Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Drive options not showing up
Suggest me, How to correct the registry editor to show the correct drive options
    Genius:
  • 1,142 Answers
I CAN`T BURN DVD WITH MY NERO BECAUSE IT TELLS ME THAT:ERROR TO HL-DT-ST DVDRAMGSA T50N ATA Devise.What can i do?
Hi marymichael2,
I see that you are having issues burning using Nero.
First check if the setting of Nero is correct for the DVD drive open Nero then go to Extras click on Get system info for Nero to detect the system devices and windows info for proper compatibility and Burning Detection of the DVD drive.
If the error states that there is something wrong with your DVD driver then you can check to see if resetting your DVD drive can fix the issue you reset you DVD drive by going to the registry editor.
regardless of what OS you have the steps are the same.
  • Click on Start then Click all programs look for Accessories, then look for CMD or Command Prompt then click it to open the registry editor Tool.
  • Once you have the Registry Editor on the left hand side window look for HKEY LOCAL MACHINE click on the arrow on the left side of the Folder to show the submenu,
  • Then click on the arrow on the left of System
  • Then click on the arrow of CurrentControlSet
  • Then click on the arrow of Control
  • Then click on the arrow of Class
  • Now under Class will be a list of devices identified with Numeric ID's
  • Look for this first numbers {4D36E965 then click on it
  • On the right oane window it will show you info about your DVD drive, just look for UpperFilters and LowerFilters right click and delete both then close the registry editor
  • I suggest that you restart your computer and then try burning again
If the problem still occurs then most probably you can try reinstalling Nero, also make sure that there are no other burning software on your Computer that may cause confusion with the detection of the DVD drive.
Reinstalling windows can be done to fix the issue as well, but is the last option if all else fails.
I hope that this helps.
Thank you for choosing Fixya,
mvincentc
Jun 07, 2011 | Computers & Internet
Tip
Enable the Registry Editor, Task Manager and Folder Options Disabled by Viru
Virus attack is common these days and we often come across the problems like Disabled Folder Options or like Task Manager and Regedit disabled by Administrator. These problems are nothing but virus activities. The virus has infected our system and stopping us from accessing these options.
Pressing keys Ctrl+Alt+Del opens up a dialog saying that “Task Manager has been disabled by your Administrator” whereas you are the Administrator yourself. It becomes very annoying when you think that you can fix this problem by going into the Registry Editor but it doesn’t show up. Even the Folder Options gets disabled.
This problem is generally caused by a virus named “Brontok” but don’t worry just use RRT (Remove Restrictions Tool) that can easily solve this problem. RRT is free and can successfully enable:
1. Folder Options
2. Regedit (Registry Editor)
3. Task Manager
4. Show Hidden Files option
The tool will come more useful if you use it in Safe Mode.
Download RRT
on Nov 17, 2008 | Microsoft Windows XP Professional With...
Optiarc dvd rw driver shows code 19 error .i have tryed to reinstall ,but no use.
The below step will surely resolve the issue..
CD/DVD drive in device manager and the CD/DVD properties in device manager shows error code 10 , 19 , 31 , 32 , 39 or 41, please use the following steps:
This issue occurs due to an incorrect registry entry, which might be created due to installation of an incompatible CD/DVD burning program. We will remove the registry entry and re-install the CD/DVD drive and the issue will be fixed.
1. Click on Start and type regedit in the search box and hit enter. It will open Registry Editor window.
2. It will open registry editor.
3. Click on File and Export, it will open a new window.
4. Select Desktop from left pane in the new window and put file name as regbackup and click on Save.
5. It will create a back up of the registry on desktop.
In case something goes wrong during modifying registry, this registry backup can be used to restore to original registry.
6. Now in registry editor click on triangle symbol next to the following items in the left pane:
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
7. Locate 4D36E965-E325-11CE-BFC1-08002BE10318 below class and click on it. Make sure you have selected the correct entry as all the entries looks almost similar.
8. Look at right pane and check if you see UpperFilter and LowerFilters entries.
9. Please right click on UpperFilter and LowerFilters and select delete.
10. make sure there are no other UpperFilter and LowerFilters entry in that window.
11. Close registry editor.
12. Now please click on Start and type device manager in the search box and hit enter.
13. It will open Device manager window.
14. Click on + sign near CD/DVD entry and it will show the name of the CD/DVD drive with a yellow mark near it.
15. Right click on it and select uninstall.
16. It will remove the CD/DVD entry from device manager.
17. In Device manager, click on Action > Scan for hardware changes to re-install CD/DVD drive.
18. Now you should see the CD/DVD drive entry.
19. Do you see any yellow mark near it now?
20. Please click on Start > Computer and check if CD/DVD drive is listed.
21. Please insert a CD or DVD and check if the computer reads it.
May 08, 2010 | Computers & Internet
My comuter does not see my cd-dvd I need to reinstall drivers
First thing first is to focus. All you need to do is to enter "regedit" after clicking Start >> RUN. Under REGISTRY EDITOR screen click on "HKEY_LOCAL_MACHINE > SYSTEM > CurrentControlSet > Control > Class >{4D36E965-E325-``CE-BFC1-08002BE10318}. Please highlight "{4D36E965-E325-``CE-BFC1-08002BE10318}" and then on the right pane of the window/Registry Editor, you can see either Lowerfilters and Upperfilters. From then all you need to do is to highlight and then make a "RIGHT CLICK" from the mouse and select for "DELETE" option. After deleting either Lowerfilters and Upperfilters just exit out from Registry Editor screen and shutdown your laptop. Then after 1 minute have to turn it back on then retry checking if it ables to shows up your OPTICAL DRIVE or not. Thank you.
Apr 10, 2010 | Acer Aspire 5100 Notebook
Error code 39, cannot boot up the dvd drive
To resolve the issue i suggest perform the steps given below 1. Go to START -------> RUN command and type (devmgmt.msc ) 2. After that device manager window pops up on the screen, all you need to do is uninstall CD/DVD drive by clicking right click and press on Uninstall option 3. After uninstalling CD/DVD drive from the devicemanager , restart the notebook, The drivers which you had uninstalled will automatically retrive by windows , This should resolve the issue. Have a grat day.
Sep 16, 2009 | HP Pavilion dv6000z Notebook
Cd drive doesnt read anything
If the drive is showing an error (or is missing) in device manager, do the following:
Start Registry Editor (Start, Run and type in regedit then click O.K)
Locate the UpperFilters value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the Edit menu, click Delete, and then click OK.
Locate the LowerFilters value under the same key in the registry:
Quit Registry Editor.
Hope this helps
May 02, 2009 | Dell Inspiron 1525 Notebook
CD DVD Rom not found
If your drive is showing in the BIOS and you are able to boot from it using a bootable disc then the following should resolve the problem:
Always backup your registry before editing and use care to find exact key!
Start Registry Editor (Start, Run and type in regedit then click)
Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Reboot.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
Dec 30, 2008 | Acer Aspire 5100 Notebook
Where can i get registry editor on my laptop
Just push the start menu button, hit run and type regedit there and push enter, registry editor will show up in 2 secs.
Nov 23, 2008 | Acer Aspire 3000 Notebook
Pen drive not showing in My Computer
hello sr my pendrive wn i connect to my pc and it is not showing and option in my pc so is it any damage at pendrive and how can my pendrive work
May 19, 2008 | Electronics - Others
Pioneer dvd-rw dvr-k17 problem
Hi
Right click on the driver and then click Properties.
On the properties screen, check the device status and then go to the Details tab at the top.
If the details screen shows any errors or problems abt anything other than drivers, then follow the steps below to delete the upper and lower filters from registry.
Step 1: Back up the registry
  1. Click Start and and in the Start Search box type in REGEDIT and hit Enter .
  2. From the Registry Editor window, perform one of the following depending on the operating system:
Click File and then click Export File.
  1. The Export Registry File window will be displayed. Save In: should be set to the Desktop . Next to File Name: provide an easily identifiable filename like “Full Registry Backup”. In the Export Range portion of the window, make sure the radio button next to All is selected. Click Save to save an exported copy of the registry to the desktop.
  2. Step 2: Remove upper and lower filters
The steps below describe how to remove the drivers associated with the drives disappearing. After removing the filter driver keys, the CD recording software will be have to be re-installed.
  1. With a copy of the registry exported, click the plus signs [+] in front of the follow keys in the order they are listed: HKEY_LOCAL_MACHINE , SYSTEM , and then ControlSet . In some cases, multiple ControlSets may be listed similar to the following:
    • HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001 HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002
    or
    • HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001 HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002
  2. Click the plus sign [+] in front of either CurrentControlSet or the lowest numbered ControlSet. For example, in the second list above, ControlSet001 would be the correct listing.
  3. Click the plus sign [+] in front of Control.
  4. Click the plus sign [+] in front of Control.
  5. Click the plus sign [+] in front of Class.
  6. Locate the following key and highlight it in the left window of the Registry Editor (The numbers can be very similar, be careful select the correct key. Another method to find the correct key is to highlight Class, then cut and paste the key below into a Find window accessed from Edit and Find in the Registry Editor.)
    • {4D36E965-E325-11CE-BFC1-08002BE10318}
  7. With the key highlighted, the right pane will have multiple keys listed including LowerFilters and UpperFilters. Highlight LowerFilters and press the Delete (Del) on the keyboard. A confirmation dialog box will be displayed asking if the value should be deleted. Click Yes to delete the value.
  8. Repeat the process for the UpperFilters by highlighting UpperFilters, pressing the Delete (Del) key on the keyboard and again confirming the value should be deleted by clicking Yes.
  9. Exit the Registry Editor
  10. Restart the computer. The optical drives should then be recognized and available for use.
Feb 25, 2008 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
