Question about Whirlpool Calypso GVW9959K Top Load Washer
Machine is not draining - is not the timer this time.
My washer is not a calypso but is a top loader. I think my Whirlpool (model lsr8433kq0) was made in 2001 (when I bought it). The original timer went bad, got a new one, installed it and I can't get it to start @ the drain-spin cycle (is full of water). I can only start it at the begining of each full cycle, it shakes but when it comes time to drain it doesn't. I checked and re checked part number and it checks ok (I got it from repair clinic.com). Help is needed big time, can afford to go another weekend without it.
Many thanks in advance for the help.
Meteoro.
  • meteoro Mar 16, 2008
    Yes Sir, yes indeed. That sure took care of it.
    Many thanks.
    Meteoro.
More often than not the lid switch housing has seperated, not allowing the switch to operate properly. In a pinch9or until the new part arrives) you can "snap" the housing back together and place a zip tie around the housing to keep it from seperating again. This is not a permanent sollution, but it dies work. and my wife is still doing the laundry. I fix she washes.
Posted on Jun 16, 2009
    President:
  • Whirlpool Master
  • 2,651 Answers
Sounds like a bad lid switch, agitates but doenst advance to rinse, remains full of water?? if so lift the lid up and downa few times hear a "clicking" noise?? problably not. machine doesnt think lid is closed so for safety reasons wont spin/drain replace the door switch assy part num 3949237
Posted on Mar 14, 2008
SOURCE:
Where do you locate the model number on a whirlpool calypso?
The model number on Whirlpool manufactured top loaders is usually printed on a nameplate along the wash tub rim under the lid.
May 26, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Washer won't drain may be plugged
not draining quick enough, therefore spins with too much water throwing it self off bal. ever have any problem with this machine. heres what i can suggest. tip the machine back and remove 3 5/16 screws holding bottom panel on . on the right side approx 2/3 of the way back is the pump assy.( a yellow and black hose going to pump. are there clips on the pump holding it up to the pump motor???if so yuou can release the clips and disconnect the hoses looking for lint build up in pump itself.WARNING!!! you will ge wet ther is ALWAYS water inside this pump especially if you not pumping out correctly.i use a large black trash bag under to catch water.sounds like a clogged drain pump. they have a replacement for this particular pump. it comes as 1peice now pump and motor, bigger ports to prevent lint build up, easy enough to replace if needed. sounds like a clog fro sure though good luck
Mar 14, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
My Whirlpool Calypso Top Load Washer isn't draining or spinning. What can I do?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 07, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Get alarm code ld
CI code comes on just seconds after I start the machine. The machine itself is leveled on all sides.
Dec 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Won't fillCalypso whirlpool washer model#GVW9959KQ1 LD on display
LD is long drain error, the machine does not fill because it is in fault mode, but error is on drain system.
If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
Check if the drain hose at the back is kinked or blocked.
Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
Keep a container ready to collect water when you undo pump hose.
Ifall the rest is OK, test and eventually replace timer board.Problemwith water pump are far more commonly causing this problemsthenfaulty timer board.
Parts and diagrams available here.
Oct 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Replacing timer on a whirlpool lsr8433kq0
Garret,
Yep... it sure sounds like a failed timer. I looked it up for you, the part number is 3948852. You can find it online or see if you can get one from a local appliance parts retailer.
SG
Apr 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Washer starts then stops then starts and stops
With this Washer you are going to need the Factory Repair Manual. It will give you all the diagnostics and troubleshooting you need to find the issue and repair it. This are rather involved machines and you will need the guidance of the manual to better assist you on this. Especially when it comes to getting into the machine to replace the defective parts.
Download Whirlpool Calypso Washer Repair Manual
Good Luck
Jan 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer Wont spin
The whirlpool calypso was a lemon!!! if i were you i would buy another machine. They have many problems! Pumps go out very frequently and they are over 80 dollars. Save and buy a new machine... Sorry for the bad news.
Nov 17, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing machines
Although the Calypso was a nightmare machine, for the consumer as well as us techs, whirlpool, i feel, still makes best laundry product. The Duet is a nice model, me personnally am a fan of the regular regular mid range top loader, nothin fancy but reliable
Feb 29, 2008 | Washing Machines
Whirlpool top loader 9 kg - I can't see any serial no.
There are no lint filters on this machine. The lint is pumped out with the water. There may be a restriction in the drain line starting where it connects to the tub or the small drain holes in the inner tub may be clogged.
Jan 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
253 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
