Question about HP PSC 1315 All-In-One InkJet Printer
HP F370 PSC
Need solution to my printer some mechanical problem..Print heads slams on both sides of printer creating terrrible noise then paper and E error indicator ligths up.
  • noppix Mar 14, 2008
    First of all thank you for the response regarding to my problem.. I try it but for no avail same problem occur. is there some other advice regarding the cause of printerhead mis behaviour.
  • noppix Mar 15, 2008
    Again thanks for the response and advice maybe the problem originated not only on the sensor but also for the mainboard because upon powering up the unit the problem immediately occur and i noticed also opening the printer head access door its no response and stay to the position where it is usually park. Regarding about printer driver original cd that bundled to the printer was used and besides scanning trough computer was done with no errors, that problem lies only on printing. Again thank you and more power.
    President:
  • 2,072 Answers
One possibility is. look toward the back of the printer, there is a strip of clear plastic, about a quarter inch wide and clear. It runs the length of the print head area. That contains the stop strip. That strip or the sensor on the print head itself may be dirty and not sensing the strip, therefor not knowing when to stop.
Posted on Mar 14, 2008
  • Rick Kasper Mar 14, 2008
    The print head sensor itself may have failed and simply is not sensing when it gets to the stripe. That seems like what is going on now.
    Less likely is some software corruption in the printer. That may be very hard to reload with the printer crashing.
    You can go to www.hp.com and to their driver and software location, download the software and see if your printer will accept it.
    Honestly if it comes down to not being able to correct it with the software, give consideration to simply replacing it. I know that's not what you want to hear, but parts and labor to repair those, is pretty expensive.
    The main processor in the printer may have also failed. Even if your sensors are working, but that board is not reading the signal, it will slam the print head as such.
    Sincerely wish I could offer you more. There really is not a lot that senses that head, just when the sensor light is no longer reflected through that strip, it signals it to stop.
    Let me know ....
    Wish I did. Once you clean the strip and sensor, most likely a more involved electrical problem. wish I could offer more, But not much to sensing that movement of the print head
There is paper in the tray and ink in the printer. When I go to print something, the carriages makes a noise, then the orange light (check paper, check print cartridge) comes on and I can't print
Make sure you don't have a piece of paper inside the machine blocking the carriage, and that the print heads are properly/securely seated in the carriage.
Jan 16, 2011 | HP PSC 1510 All-In-One InkJet Printer
When i turn my printer on, the ink cartridge carrier zooms back and forth really fast, slamming into each side. The printer shows a paper jam, but there is no paper in it. Also, when the cartridge...
OK, it sounds like a defective printer that needs to be reset.
Unplug the power to it and replug the power back in to see if it stops doing this.
Read over the following paper jam link from hp.com. It might help you get the paper jam indicator to not light up:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu00697&tmp_track_link=ot_faqs/top_issues/en_us/buu00697/loc:6&lc=en&dlc=en&cc=us&product=90764
Oct 28, 2010 | HP PSC 1210 All-In-One InkJet Printer
Brother DPC-165C has 'Init Unable AF' error
Yup. I suspect the head has been removed from the unit. There are adjustments on some printers. It was assembled wrong. The grating noise is likely the auto cleaner. If it cannot go 'home' the unit will not initialize. Possibly the head detect sensor is broken or covered. If the head will not home (moves out and back more than once or slams home hard), 'Init Unable AF'. You may be able to order a service manual from Brother for this. A repair shop can order the manual as well. (I suspect you need a new print head as well. You might want to replace the printer) see tips on bubblejet printers.
Mar 20, 2010 | Office Equipment & Supplies
My epson cx3200 says paper jam, I dont see any paper jamed, when i press the button to say ive cleared it,it then runs a sheet of paper through it and says paper jam again, surely if there was a paper jam...
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 06, 2009 | HP PSC 2210 All-In-One InkJet Printer
Print head slams side to side against little black movable posts.
Sounds like your printer needs to be serviced. Would seem to me like the rollers are dirty and needs cleaning. There's also a possibility of dust and paper bits being in other areas of the paper path blocking it.
Oct 01, 2009 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 2210 printer jam
your printer need to be opened and check for any lever is struck or dislodge, it will be better if you send it for servicing
May 01, 2008 | HP PSC 2210 All-In-One InkJet Printer
Paper feed
sounds like print head is not engaging home switch or sensor. open the printer and look for any such switch to sense print head at home position.
Jun 01, 2007 | HP PSC 2210 All-In-One InkJet Printer
Hp psc 2410 photosmartservicing manual +free
remove the paper roller at the back of your printer and then see if there is a paper inside print head.
Mar 15, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
443 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
