec 14, 2010 | Canon PIXMA MX300 All-in-One Printer
Trouble receiving faxes from brother personal plain paper fax 575
Press START while fax is ringing.
Try unplugging the power cord for 10 seconds.
If you do pull your hair out, please send it to me, I need more hair.
Dec 17, 2008 | Brother Office Equipment & Supplies
How to send fax from computer ?
Please follw the below steps:
To Fax From Your Word Processing Program1. Some software products, such as Microsoft Word, allow you to fax a document without opening your fax software.
2. Open the document that you want to fax.
3. From the File menu, select Print. The Print window opens.
4. Instead of printing to your default printer, look for an option that allows you to Print to Fax. Select this option and click Print.
5. You will be asked to provide the recipient's fax number and other assorted information as with a fax program.
6. The fax message compiles, the modem dials. If the connection is made with the other modem, the fax will be sent.
To Send a Fax From Fax Software1. Prepare the document that you want to fax.
2. Prepare a fax cover sheet, if desired.
3. Open your fax software - such as Microsoft Fax or Microsoft Exchangemag-glass_10x10.gif.
4. Look for an icon or menu command that allows you to send a fax - such as Send New and Send Fax. Click on that item.
5. Follow instructions for entering the fax number of the recipient and any other requested information. Be sure to include area codes and long-distance information if needed.
6. Indicate whether you wish to send a cover sheet.
7. When asked to attach the file, follow instructions to attach the file that you want to fax.
8. When ready, click Send. The fax will begin to compile the information and, when ready, will dial the remote fax machine.
9. When the connection is made, the fax will be sent.
Thank you.....
Dec 08, 2008 | Office Equipment & Supplies
Fax modem
The best solution is not to need a fax/modem. Send and receive faxes via internet.
This program was PC Magazines editors Choice:
http://home.efax.com/s/r/efax-brand9?VID=33675&gclid=CL_th9ybypYCFQOIFQod1iRdyg
This way you don't need a phone line/ tying up your phone line etc..
Oct 28, 2008 | D-Link DFM 562E (dfm-562e) Modem
Hp-laser jet 3055
hi, just try to reset the memory the of fax. i think that's the cause that's you cant send and recieved fax..i hope it would help you...
Oct 20, 2008 | HP LaserJet 3055 All-In-One Printer
Can't receive fax on Lexmark X6170
not really...some fax machines are not happy with receiving from a computer or printer(read that digital). may take years for it to work itself out.
http://tinyurl.com/6qcpgy
Aug 18, 2008 | Lexmark X6170 All-In-One InkJet Printer
We cannot receive or send faxes
hello dmhertz
anything here that may help Canon .
riz.
May 12, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Our new HP Oficejet Pro L7780 can send faxes but can't receive
First things first, i really want to know how things being setup in your end. Let say for example, from the walljack what is the device connected to it. Or if your using one line for both incoming calls and faxes. Or if your using a DSL also for that same phone number for faxing/incoming calls.
Those are just severa factors that affect your problems. Meanwhile, i cant give you a solution on your issue since i still dont have a clear picture on are the devices connected with each other. ALso, its really advisable that you need to use the telephone cord that came out with the box.
Thank you so much. I remain.
adonscott
Apr 23, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Panafax uf-550
Hi! The battery pack is easy to find; Remove the small cover in the middle of the back of the fax where your line in is plugged in. When the cover is removed, you should se a print-board, and on the lower part there, you see a light green battery pack. Don't know if it's easy to find replacement... I'm don't know much about ussage of the fax, so not much help there...
Sep 14, 2007 | Panasonic Panafax UF-550 Plain Paper Laser...
HP Officejet 5610 All-In-One InkJet Printer Logo
584 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
