Hi, you see when a Camera's & the like, is/are left without power going through it, it actually does it harm, things in storage should be powered up at least a few times a month, otherwise the capacitors will loose their "Form" and will not work correctly, and if left too long the unit simply becomes unservicable, also the moisture in the atmosphere, gets absorbed by osmosis, into "Other" compnentry, and this too causes failures, not to mention, any other sort of corrosion, or perhaps flat cells in a unit, inductors etc. So as said, this makes a unit more or less unrepairable. It still maybe worth taking it to a JVC authorized repairer, and asking for a "Quote" for repair, this way you can make an informed decision, as to repair or replace.
