Question about Logitech 967437-0403 Keyboard
Logitech keyboard not working
my wireless keyboard stopped responding. i replaced the batteries. i pushed the receiver button on the underside of the keyboard. the light flashed on the receiver. mouse is still working fine and is off same receiver. i pushed the button on the receiver itself to recognize the keyboard also. light blinked in response.
  • 6 more comments
  • ekgti6 Mar 24, 2008
    i have the same problem, the reciever responds but the keys dont work. The volume keys work but no letters or numbers. I have reinstalled setpoint and even tried it on another computer and it worked fine.
  • Anonymous Mar 27, 2008
    Same problem as SURESH007. Did the same as SURES007.
  • mrwaz Apr 10, 2008
    my keyboard has no response to typing. I changed batteries and nothing. prior to this, my volume went way down and I can not even get the volume green bars on my screen as I turn the volume wheel on my keyboard.
  • Anonymous May 25, 2008
    Only my media button works, others don't do anything
  • Catalina Ang Jun 09, 2008
    My Logitech keyboard is also not working!!! We replaced the batteries but get no connectivity. Although, our volume isn't working as theirs is.
  • alabamagirl Jun 14, 2008
    The mouse works - just the keyboard won't. Replaced the batteries and pushed the connect button - still not working.
  • buddy427 Oct 29, 2008
    I have the same problem as albamagirl - The keyboard just stopped working but the mouse works fine. Batteries are good - confirmed.
  • Anonymous Dec 24, 2008
    I have the same problem - mouse works, keyboard batteries good, but no kb response. KB model is Y-RK49 (Logitech). Checked the PS-2 connection on the motherboard and it is good. Next step is pull the keyboard apart?
    One possible solution here: http://logitech-en-amr.custhelp.com/cgi-... - but does not include my keyboard model.
I put my logiteck kb on sleep mode. Computer shut down next moring would not work for nothing Is there a power up sequence or somehting i need to do. Used to work, very strange.
Posted on Oct 13, 2008
  • Anonymous Oct 13, 2008
    Model number is well its called the Itouch ke. help help nobody yells help once
Try doing a system restore to when it was working
Posted on Dec 25, 2008
SOURCE:
My logitech wireless mouse stops responding now.wat to do?
Well, change the battery or change the USB port the wireless piece is in.
Hope this helps :)
Oct 18, 2009 | Logitech Cordless Mouse
Wireless just stopped working. Changed batteries,
The behavior described indicates weak/dead batteries. Logitech brags about the battery life on this model, but in reality battery life varys dramatically between invidual units. I've seen one that would not operate at all on Ni-Cad rechargable batteries (only 1.2 volts even at full charge). If you must use rechargeables, stick with NiMH (metal hydride). Better yet, use long life lithium.
Also, make sure the "Nano" receiver isn't sitting in the storage bin. This is one of two ways to power off the mouse. The other is the 'Clip N Go' dock.
Sep 24, 2009 | Logitech Cordless Mouse
My Ex110 wireless laptop stopped working.
change the batteries especially if they came with the EX100. then try connecting the mouse. receiver first push button one second and release.then on the mouse push the button one second and release.
then if the mouse connects. go to the keyboard and push button on the receiver first one second and release then keyboard for one second and release. try this three times if no connection you need to call logitech for warranty info.
Jul 19, 2009 | Logitech Cordless Desktop EX110
Logitech wireless keyboard not working
After changing the batteries and cleaning the corrosion out of the battery case, I pressed the connect button on the Logitech receiver, then the red restart button on the underside of the keyboard and it was fixed!
Mar 25, 2009 | Logitech Wireless Access Duo Optical...
Mx3000 stopped working, read forums, reset receiver now dashes only when pressing any key. rebooted computer ... now keyboard not responding agian
I got a used MX3200, got the mouse working right off, but no keyboard. This solved my problem: with the wireless mouse working took out the keyboard batteries, pressed connect button on the receiver, replaced the keyboard batteries, pressed connect button on the keyboard. Voila!
Feb 03, 2009 | Logitech Cordless Desktop MX 3000...
Wireless keyboard stopped working
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Jun 11, 2008 | Logitech MX3000 USB PS/2 Wireless...
Mouse not responding
Are the batteries good?
Try
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
May 24, 2008 | Kensington Comfort Type Wireless Optical...
Keyboard not responding
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Nov 26, 2007 | Elite Logitech Media Keyboard(KB9675590403
Cordless Desktop EX110 Keyboard doesn't respond
Look on underside of keyboard there should be a button to push that will transmit to the receiver
1st push the button on the receiver
2nd make sure batteries are inserted in right direction into keyboard then push the botton on bottom of keyboard
that should make it work
Hope that helps friend
Nov 14, 2007 | Logitech Cordless Desktop EX110
The keyboard has probably died. (It happens often). Here's a great inexpensive combo to replace your current one. https://www.amazon.com/Logitech-MK270-Wireless-Keyboard-Mouse/dp/B00BP5KOPA/ref=sr_1_1?ie=UTF8&qid=1491364851&sr=8-1&keywords=Logitech-MK270-Wireless-Keyboard-Mouse
Apr 03, 2017 | Dell Wireless Keyboard Optical Mouse w0147
Logitech 967437-0403 Keyboard Logo
2,768 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
