Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Temporary loss of picture
Sudden temporary loss of picture. Audio remains ok. Picture loss can occur from live signal or recorded DVR. After a few seconds the picture normally reappears. Tapping the TV will often get the picture back immediately. The problem doesn't normally start unless the tv has been on for over 1 hour.
  • 84 Answers
First thing is to change the lamp
Posted on Mar 23, 2008
  • matt wilson Dec 05, 2011
    I have the same problem i have sund but no pitcure.do i need to take to shop or is this somehing i can fix at home.
SOURCE:
Fix tv picture
If the TV is receiving its signal from a cable TV box or DVR then you need to find out if the problem is in the TV or the cable box/DVR. Connect a different source to your TV such as a DVD or Blu-ray player and play a DVD movie. If the problem occurs again it suggests the TV needs repair. If the TV works OK when playing a DVD movie then that suggests that your cable box/DVR needs repair or replacement.
If your TV is receiving its signal directly from an antenna or cable outlet on the wall then you should try replacing the cable wire from the wall to the TV with a new wire. If that doesn't help then your TV probably needs repair or replacement.
Dec 29, 2015 | Sanyo Televison & Video
My picture breaks up and I loose sound. usually while viewing something I've recorded on my DVR. is it my tv or the cable? or the channel itself?
If it is only during watching a recording on the DVR then it may be the DVR that is the problem. Does a recording always break up at the same point? If so then the recording itself is bad and this may be due to a poor signal being received. If the breakup occurs randomly then the DVR may not be able to read the data from the recording media (Hard disk or DVD - you did not specify). The obvious first step is to try the DVR on another TV.
May 16, 2011 | HP Lc3272n 32 in. LCD Television
DVR refuses to rewind or pause live TV or record
ruukasu2005,
If you are still experiencing problems with your 625 receiver performing live DVR functions, try unplugging the receiver for about 10 seconds and plugging back in. This will cause the receiver to reboot and acquire satellite signal. After the picture returns, then try to pause. If it still doesn't work, then we may need to replace the receiver. I hope this helps.
Ray Calo
DISH Network
Jul 08, 2010 | DISH Network DVR-625 DTV Receiver /...
Intermittent sound/picture freeze when recording
this fault could be due to electrical interference ie freezer cutting in/out .just because your signal is strong dose not mean its interference free .check you analogue picture get it as good as you can with no ghosting. i also live in the southwest cornwall infact .aerials in lofts are not a good idea .i would mount it outside. by the way i am told that when the old analog channels are turned off the digital signal strength will be increased. good luck .farr64 [camborne cornwall]
Apr 29, 2009 | Televison & Video
Magnavox MPTV68A "Magnavox" emblem is displayed and won't disappear
I don't know the exact TV, but Magnavox usually have an item or two items in the menu system where the "Magnavox" and also the "blue screen of death" can be disabled. Look in your manual.
I'd suggest the reason it appears is temporary loss of signal from the antenna, set top box, cable system or whatever it is you receive your TV programming via. I don't have an answer as to why it occurs watching video, but turning off the logo and blue screen should help. If it still occurs, it's time for professional intervention!
Jan 02, 2008 | Philips Magnavox 27MS343S 27" TV
Audio on DVR recordings on non-digital channels squeals on playback
Try a system reset by unplugging the unit from all power, wait for 5 minutes and retry. This is an unusual problem...accordianman
Oct 13, 2007 | Arris DCT6200 DTV Receiver
Audio problem with sony sxrd 60" hi def
i am having the same problem, but mine occurs about every 3 minutes. i get a 1 second pause in the audio that shows up in the recordings as well as live. it doesnt seem to matter if it is hd or not, but very frustrating.
Jan 20, 2007 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
119 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
