Question about Trendware TEW-432BRP Wireless Router (TEW432BRP)
Wireless router msn keeps disconnecting
  • vinrose May 25, 2008
    My problem is that i keep losing connection when I am only about 18 metres awaw from router is there a solution
  • jgan May 11, 2010
    are you disconnected from the internet? if you are wired and not wireless does it still work. if you do remain connected by being wired you can access your router by typing in the ip addy that is usually located at the bottom of the router or by searching online. once in your router site, reset to factory settings.
  • 30 Answers
It's probably the wireless connection switching from G to B mode.
Set the router and card for B mode only. You'll lose speed but gain reliability.
Also make sure there aren't any other 2.4GHz devices between you and the router, like a cordless phone.
Check for thick objects between you and the router, like walls.
get a larger antenna for the router. There are many indoor/outdoor models available. Ones with about an 8 DBm gain are about $40, and can increase your range up to 500M in open air. more expensive and directional antennas can increase this.
Posted on Jun 18, 2008
    Novelist:
  • 104 Answers
Msn has nothing to do with the router...
Posted on Mar 15, 2008
Keeps Getting DIsconnected from network
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Mar 18, 2013 | D-Link Computers & Internet
WRT54G keeps disconnecting itself, requires disconnecting/reconnecting power and running setup disk again to reconnect. System info: 12 mb/s cable broadband ISP, Motorola SB5105 cable modem, WRT54G...
Go to Administrative Page on your router at section Setup - Basic and activate: Keep Alive : Redial Period 30 seconds.
After that restart your router
Mar 04, 2010 | Linksys Wireless-G WRT54G Router
My router (d-link WBR-1310) keeps dropping internet every 10-15
Try to access the configuration page of your router and look for channel number. Change the channel number to 11 or 13 whichever is available. It should work fine after that. If it still does not work, you can hard reset it by pressing the reset switch on the router. However, then, you will have to configure all the settings again.
Nov 18, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I have a zyxel router, after connecting to the laptop via wireless, sometime it cant load the webpage such as www.google.com. but the wireless signal there showing "Connected" with full tab. After once...
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 01, 2009 | Zyxel ZyAIR B-100 802.11b (AM5009004)...
Problem with router; Msn gets disconnected frequently.
It could be the proxy or firwall setting in the router.
you need to open the router page and check the firewall and proxy setting ..
or you can download the tool from the below site
www.ultrareach.com/
and it will take off all proxy setting and you winows messenger should work.
This should help you identifing if its a proxy issu.
THanks & all the best
May 27, 2009 | Belkin (F5D8231-4) Wireless Router...
Connection disconnect
This is a firmware problem on your router , you can go to this link and download the latest firmware/software for your router http://www.belkin.com/support/article/?lid=en&pid=F5D9230-4&aid=8593&scid=0
This is the link for the steps on how to update the firmware of your router http://www.belkin.com/support/article/?lid=en&pid=F5D9230-4&aid=5947&scid=0
Hope that helps.............
Oct 05, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Msn sites are not opening
Disconnect your firewall or antivirus firewall to get access to msn.
Sep 28, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Belkin g+ mimo wont work
get a netgear cable modems and routers are based on one of there principles and that is how much packet data can the modem or router handle at a given time some are streaming data like netgear and some are static packet data this could be your hang up
Jun 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless router dissconnects
Upgrade the firmwire you will find-it on www.trendnet.com
Mar 14, 2008 | Trendware TRENDnet TEW-432BRP Cable/DSL...
Browsers keep disconnecting
First of all, make sure that your router is set to an idle time of zero in the connection menu, as inactivity can make the router disconnect from the net. Secondly, ensure that you have no corrupt temp files and cookies, use this excellent free programme to clear any temp files and redundant system files. http://www.filehippo.com/download_ccleaner/ You can also alter the channel that your router works on to(from 1 to 11) see if that stops it as it may be interfering with the phones on the 2.4mhz channel. You can also check in your router that it's not your isp by looking at the dns primary and secondary servers and the isp gateway, if there is nothing other than noughts in any of these settings, your isp may be at fault.
Mar 16, 2007 | Buffalo Technology AirStation WBR2-G54S...
Trendware TEW-432BRP Wireless Router (TEW432BRP) Logo
215 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
alex metro
alex metro
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
