Question about Intel Desktop Board SE440BX-2 Motherboard
I did put more ram in and it did help a lot. I would like to install a dvd burner but they require more than a P2 350. Would a P3 600 be enough to run a dvd burner?
  • 818 Answers
Yes, i think that this will be optimal. rember after some dvd burn to
defrag your hard disk
Sergio
Posted on Mar 15, 2008
6ya staff
SOURCE:
Computer don't start,
If it doesn't start at all, check motherboard for a short by unplugging the processor power cable (4 pin normally), and turn the computer on. If the fans start rotating, it is probably a short. If that isn't the problem, check for cables that should be connected, and test the processor in another computer. Hope it works (it did for me)
May 27, 2014 | Powerspec G213 Desktop Computer; Intel...
AWRDACPI P4M80P sound driver, is there a place i can get one free
Go to the following link and have it detect the most up to date drivers for your motherboard. THIS WILL ONLY WORK WITH TRUE INTEL HARDWARE!!
http://www.intel.com/support/detect.htm
Jan 23, 2010 | Intel Desktop Board SE440BX-2 Motherboard
Intel desktop board SE440BX-2
Intel don't do an xp driver for this board. It may be worth downloading and trying the NT driver from www.intel.com
Jul 25, 2009 | Intel Desktop Board SE440BX-2 Motherboard
Sound Problem for SE440BX-2 in XP OS
You can download the driver here :
http://downloadcenter.intel.com/Detail_Desc.aspx?ProductID=208&DwnldID=3522&lang=eng
Mar 20, 2009 | Intel Desktop Board SE440BX-2 Motherboard
I have an intel SE440BX-2 that does not recognize my mouse and keyboard. The scroll lock, num lock, and caps lock all flash repeatedly. The keyboard and mouse do not work at all. Tried 2 different hard...
hi im josh in cebu.friend if it wnt detect the probem is on your bios setup or on your motherboard parts like the cmos batt. you go to bios setup then go to pheriperals then choose enabled keyboard and mouse. or try to remove your cmos batt then afterr several seconds.install back firmly and tightenly. then reboot your pc.this will help you a lot good luck
Feb 23, 2009 | Intel Desktop Board SE440BX-2 Motherboard
I have a P3 at 500MHz and was wondering with this Motherboard,
The motherboard has three, dual in-line memory module (DIMM) sockets. Minimum memory size is 16 MB; maximum memory size is 768 MB. The largest DIMM supported at this time is 256 MB using unbuffered 128 Mbit technology parts. The BIOS automatically detects memory type, size, and speed.
The motherboard supports the following memory features:
  • 168-pin DIMMs with gold-plated contacts
  • 66 or 100 MHz SDRAM
  • Non-ECC (64-bit) and ECC (72-bit) memory
  • 3.3 V memory only
  • Unbuffered Single- or double-sided DIMMs in the following sizes:
DIMM Size Non-ECC Configuration ECC Configuration 16 MB 2M x 64 2M x 72 32 MB 4M x 64 4M x 72 64 MB 8M x 64 8M x 72 128 MB 16M x 64 16M x 72 256MB 32M x 64 32M x 72
Synchronous DRAM (SDRAM) can be installed in one, two, or three sockets. EDO DIMMs are not supported. Memory size and speed can vary between sockets.
Note: Intel® Pentium® II processors with 100 MHz front-side bus should be paired only with 100 MHz SDRAM. Processors with 66 MHz front-side bus can be paired with either 66 MHz or 100 MHz SDRAM.
All memory components and DIMMs used with the Intel® SE440BX-2 motherboard should comply with the PC SDRAM specifications. These include: the PC SDRAM Specification (memory component specific), the PC Unbuffered DIMM Specification, and the PC Serial Presence Detect Specification.
Note: It is recommended that SPD memory DIMMs be used with the SE440BX-2 motherboard. However, the BIOS will allow the use of non-SPD DIMM memory.
So the max you can go is 3 x 256 MB.
Thanks and please take a moment to rate fixya.
Jul 06, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Processor up grade
The fastest cpu you can use on your mb is a pentium 3 800. Providing that you have the latest bios update.
check this link here.
You may need to download and install bios update from factory website .
Feb 22, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Intel Desktop Board SE440BX-2 Motherboard Logo
85 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
