Question about Siren Edge MP3 Player
Siren MP3 turns screen off but sound keeps playing
I got my husband this MP3 player and he used it one or two times. He is not into technology so it has been sitting unused for about 4 months. My MP3 player broke so today I decided to use his. As I listen to my books on MP#, the screen goes all black. I can still hear the book. If I try to hit the menu button, or the volume button, nothing happens. I cannot even turn it off! I have to pop the battery out to turn it off! Sometimes (about half the time) the sound turns garbled when it does this. Does anyone have a solution? Thanks, CJ
  • Anonymous Apr 15, 2008
    The screen turns off in less than a minute regardless of any settings. Most of the time the sound continues, in which case it IS possible to turn the player off by holding down the power button (blindly). But occasionally, it starts screeching instead of normal music and nothing short of battery removal works.
I had the same problem when I purchased this for my son. I called the place where I purchased it from to return it, they requested a call tag from UPS, then after 1 more try, I turned it on and was able to get the menu button to work and went through some of the different functions and it started working again. I would suggest just experimenting with some of the controls and see if that maybe will trigger something in it. Ever since then, it has worked fine.
Posted on Mar 26, 2008
6ya staff
SOURCE:
I have a mp3 by the brand of (siren) and need to know to download music of the computer.
MP3 players can only play music files in mp3 file format. You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format:- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Apr 25, 2011 | Siren Edge MP3 Player
MP3 troble
I had to go media player and then hook up siren . if that doesn't work to my computer and then plug in siren and delete files manually
Feb 25, 2009 | Siren MP3 Player
Have problems with my ILO
1. Connect the player to the PC using the USB cable.
2. Open Windows Media Player.
3. Go to the Sync or Devices tab and delete all content from the player.
4. Go to the Tools menu and select Options.
5. Select the Devices tab, highlight the ILO or Siren player and click on Properties.
6. Uncheck the box "Create Folder Hierarchy on Device"
Sep 23, 2008 | iLO (2 GB) MP3 Player
HELP!!!
The songs that you are syncing may not be in the right format for this particular Mp3 player. Where did you get the songs?
Q: What type of files can I play?
A: Mp3 and WMA files. DRM protected WMA files, such as those purchased from many online music services, must be copied to the player via Windows Media Player or the music management software compatible with your online music store.
The player does not support AAC file playback.
(i.e: iTunes will not work)
May 23, 2008 | Siren Edge MP3 Player
My siren 4GB mp3 player
Why does my player display "Boot error, Shutting Down" when I switch it on?
"– The player has been formatted with the wrong system, for example NTFS, Mac OS or Unix. To enable it again for playing audio tracks, please format the player in FAT/FAT32 format."
– If formatting was not successful, please reinstall the firmware while the player is in Recovery mode (Refer to the chapter "If the player does not work" in your instruction manual).
Hope this helps. M~
Apr 30, 2008 | Siren Edge MP3 Player
I don't know what is wrong... With my Siren Edge
Try windows Recovery Mode first:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jan 06, 2008 | Siren Edge MP3 Player
Dropped MP3 Player/blank screen
Try pressing and holding the power/ menu button while holding down the play/ pause button. Do this till the screen says goodbye or turns off!!
Dec 31, 2007 | SanDisk Sansa e250 MP3 Player
Siren Edge MP3 player
deb - water damage = unfixable - I have heard courageous stories from people who dried out their players; the best scenario is that they can get it to work sometimes, every once in a while - sorry
T-Mitch - Uninstall MTP Device in Windows' Device Manager
Dec 28, 2007 | Siren Edge MP3 Player
Repair LCD SCREEN
The Reset is a tiny pinhole(unlabelled) - you must get a size #1 paperclip to fit
LCD screen that are cracked/damaged cannot be repaired - Siren will not send components
Oct 02, 2007 | Siren Edge MP3 Player
Mp3 Player wont connect
Aug 09, 2007 | Siren Edge MP3 Player
Siren Edge MP3 Player Logo
52 people viewed this question
Top Siren Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Siren Audio Player and Recorder Expert? Answer questions, earn points and help others
