Question about HP Photosmart M525 Digital Camera
Camera my camera lens is stuck and when i turn it on goes right back of what do i do to fix it
  • HP Master
  • 4,738 Answers
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Mar 15, 2008
SOURCE:
Nikon coolpix L810 lens is stuck. when powering on no move movement of lens or error message. Then camera turns off and lens remains stuck. Does anyone know of a solution other than taking it into a...
I plugged in usb to my computer than turned on. The camera's lens went right back in I was able to unplug the usb and my camera was back to normal.
Aug 05, 2013 | Nikon COOLPIX L810
The lens on my samsung camera keeps getting stuck. When I turn it on it it beeps a few times and nothing happens,the lens doesnt open or anything. Before that it would justt beep and the lens would not go...
Make sure you have installed freshly charged batteries on your Kodak Camera. If you already have but problem still goes on, then try to do a little fix.
With your camera turned OFF, hold the camera on your right hand with the lens facing the ground. Then hit the camera's base on your left palm as you push the button to turn on the camera. You might have to do this a few times. What happens is that there could be a grit of sand that got stuck between your lens' barrel and the camera's base, preventing the lens to retract freely. If the above solution does not work, you might want to apply a bit of force by twist-pushing the lens inside with your index finger while trying to turn on the camera. The idea here is to remove that grit out of the camera.
Please let me know how this goes. Thank you for using FixYa.
Jan 22, 2011 | Samsung Cameras
This is exactly my problem.
Focus is stuck - could be sand or something in the focus gears. That's the weak spot for these lens. Contact your local Olympus service center or any other camera service center or me at [email protected]
Tom
Jul 28, 2009 | Olympus FE-170 Digital Camera
I have a Sony Cybershot DSC-W30 camera. This morning, I took a picture of my daughter, and turned the camera off. Right when I was turning it off, she asked me if she could see the picture, so I quickly...
MY LENS IS ALSO STUCK OUT. I pressed on the lens by accident while it was on. Now it won't turn on and the lens is stuck out. I tried twisting it left as recommended by aplynn09 but didn't work. SOMEONE PLEASE HELP!!!
Jul 16, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
THE LENS COMES OUT BUT GOES RIGHT BACK IN AND
I had the same problem. All I did was hold the lens out when it tun so that when it shuts off, the lens is still out. Then I moved it around a bit. Something was stuck in the lens and when I moved the lens around, it came out. So now it functions normally :] I hope I helped!
Jul 07, 2009 | Kodak EASYSHARE M1063 Digital Camera
Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 03, 2009 | Nikon COOLPIX L3 Digital Camera
Camera lens stuck
Look at some of my posts today.
This may be that the lens is off track and may be able to be pushed back by a little force as you start the camera....see my other posts on this problem.
Jun 11, 2008 | Nikon COOLPIX L3 Digital Camera
Camera lens stuck
We dropped our Samsung s730 (twice!) and got the lens jammed slightly sideways. I read a blog somewhere about this and just did what she said- If it is stuck out and obviously jammed sideways, push on the lens the way it should sit. I had to press really hard, but it snapped back into place and now works fine!
This WILL NOT work if: The lens retracts normally and goes back out normally, or it is not OBVIOUSLY stuck slightly askew. Sadly, with cameras this low in price about the only option is to replace it as repairs would cost more than a replacement.
In the future I plan on getting a squaretrade.com damage warranty on ALL my small 'droppable' electronics, it is pretty inexpensive (usually the same price as 'store brand' extended warranties that only cover defects).
Russell - Idaho USA
May 15, 2008 | Samsung Digimax S730 Digital Camera
Turn camera off then on again?
I posted and looked around more online- I found this, did it and it worked! I just held camera with lens upright and used my left thumb and applied pressure when turning off with right thumb.
"I have dsc-w70 with lens stuck out . When you turn it on , you will see a message turn the power off . I've just fixed this morning without any tool and it took only a second . When i turn the power off with my left thumb , i used my right hand to squeeze the lens with little push it in , it will be back to the right position it should be . My camera is working great now like before . Do not affraid , hope everyone can do it . Good luck ."
Feb 22, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Camera freezes in any picture taking mode
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. you need professional service to fix it.
Dec 28, 2006 | Gateway DC-T50 Digital Camera
HP Photosmart M525 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
