Question about Polaroid 15'' HDTV Monitor FLM-1511
Purple screen vertical lines picture comes & goes
Picuter comes and goes to purple screen with vertical lines
  • 1 more comment
  • sisyphus Mar 24, 2008
    Using the monitor as a TV. Has the same issue.Picture works for a while then purple lines go across the screen and there is no picture. You can still hear the audio, but there is no picture.
  • disporshce Aug 09, 2008
    Sisyphus,
    I have a Polaroid FLM-1511. I am having the exact same problem. It happened once before, but then it cleared up. But now it is doing it again. I also am not using it as a monitor at the moment, but as a TV. The problem also persists when the input is switched to the video setting. I have not tried hooking it up to my PC and I doubt it is a lamp problem as asked by tantong. Did you try resoldering the "caps"? Did you trying anything to fix it?
  • IndyUser Dec 18, 2008
    Repeating vertical purple lines about 1# wide. Replaced monitor with a new one but the same problem occurs occassionally. If I turn off the PC the lines usually go away for days.
    Novelist:
  • 138 Answers
I would suggest that You should check your monitor with another PC. If it still has the same problem, there will be something wrong with your monitor.
Using these following steps to examine your monitor. After you turned PC on and monitor went purple, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 14, 2008
SOURCE:
Lg tv with vertical lines on half the screen. discoloration with reds and purples. comes and goes
The TCON board or the LCD panle is faulty. Can confirm By replacing the TCON board.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Feb 02, 2017 | LG Televison & Video
White and purple flickering vertical lines. No image or sound.
I Hope this helps!
Sony has extended the Warranty for people experiencing picture anomalies due to LCD Panel failure through October 31, 2012.
See here:
http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP.
(any less hurts our averages)
Thank and Good Luck!
Jan 04, 2010 | Sony KDL-46XBR4 46 in. LCD Television
Purple and green vertical lines on pictures, fujifilm finepix z
Check to see if the Fuji website has any downloads or updates for your camera.
Aug 12, 2009 | Agfa FUJIFILM FINEPIX Z33WP Digital Camera
Desktop doesn't come up. i get vertical lines instead
try removing the bios battery for couple of mins and then replacing it :)
Apr 23, 2009 | Computers & Internet
Vertical lines on canon a95
Go to www.digitalcamrepair.com then click on the self diagnosis page. for your answer to your question.
May 28, 2008 | Canon PowerShot SD1000 Digital Camera
Coloured lines on picture screen
I have the same issue, Although My camera is a samsung N46, It was working perfectly the night before, then my friend switched it on and it came up with a black backround and pink + purple vertical lines going through it.
Nov 12, 2007 | Olympus FE-120 Digital Camera
Green and purple vertical stripes on our TV screen
The cause is one or more shorted transistors either on CRT board or on main or both. The colors are red,blue and green, you have a transistor for each and a bias trans. check each there are 6 in all.
Sep 14, 2007 | Televison & Video
Vertical lines and purple artifacts when the camera is aimed at bright subjects
Current LCD display technology can reproduce about 300 different levels of brightness. Brightly lit scenes or light sources may exceed this brightness range, causing a temporary disruption (artifacts) in the live display. Artifacts are part of the display, but they are not part of your recorded image. If you take a picture while you see artifacts on the screen and then display the picture on the LCD, you will no longer see the artifacts.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Polaroid 15'' HDTV Monitor FLM-1511 Logo
194 people viewed this question
Top Polaroid Computers & Internet Experts
Tom Chichester
Steve P
Steve P
Joseph Wright
Are you a Polaroid Computer and Internet Expert? Answer questions, earn points and help others
