Question about Toshiba Tecra 9000 Notebook
Wireless lan cannot connect to residential gateway with an att 2wire wireless modem
  • 1 more comment
  • df8bl Mar 14, 2008
    when i try to type in the network name the prompt say must be 6 chacters. the network name is 8.
    Can anyone help?
    Thank you, I have tried this, and all that comes up is infrastructure with 1 channel named other. My roommate who has the sevice verified the name of the network is 2wire900 which is encrypted.
  • 520 Answers
You should be able to search for available networks and then select to connect .
Posted on Mar 14, 2008
  • Anonymous Mar 15, 2008
    unless you have a wep key you will not be able to access that network anyway.you need to search for a unprotected network.
    to search,select in drop menu for any networks.in properties put tick inside box for the network provides key.
    make sure when you installed software that uk was selected and not fdd;or any other for that matter because this tells the program to search in given area fields(channels)
SOURCE:
How to get my 2wire ip number
There is a problem: you are connected on LAN side of the modem, so your IP is privat and are not visible in the Internet. It?s like 192.168.x.x .On the WAN side you have another IP that's could be public: 5.35.85.x .To see the public IP use a specific web site like: http://pingme.info/
Jan 01, 2015 | Gateway At&t 2701hgv-b 2wire Hi Speed...
I have a 2wire 397 modem router from att in line ,i want to add another 2wire modem router in line to a different room to hook up a samsung 3d blu ray to go on the internet
you cannot have 2 modem routers on the same line, if your current modem router has wifi, you might consider using a wifi repeater that will pick up the signal elsewhere and give you added lan ports. alternatively, you could just run a lan lead to where your samsung is and use a 5 port lan switch.
Apr 26, 2011 | 2wire (2701HG-B) Wireless Router
Http://192.168.1.254/ has been put into my home page browser but nothing happens
IP ADDRESS 192.168.1.254 is the default gateway of an AT&T modem router (RESIDENTIAL GATEWAY) (2WIRE). for this ip address should be able to view the main screen of your 2wire modem and if not your computer is connected to a different network.
1) try connecting the computer to the 2wire RG using a ETHERNET cable (if your connected via wireless)
2) make sure that the DSL light is solid and not blinking.
3) if your computer already connected by a ETHERNET cable, try accessing the same ip address if your able to view the main screen of your 2wire modem it means that your computer will be able to connect to the internet.
4) try this also:
this for internet explorer:
click tools - connections - LAN settings
( if there's a tick mark on PROXY SERVER remove it )
if you do have tick mark on PROXY SERVER then your computer have a virus, because virus can put a tick on PROXY SERVER without you noticing it.
after removing the tick you will be able to connect to the internet again.
Apr 10, 2011 | Computers & Internet
I had ATT DSL w/ a linksys wireless router. I was
So, both computers are on the lan segment of 2wire? How many lan ports on 2 wire? Can you do ipconfig from the command line on both computers to see what the addresses are? In most cases, the first 3 octets xxx.yyy.zzz.### should be the same. If not, then 2wire is configured for vlan and the computers are actually on different lan segments & cannot communicate with each other.
Another thing you can do to troubleshoot is to ping each other's address.
You have to first establish there is communication between the 2 systems before troubleshooting further. Otherwise, you could be wasting a lot of time.
Jun 04, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
I recently reactivated my internet service with At&t. I already had a modem, however they sent me a kit that included the 2Wire Wireless/Gateway. I will be using a laptop also, will the 2wire replace...
think the new ones are capable of being wireless. if your laptop has wifi it will work. if not. should also have a lan connector to be wired.
or if CLEAR.com is available in your area you can have multiple connections with them. we can setup your account if your address is verified by there.system. and we give you $45 back on new activations. just ask me how.
Dec 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
How do I connect to XBox live w/ ATT 2Wire?
to connect your xbox live wireless to 2wire gateway router you need to go to your xbox menu and click on settings then click A on joystick.Go to network settings then select ip address configure automatic ip. DNS should also be automatic. Under advance tab you'll see wireless you need to click connect.if you are prompt to wype encryption its the 10 digit number enclosed in a bracket on the buttom of 2wire router go to
Aug 19, 2009 | 2wire 2700HG-B Router (2700HGB)
Can I use AT&T 2WIRE 2701HG-B DSL to ant ISP?
look if u wish to go for verizon service,,they will provide u with a wireless modem as well,,but if u tell them that u hav a modem then they might configure this modem only,,both ATT and verizon are DSL service providers with PPPoE connections.the only thing u need is the username and passwrd from verizon which u have to setup on the first page of the 2wire setup page,,both the connections are dhcp based.so no other connection settings change required.But when u talk with verizon make sure u tell them of the 2wire modem
Moreover verizon has wireless broadband service which is actually a express card tat u have to put into your computer and u can go online anywhere u go within ur country{it works like a mobile phone}
best of luck,,keep me posted
May 14, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Connecting 2wire modem./router to extra linksys router
to get this right you must make sure that the 2wire will be configured to be your gateway which means that the 2wire itself will be connected to the internet then set the linksys to DHCP mode because if you dont it will give you a router behind router error , make sure that the 2wire is properly authenticated and connected to the internet to make sure access the gui by typing gateway.2wire.net on your browser and run system set up wizard
Dec 11, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
DSL (2wire modem) and LAN conflict
You can actually try accessing the interface of your gateway and put it on DMZ mode. That way it will open the ports on your gateway to ensure passage of all data from your gateway to all your computers even when the dsl is on. But make sure tat you have security software installed on all your computer workstations bec. putting your 2WIRE gateway on DMZ mode will expose your connection.
Aug 15, 2008 | 2wire 2700HG-B Router (2700HGB)
2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at [email protected]
Feb 03, 2008 | 2wire (1000-400108-001) Router
Open Questions:
See all Toshiba Tecra 9000 Notebook Questions
Toshiba Tecra 9000 Notebook Logo
116 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
