Our topload Kenmore Elite washer will not fill with water. It starts to agitate right away upon setting the dial
    President:
  • Washing Mach... Master
  • 2,651 Answers
Try switch in the load size?? sounds like your having a problem with the pressure/ water level switch. it must think its full of water already. you would need to pop open the control panel. either 2 screws located on back of console (while looking over the top of machine and straight down you should see 2 Phillips head screws in both corner of top screwing straight down. if not the 2 front end caps will pop of control panel to reveal the screws. undo the screws and tip the console back( its hinged), the far left is the pressure switch, it has a clear plastic tubing leading to it. remove the tube and try blowing through it(clear the line) try also blowing back into the switch itself you should hear it click. if after that it still doesnt work id say the switch is no good
Posted on Mar 14, 2008
SOURCE:
I have a kenmore 70 series heavy duty plus. my model number is 82372110. my washer will fill with water but when its time for it to start to agitate it drains the water then fills it and drains it the
Sounds like the main dial is gone on the top control panel. How a washer works, is the water level switch ( the dial that allows you to select the amount of water you want to wash your clothes in) sends a signal to the main dial, when the water level is full to turn on the agitate and the water to shut off. But it is emptying the water instead, so the main dial is skippiing the agitate cycle. If you take the back panel off the top control panel, you will see a mechanism behind the main dial. That is probably what needs to be changed. It costs anywhere from $120 to $180 for the part. You may want to invest in a new one instead but replacing this part should fix your problem as well. It is about a 2-3 out of 5 for someone without experience to fix. Not hard. Have you noticed any whining or abnormal mild grinding coming from the dial itself? This may be a clear indicator that the dial is on its way out.
Jul 18, 2012 | Kenmore 22422 Top Load Washer
This Kenmore Elite Top Load Washing machine has
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This gets a little tricky.
It sounds as if, based upon the weight in the tub being reduced, the noise gets less. Something is pressing on something else due to the weight.
If you look at the gearcase parts section of the Sears site, you'll see parts called the agitate gear and agitate cam.
If the agitate cam wears (it's two plastic pieces) when the transmission moves to the spin cycle, the cam is supposed to lift the gear above it.
If it doesn't lift the gear high enough, you'll hear loud gear noise. This may lessen as the washer pumps water out and there is less weight on the spring.
We had the same problem with a washer and found that by replacing the cams, the noise went away.
Please see GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
I had the same problem with gear grinding and this solved it.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Sep 26, 2009 | Kenmore Washing Machines
Washer does not spin and drain water. (Kenmore Elite Heavy Duty)
it seems to me ur washer transmission is going out or already there
Nov 26, 2008 | Kenmore 24032\24036 Top Load Washer
Agitator not working 90 series model # 11026912691
Hello aksward,
Welcome to Fixya.
Here are some suggestions for any Kenmore washers
Let me know how it goes. I'm still thinking and searching my repair manuals!
Huuum
Please remember to leave a rating!
KENMORE ELITE TOP LOAD
Washer stops, won't fill, rinse or agitate
• Check the following:
Is the power cord plugged into a grounded 3 prong outlet?
Is the indicator on the Cycle Control knob properly lined up
with a cycle? Turn the Cycle Control knob to the right slightly
and pull to start.
Are the water inlet valve screens clogged?
Are both the hot and cold water faucets turned on?
Is the water inlet hose kinked?
• Does the water level seem too low, or does the washer
appear to not fill completely? The top of the agitator is
much higher than the highest water level. This is normal and
necessary for clothes to move freely.
• Has a fuse blown or is the circuit breaker open? If problem
continues, call an electrician.
• Are you using an extension cord? Do not use an extension
cord.
• Is the washer in a normal pause in the cycle? The washer
pauses for about 2 minutes during certain cycles. Allow the
cycle to continue. Some cycles feature periods of agitation
and soak.
• Is the washer overloaded? Wash smaller loads.
• Is the lid open? The lid must be closed during operation.
Washer will not agitate or spin with the lid open.
Oct 06, 2008 | Kenmore 22422 Top Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
