Question about Sharp 36R-S50 36" TV
Sharp 36R-S50 Main Circuit Board
The website you gave me says they are discontinued, do you know of any other places that may have it?
I'm looking for the main (largest) circuit board, it's located at the bottom of the tv and it has the exteranl connections. There is a large item attached to the right hand side that is heavy compared to the board and when the TV fell this broke the corner of the PC board. Everything else looks to be in good shape.
Posted on Mar 27, 2008
  • 298 Answers
The only board i show there that is discontinued is the Front Control Board Assembly. There are other boards in this unit that are not listed. So I may still be able to find it for you. Are you sure that the Front Control Board is what you are looking for? Let me know.
  • F1forHelp Mar 27, 2008
    I will check this for you and get back to you.
    The link below is for the Main Board Assembly. This is the board with all the A/V jacks and the main power transformer. However, the original board is not available from Sharp anymore. Though, you can purchase the rebuilt board which is the same but it has been rebuilt (it is a Sharp Board for this model). See the link below for the rebuilt Main Board Assembly with A/V jacks.
    36R-S50 Replacement Main Board Assembly
2002 sharp 27u/s50 how to set up
in main menu the input has to be AIR or antenna .then do an auto scan for channels
Oct 20, 2015 | Sharp 27U-S50 27" TV
Where is fuse located...part #3601-001197
The part number you provided is invalid--Samsung parts start with DD such as the main board is listed. The main board part number is DD92-00033B. There is no fuse--I've scoured the exploded diagram and parts list--there is a leakage sensor located at the bottom of the unit, directly in the center of the bottom frame. If water is detected, the sensor tells the main board to shut down. The main board is located behind a cover at the base of the dishwasher below the door. You will have to remove the kick panel to access it. WARNING--that main board cover can be tricky to put back on. It's metal, has a relatively sharp edge, and if installed improperly, will cut into the wiring harness--and that will be a BIG oops! Make darn sure you route the wiring harness properly so the cover fits properly without pinching anything(ask me how I know this--and I'm a tech--it can happen to the most experienced person). BTW, did you have a power outage recently? Maybe 3-4 weeks prior to the problem. Outages are notorious for damaging circuit boards. If your unit is totally dead, you might have a blown main board--that's why I gave you the part number. The user interface board(touch panel) is DD92-00037A. The display board is DD92-00038A. I hope I helped you!
Sep 12, 2015 | Samsung DW80F800UWS 24" Stainless Steel...
How can I hook up a headset to a sharp 36r-s50-36 tv
check the rear or front panel of your tv for a audio and video output jack slots....you should be able to able to find a jack slot with the symbol of headphone..Its normally of green colour..you should be able to plug in a 3.5 audio jack....
hope this helped you...
Dec 20, 2010 | Sharp 36R-S50 36" TV
On the circuit, one of the resistors got blown up
U can see one or two bands of the colors of the resistor right?Compare it to a couple resistors beside it or around in the board.U should know and determine it values.
May 04, 2010 | Sharp 27R-S50 27" TV
Sharp lc46sb54u will not turn on, I hear clicking inside a couple of times like its trying to turn on. Then power an OCD button blink 3 times over and over. Help!!!
It sounds like you only have the standby 5vdc circuit working, first place to look is the main power supply module, or it can be the main circuit board.
Oct 30, 2009 | Sharp LC46SB54U 46 in. LCD TV
Can this tv view in hd?
Unfortunately the answer to your question is 'NO'
You require a TV with either a HDMI / DVI .Component connections on it.
If you looking to purchase a New tv to be able to watch HD on then I would get a TV with HDMI ports on the back.
Hope this helped you out. Please Leave a Thumbs up it this did.
Cheers Little Dish Fitter
Oct 06, 2009 | Sharp 36R-S50 36" TV
Replacement circuit board for my Sharp 36r-S50
Yes, you can find replacement circuit board and any other accessories at Andrews Electronics.com.
  1. Go to the Order Parts menu
  2. Type in your model number with NO DASHES.
  3. Locate the part you are looking for in the listing that shows up. If your part is not listed, email quotes@andrewselectronics.com to request the part you are looking for.
Or I will be happy to assist you if you reply here as well.
Mar 09, 2008 | Sharp 36R-S50 36" TV
Sharp 36R-S50 36" TV Logo
99 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
