Question about Kitchen Ranges
Oven not heating properly.
I see the igniter go on but I don't hear the gas flow. The 200 Degree is just a guess.
  • josey78681 Mar 14, 2008
    Igniter seems to be working, but the gas is not coming on. I tried using the oven cleaning feature, but after 30 minutes the oven still had not heated up.
  • carlos99 Dec 31, 2008
    intermittent problem with oven not heating- seems that main burner will not ignite- oven becomes warm, but not hot when it's turned on. Possible oven ignitor replacement the solution?
    Thanks!!
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
You replaced hte oven ignitor already correct?? although its glowing might not be glowing correctly, adn if you did replace you ordered for this model???was the igintor hte same ?
Posted on Mar 14, 2008
SOURCE:
GE XL 44 oven will not come up to temperature. Oven lights but will not heat beyond 250 degrees.
The most probable reason the oven isnt heating very well is because of a weak igniter,since that igniter is weak its having a hard time fully opening the gas valve so the flame is very small and thusly not producing much heat,by replacing the igniter the gas will flow properly and heat to a high tempature.
GENE
Oct 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
My Kenmore propane oven is taking long then time needed to bake something
A very common problem when gas(both propane and natural) oven takes longer to heat properly is going to be a weak igniter . Since its weak its not fully opening the gas valve and not enough gas is flowing to produce the proper flame size/heat. By replacing the oven igniter it will heat as its supposed to .
GENE
Sep 24, 2011 | Kenmore Ovens
Ignitor glows but burner doen't ignite. Don't hear any gas flow or smell any gas.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 26, 2011 | Ovens
My amana oven wont heat properly, long cook times,
Theres probably an adjustable gas valve on it. You should also know the igniter and gas valve being wired in series makes it sensitive to current flow so the igniter could be the problem. Low current flow would not allow the valve to fully open.
Jun 08, 2010 | Kitchen Ranges
Oven takes too long to heat up on Jenn Air gas oven
you need to look at the oven igniter to see what color it is. if it is orange it needs to be replaced. it should glow white hot in order to ignite. hope this helps.
Oct 13, 2009 | KitchenAid KGST307 Gas Kitchen Range
Oven won't heat
hi. thanks for the question. i would replace the igniter, on the oven burner.that will solve the problem. thanks the appliance doc
Sep 30, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven would not light. I replaced the igniter and now it lights but it will not heat past 200 degrees. Is this the thermostat acting up or is this connected to the gas supply? Any suggestions??? My oven...
when you say now it lights. is just the ignitor lighting?or can you hear the gas flowing??? can you feel it heating at all?? should start at 100 degrees and climb up from there. no reason for it not to heat past 200 (unless set to Celsius which default setting of 350 =190degress) therefore will not heat past 200. and wont let you try to heat to 425 , that would be off the charts of Celsius conversion. sensor problem would eitherno t let stove come on or wouldnt stop from heating eitherway a code would come up in the display
Mar 14, 2008 | Kitchen Ranges
Gas oven not heating
waka,
I'm guessing that there is an issue of some kind with flow of heat inside the oven. Gas ovens use the hot air/gas exhaust to heat up the oven. Flames mean heat. The flames should be about half an inch long or so. If not, there may be an issue, but I don't think that is it.
Have you lined the oven with foil? It is possible that vents from the boiler section are closed up? That will prevent heat from reaching the oven.
Dec 03, 2007 | Whirlpool SF367 Gas Kitchen Range
New gas valve, new gas smell
CG, unfortunately you replaced the wrong part. The problem with your oven is the igniter. The igniter is wired in series with a safety valve. The safety valve monitors the amount of electrical current flowing through the igniter when you ask it to "bake".  When the igniter gets "weak" it won't allow current to flow through it properly, this will keep the oven from heating. It will also cause your symptoms as well...
Here's the scenario; Say your safety valve is "looking" for 2.5 amps of electricity flowing through it before it'll open up and allow gas to the manifold. Your igniter is designed to allow 2.8-3.2 amps to flow in good operating condition, but your igniter has become "weak"... it's now allowing 2.48-2.51 amps. The safety valve is sensing this and opening and closing rapidly, allowing gas to flow through it (fluttering). BUT! the igniter is not hot enough to ignite the gas and/or there is not enough gas to ignite do to the fluttering effect of the valve. Sometimes it'll light sometimes it won't.
Your igniter is the cause and needs to be replaced.
Before you begin the repair, you should have the new part on hand. The part number is WB2X9154 and can be purchased at your local appliance parts retailer for about $50.00. Here's one online for $65.00.
First, UNPLUG YOUR OVEN!
To replace it... Remove the racks and lower panel (oven floor). This will expose the burner manifold where the igniter is mounted.  (It's the round thing on the manifold near the back... it has 2 wires going into it.) You'll need a 1/4" socket or nut driver to remove it.
(*TIP---> before removing the screws from the igniter, put a few drops of liquid dish soap on the threads to lubricate them. If you do this, you will not strip the threads of the screws and it will ease their removal.)
The new igniter kit will have two ceramic wire nuts in it. Cut the two wires off of the old igniter and strip them back about 3/8". Then connect the wires of your new one to the wires in the oven using the ceramic wire nuts provided. Then mount the new igniter and rebuild the oven.
(*TIP---> The new igniter is very fragile! [that's why it came wrapped tightly in bubble wrap] Handle it gently!)
There ya go! Total job time? ~45 minutes.
Oct 09, 2007 | GE JGRP17 Gas Single Oven
Kitchen Ranges Logo
80 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
