Question about Kitchen Ranges
Oven won't heat beyond 200 degree F. after replacing igniter.
I don't have the user's manual and I don't see any markings for Fahrenheit or Celcius.
  • josey78681 Mar 21, 2008
    I discovered that my pressure compression valve was defective and I replaced it. Stove works great now.
    New Friend:
My Maytag smoothtop double oven presision touch range, the bottom oven only heats up to 195 and the bottom coil is cold, the parts house tested it
Posted on Sep 10, 2010
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
No need to reply to this, as it is aduplicate submission, just needed to clear it from my page of unresolved asked question list. hope all was/is resolved anyhow
Posted on Mar 14, 2008
SOURCE:
How do I switch my Panasonic NN-CD989S from Celcius to Fahrenheit?
talk with your local service agent and see if he can advise on what to do as he probably has met this problem in servicing units and has to change the setting
Jul 07, 2016 | Panasonic NN-CD989S 1.5 CU FT GENIUS...
How do I warm up the oven to 200 degree celcius
Most American made ovens are going to be in Fahrenheit and 200 degrees Celsius would be just under 400 degrees in Fahrenheit. Hope this helps!
Feb 13, 2015 | Ovens
HOW TO REPAIR A THERMOSTAT
Hi, it won't cause your oven overheating by hanging loose. I think your thermostat is faulty. I don't suggest opening it to try and repair it yourself. If your tamper with the metal plates inside, your temperature will not be accurate as where you set it for 120 degrees Celcius or 248 fahrenheit it will meybe give you a true temperature of 220 degrees celcius or 428 fahrenheit which would be chaos. Rather rplace the complete thermostat unit.
May 03, 2014 | Bosch Ovens
What dose 180 degrees Celsius Fahrenheit mean so I can bake
Hi Nancy,
180 degrees Celcius is about 360 degrees Fahrenheit.
Jan 29, 2014 | GE JKP30WMWW 27" Built-in Single Electric...
Convert celcius to farenheit
180 degrees c is equal to 350 degrees f (356 to be precise)
MY OVEN IS VIKING OVEN CAN YOU PLEASE TELL ME HOW TO CHANGE FARENHEIT FROM CELCIUS
Hi and welcome to FixYa, I am Kelly.
Here is how you change it:
Degree Format
The oven has been preset to the Fahrenheit temperature scale.
With this feature, users can switch to the Celsius temperature
scale.
To change degree format to Celsius:
1. Press "SETTINGS." Settings menu will appear in display.
2. Press the up or down arrows until "DEGREES:
FAHRENHEIT" appears in the display.
3. Press "ENTER" to change degree format. Current value
will flash.
4. Use arrow keys to select "CELSIUS."
5. Press "ENTER" again to set degree format.
6. To exit the Settings menu, press "SETTINGS."
You will need to press the up or down button after pressing settings until you see Celsius appear then press ENTER and the Celsius flashes then use the arrow key to select Fahrenheit (still flashing) and once again press enter (saves) and it stops flashing. then press settings to exit the settings menu.
Thanks for choosing FixYa,
Kelly
Mar 22, 2011 | Microwave Ovens
My oven only heats up to 250 celcius
That is actually very hot in fahrenheit, around 482 degrees to be exact. Is that not hot enough?
Dec 23, 2010 | Maytag MEW5530D Electric Single Oven
Ovens won't heat up beyond 250 degrees.
if you cant program it for more than the 270 you may have changed it from farienhiet ( bad spelling) to celcius. pushing and holding broil may switch it back.
May 02, 2009 | KitchenAid Architect ® II KEBS208S...
Oven problem
look closely at the display make sure you haven't reverted to Celsius, instead of Fahrenheit. if so refer to user manual for way to change back.no manual?? post the make and model see if i can find for you
Mar 14, 2008 | Kitchen Ranges
Kitchen Ranges Logo
153 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
