Question about Whirlpool Duet GHW9150P Front Load Washer
"SUDS" mark on my washer
"SUDS" mark on my washer then it shows F02- I called spoke w/customer services the lady suggested to buy affresh tablets to help w/ build up or residue. I have used regular laudry soap 96 loads to be exact. I'm thinking its electric now. No kinks,holes,nor blockage
    President:
  • Whirlpool Master
  • 2,651 Answers
You NEED to use HE (high efficency )detergent. with this machine. you say you used regular soap.affresh is not a detegrent but a cleaning product for the washer not for your clothes but for the washer it self. theese pumps are real senstive to excessive suds generated by "regular" detergent. HE is low sudsing designed especially for the front loading machines
Posted on Mar 14, 2008
How do we get debris out of the bottom of the tub
Hi Ms. McCord. To clean the washer, we would recommend running a cycle on the hottest temperature possible, and adding a cup of bleach to the bleach compartment. You can also use Affresh tablets to clean the washer. Hereis a link to the Affresh tablets for the washer: http://bit.ly/Nd4OeX . I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
Jun 23, 2012 | Maytag Bravos MTW6600T Top Load Washer
About one minute after starting machine (Whirlpool Duet WFW9600T01) the machine flashes "SUDS" for a couple minute or so, then the machine locks up with the F35 code. The only way to open the...
this is a suds lock and a very nightmare of a call....... are you using high effeciency soap and do you ever run a clean cycle ....... i prefer an affresh cleaning tablet once a month...... first things first need to drain all water out of washer threw drain hose connected to drain pump .... then check for any float obstructions at bottom of outer tub to drain pump large 4 inch ruber hose at bottom of tub with a plastic ball in it make sure there isnt any lint causing float ball not to seal in pump vacum... then reinstall and reconnect hoses then check pump filter sump trap for debris and reinstalll next open washer and install an affresh cleaning tablet and select hotest water cycle or clean cycle if washer is equipped with this feature and close door and let washer run ...m if code comes back you make have to repeat draining and pump steps a COUPLE OF TIMES TO REMOVE EXCESS SOAP BUILDUP..,. CAUSIN SUDS ERROR LOCK CODE.....
Jan 24, 2011 | Washing Machines
How to get rid of the stale smell from the atf8000 front loader washing machine
first things first we need to purchase a cleaning tablet from local grocery store called affresh tablets in your laundry detergent aisle ,
then clean out filter sump assymbly in bottom corner of washer som washers have an axcess panel in the bottom righ or left hand corber uncrew filter cap and drain in to bucket or a shop vac .
clean debris out of filter and reinstall the filter screw cap in tightly ..
check your console for a clean cycle option in your wash cycles an select put one affresh tablet inside of washer drum and run cycle..
if you dont have a clean cycle thats ok select your hotest water wash cycle or sanitary cycle put one affresh tablet inside washer drum and run cycle ...
after cycle completes always leave waher door cracked open when washer is not in use ,,, reccomend running an affresh cycle once every month or if u notice stagnant water smell the more often you wash with hot water the less chances of smell
How to fix suds lock on Kenmore
The Sd code on most Kenmore Elite HE washers indicates a suds lock (usually caused by excessive suds do to overuse of detergent). Check for the presence of excessive suds in the washer. If you see a lot of foam, the code is likely caused by this problem. You will likely be able to drain the washer and spin out the clothes once the suds dissipate. Run an empty cycle with 1 cup of liquid chlorine bleach through the washer to help rinse out suds residue. If you see foam emerging during the empty cycle, you may need to repeat this process. You can also use Washer Magic or AFFRESH to help clean suds residue out of the washer. These products are available at your local Sears store or the grocery store. Make sure that you are using HE (High Efficiency) detergent in the appropriate quantity. You may need as little as a tablespoon of detergent in a high efficiency washer due to the low water level. You may need even less for a while since the clothes will likely have detergent still dissolved in the fibers that will emerge during subsequent wash cycles.
There are many different models of Kenmore Elite HE washers. If you do not see any apparent problem with excessive suds or need more help, resubmit your question with additional details and the full model number of your Kenmore Elite HE washer.
Jan 11, 2011 | Kenmore Washing Machines
What does the clean washer reminder light mean and what do I do to clean the machine? This washer was new in September, 09 and the light has been on for several weeks.
This is just a factory setting that reminds you to clean the washer to avoid that musty smell. You can buy tablets called Affresh or other similar cleaners for washing machines. They sell these items at Target, Walmart, Lowes and Home Depot. You can also substitue 1 Cup of Bleach in the washer. Then once you add whatever solution you have decided to clean it with you simply select the wash cycle on the machine called "Clean Washer with Affresh" Once you have done this the light should go out. You can also reset the indicator light by pushing the button next to the light that says Reset clean washer reminder. Hope this helps!! :)
Nov 18, 2009 | Maytag Bravos MTW6600T Top Load Washer
Clean washer reminder---what do i do when this indicator lights?
This is just a factory setting that reminds you to clean the washer to avoid that musty smell. You can buy tablets called Affresh or other similar cleaners for washing machines. They sell these items at Target, Walmart, Lowes and Home Depot. You can also substitue 1 Cup of Bleach in the washer. Then once you add whatever solution you have decided to clean it with you simply select the wash cycle on the machine called "Clean Washer with Affresh" Once you have done this the light should go out. And if you were getting the Sd code it should also be gone. You can also reset this by pushing the button next to the light that says Reset clean washer reminder. Hope this helps!! :)
Aug 08, 2009 | Maytag Washing Machines
Smell in Washer
The best suggestion I can givefor this is to use a tablet called Affresh.
http://www.affresh.com/
This is a great cleaner for all HE washers. I hope this helps.
Good Luck!
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Jan 18, 2009 | Kenmore 44102 Front Load Washer
F02 Error on Front Load Kenmore HE3
F 02 Is your key pad user interface that has failed. I would call back and get some free service from a different technician.
Oct 23, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet washer ghw9100lw1
That is not what it is. I would recommend either going to the website affresh.com or best buy/home depot carry this product
Its called Affresh, comes in a green package 3 tablets in each package. Retails at 6.99$ (not sure about in store prices)
Front loads can not drain all water and residue because of gravity. This builds up and causes molding/odor issues in some units
Affresh was solely created to resolve this and replace the Bleach Clean Procedure.
Easy to use, put tablet directly in tub, no clothes or detergent, hot water, normal cycle selection and run it. In your case the idea is to run 3 consecutive washes (1 table per wash) then once monthly after that(1 wash same directions but only the first time you do 3 washes). This will resolve the issues, i use it and buy it for my family and friends.
May 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
117 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
