HP iPAQ  rx5915 Logo
Posted on Mar 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Touchscreen not reacting to stylus but the buttons work ok
Anonymous
Level 2:
  • Expert 195 Answers
  • Posted on Mar 29, 2010
Anonymous
Expert
Level 2:
Answers
195
Questions
0
Helped
37377
Points
348
  1. urn on your HP iPAQ Pocket PC.
  2. Use your stylus to tap on the "Start" menu.
  3. Tap on the "System" tab.
  4. Tap the "Screen" icon.
  5. Tap the "Align Screen" button.
  6. Tap the center of the cross-hair object carefully at each location as it moves around the screen.
  7. Tap "OK" to complete the screen alignment.
Touch screen calibration
To calibrate the StreetPilot c-Series touchscreen, follow these steps: Begin with the device turned off and unplugged from a power source Power the device on and continue to hold the power button for 1 minute Release the power button when the screen displays "Press Dot" Accurately touch the dots as they appear The dots will change location A stylus or pencil eraser may be used to accurately touch the dots Touch OK when the "Calibration Complete" appears The touchscreen is now calibrated.
My v touch pro touch screen wont work
b> The Touch Pro2, manufactured by HTC, is a smartphone designed to be used with the Verizon wireless phone network. This smartphone combines a cell phone, PDA, MP3 player and wireless Internet access into a small, portable device. If the device begins malfunctioning or freezing, you can perform a soft reset. A soft reset does not delete any of your saved information. It shuts the phone down and reboots the phone to the Verizon Today Welcome Screen.
Pull the stylus upward to remove it from the side of the phone. Push the back cover upward using your thumbs until it pops from the back of the Touch Pro2 phone. The back cover can then be lifted away and removed from the phone. Press the "Reset" button, on the upper, left side of the back panel using the stylus tip. The device will now restart and display the Verizon Today screen. Snap the back cover back onto the back of the phone. Touch Screen is Not Working
As most tablet PCs ,Phones and Mp3 players are full touchscreen devices, you use your touchscreen for everything you need to do on your Tablet PC. If the touchscreen stops working, you can't get much use out of your Tablet. Touchscreen issues are caused by hardware or software problems, but check with your manufacturer before attempting a DIY repair.
Hardware Issues Damages to the surface of your Tablet PC can cause the touchscreen to malfunction or stop working entirely. For example, putting pressure on the screen, such as placing the Tablet PC in a bag with other heavy items, can cause cracking along the screen. Exposing the screen to water, even in small amounts, can cause the electrical system within the touchscreen to malfunction. If the electrical system malfunctions, the touchscreen stops working properly. b> Screen Sensitivity b> Pressing the touchscreen on your Tablet PC sends a signal to the internal motherboard. The motherboard then transmits to other components, such as the hard drive. The accuracy of the touchscreen depends on the screen's sensitivity. Many Tablet PCs include a program for calibrating the touchscreen. This program may fix minor responsive issues. Even a small amount of dirt or debris can effect how the touchscreen responds. Cleaning your touchscreen with an electronics cleaner or a microfiber cloth may help improve sensitivity. b> Software Issues b> A driver is a software program that interacts between hardware devices and an operating system, Your Tablet PC needs the right drivers for your OS to work correctly. Outdated or missing drivers can cause the touchscreen to work improperly, or not respond at all. Visit the manufacturer's website to find the right drivers for your Tablet PC. b> Repair b> While you can perform some minor repairs yourself, such as re-calibrating the touchscreen sensitivity or installing drivers, only perform a hardware repair if you have a good working knowledge of electronics, specifically Tablet PCs. Before attempting to repair your device, contact your manufacturer. If your Tablet PC has a warranty, completing an unauthorized repair may make you ineligible for claiming that warranty. Hope this helps
b>
2helpful
2answers
The touchscreen us not working at all, the other buttons work
Hello
Do not put lotion on your hands and do not touch the screen if your hands are wet. Any kind of moisture can affect the way the touchscreen operates. Moisture sometimes slows the response time from the screen to the operating system.
Check for a protective sheet on the screen. If there is some kind of a film or sheet on the touchscreen, the screen is likely not able to react to all of the sensitivities of the touch of a finger as it normally would.
If there is an application open and the touchscreen seems to not be working, simply close the application and retry it. A frozen application can usually be closed by pressing and holding on the circular button located just below the touchscreen.
Completely reset the phone by holding the "Home" button and the "Reset" button for a full 10 seconds until the phone resets.
THANK YOU FOR VISITING FIXYA
Mar 07, 2011 • Cell Phones
1helpful
2answers
The touch screen does not reacted when touched. The battery is fully charged and the software has been updated.
These units have a common problem with touchscreen failures. Please see this link for more info and how to have it repaired:
http://www.sharc.net/gps_LCD_repair.htm
1helpful
2answers
The touch screen of my zire 21 does not react to the stylus.
Digitizer is out. Take it to a cell phone repair store but be prepared to pay out the nose. In essence, back it up and throw it.
6helpful
2answers
Leapster got wet, no longer reacting to stylus prompts
Did you try to recallibrate it? Hold the "hint" button down while you're turning it on. Then hit "A" when the new screen comes up. You'll touch all four corners and the center with the stylus. See if it works!
2answers
DS Lite bottom touchscreen seems "stuck"
i think you should either get a new ds or tap the touch screen hard. if tapping the touch sreen harder does not work then that means it is time for a new ds.
Touchscreen application buttons
try this http://www.palm.com/us/support/downloads/m125update.html
I've a Blaupunkt Travelpilot Lucca MP3 sat nav. The touch screen is not working. It powers up. But it cannot go further. 'OK' button is not working.
i wsa in Saturn in Wiesbaden, and i tried to operate blaupunkt Lucca 3.5. the touch screen was working, but it was not accurate at all, and wasnt sensetive enough, especially with finger. with a stylus it was much better. i tried recalibrating the touchscreen (twice) but it didnt help
in other models of Blaupunkt i didnt find this problem
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
