I have a foxconn C51XEM2AA that suddenly failed to boot up ,with no previous symptoms. About 3 days before this non startup my wife in haste got her foot caught in the mouse wire and pulled the computer off the desk.The unit was fine for 3 days.I shut it down and whe i tried to fire it up again,nothing. No video screen,the HD.led comed on briefly then nothing.There is a debugging L.E.D on the Motherboard that has what looks to be a dA displayed. This is not one of the options in the manual.Any ideas? Thanks much.. Keith Kcrews@comcast.net
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 171 Answers
Remove all connectors and fix the connectors expect mouse and keyboard ans start the system if dispaly comes connect the keyboard and check the system . if not comes again post
Posted on Mar 14, 2008
    Problem Solver:
  • 17 Answers
It looks like something is loose .
open it up , take off everything , connect back everything .
ensure that everything is fully inserted and seated.
then turn on.
if nothing is damaged , it should come on.
if it comes on and shows no operating system , you need to reformat and reinstall.
good luck
Mainboard error for install to win7 finalliting install
Hello the mainboards homepage is here:
http://www.foxconnchannel.com/ProductDetail.aspx?T=Motherboard&U=en-us0000576
From here you can download a manual.
You need at least 1gb of ram to install windows
And min.1,6 ghz cpu.
Is the windows disk an original or a copy ???
If a copy it may have be burned too fast.
Burn it not more than 4x or it will skip some files
and not be able to finalise the installation
I could also be the dvd drive.
Try also to enter the bios and set it back to factory settings
remember to set up the boot option again.
You also need a sata harddrive.
An IDE drive is too slow.
First boot device dvd
And second the harddrive
Good luck
Oct 27, 2012 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Tip
Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
<b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
on Mar 08, 2011 | Computers & Internet
My new video card Sapphire HD5770 is installed and now my pc will not post or boot, what can i do?
Make sure you have your card installed correctly in your PCIe slot, it should hook in. You also have to hook up power supply. This card requires minimum 450 watt power supply and 600 watt power supply if using crossfire and dual mode. If your system meets these requirements, and you have card seated properly and hooked to power supply. You may have to enter your bios and dedicate the PCIe slot. I'm guessing the system will boot without card.
Apr 04, 2011 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Alienware c51xem2aa out the box wont turn on
If there was a spark and it smelled, something probably burned through. If I were you, I'd send it back to Alienware and request a new one. Even if you could fix this now, the risk of it breaking again in the future is much bigger. I hope you'll get your new PC fast, Yannick.
Jun 07, 2009 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Repeated boot
I supposed you are using windows xp, put the Win XP cd in your cd drive and start your computer
boot on the cd drive, wait until the winxp finishes its copying
When asked if your want to install winxp or repair [R] choose repair by pressing R
wait till the command line and type: chkdsk /r
wiat until it finishes, it may take about 20 to 30 minutes..
reboot your pc
Oct 25, 2008 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Will not boot
try unseating the memory then plugging it back in.
Robert ...
If it was that humid i'd even suggest leaving it in a dry place for a few days... but reseat the memory either way.
Sep 17, 2008 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Startup fault
Software Error Or Corrupted windows File files
Jul 15, 2008 | Foxconn (945G7MA-8KS2) Motherboard
No boot up or bios or image after installing the new mother board, Mr Bogdan
Brand new board? Unlikely to have a problem. Are you sure you connected the small 4 pin power supply connector to the motherboard as well? (besides the main supply connector)
If you have any IDE drives make sure you have not reversed the orientation of the cable.
Regards,
Anand
Dec 17, 2007 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Nokia 3230 start-up failed
Hi, Format the Mobile set, using 4 Keys combination : Press(1) *, (2)Dial Key, (3) 3 & hold it & press (4) power on switch.] bye sr99mobiles@yahoo.co.in
Sep 11, 2007 | Nokia 3230 Cellular Phone
Computers & Internet Logo
74 people viewed this question
Alun Cox
David Payne
David Payne
