I have a problem with my ricoh FT3613
Copier is printing a dark shadow on the the right-side of the paper. Can anyone tell me how to fix this one?
Thanks!
  • Wiclife
    Wiclife Aug 13, 2013
    clean the drum(red roller).
    Scholar:
  • 78 Answers
As your machine analogue it will suffer greatly from dust build up on the mirrors and this will cause dark copies and shadowing particularly bad on the edges.
Turn the power off. Remove the glass and carefully clean the mirror with a cloth. Do not scratch the mirrors and try not to move the lower mirrors as in some copiers they can cause it to go out of alignment.
It may be other things but this is the most likely and the only one you can fix.
Posted on Mar 14, 2008
What could the Grinding noise be that is coming from Ricoh Aficio MP C2550 for each page copied/printed?
Check for:
-broken plastic gear on right side of copier
-paper or foreign object in paper path
-paper or foreign object near fuser
Oct 15, 2014 | Ricoh Aficio Mp C2550 Copier With Feed,...
DIRTY COPIES BOTH SIDE OF PAPER
don't always believe what they say. just because its "supposed to " last a certain amount of time, doesn't mean it will. Once you get the insides dirty, its hard to get them straight again. Sometimes there is build up on the printer head from a leaky cartridge. I'm just guessing cause I had a similar brand that was brand new act up on me and because I was printing bold it started rolling the paper. I put it on economy printing to save toner and after a few runs, it cleared up. plus using a watermark helped but don't think that will help you in your situation.
Sometimes when I get a streak on one side its from light coming in from somewhere and it thinks its part of the image and prints it. If you make sure that your material is flat and not allowing light to come in or its firmly against the glass it might help.
Feb 20, 2014 | Kyocera Km-1820 Copier Fax Machine
When i print A3 on Ricoh 3035 it prints a black shade on the side of the paper ,& there is no problem for A4 , please help me
Pls tell in which way you are using A4 papers. Landscape or Portrait.? More help contact me on anuruddha07@gmail.com
May 25, 2013 | Ricoh Aficio 3045, 3035 Kit
The paper gets jammed every time i copy... my unit is ricoh ft3613... i tried cleaning the rollers it worked for a while then paper gets jammed again.. please help???
cleaning those rollers is just a remedy and i think they are worn out and they need to be replaced once the problem comes back again.
May 17, 2011 | Ricoh FT3713 Copier
Hi Ricoh 1232 copier and printer. Both copies and prints are produced as if the paper feed was slightly delayed and the print moves over about an inch: effect is you have a large margin on the left side...
Is the paper in the tray landscape-oriented or portrait-oriented? If it's landscape-oriented (short edge is fed first) then you might just need to realign the paper fences. There is a screw holding down the gear in between them -- if you remove that screw you can move the fences so that they're both lined up correctly. (Push them both in all the way or out all the way, then reinsert the gear and screw it back down.)
If the paper is portrait-oriented, it may be an adjustment that will have to be made by a Ricoh service technician. It is a simple adjustment to make, and should only take a minute or two if you can have a tech look at it.
Apr 11, 2011 | Ricoh Aficio 1232C Color Copier
Hi,i owned model ft3613.as it makes more copies it crumlped the paper more.pls help me. what can i do to my copier?
In most cases, it's either the paper in the drawer is dogeared, not lying flat and even edges or fuser rollers are in need of relacement or possible registration roller issues. The only thing you can do is check the drawer paper. Other than that you'll have to have a technician take a look at it. If this helps please rate it. Thanks
Jul 04, 2009 | Ricoh Office Equipment & Supplies
Text "ghosts" or shadows
Replace Drum or blade(if possible) will fix on most types of copiers/printers, or rarer it is cause of fuser.
Oct 19, 2007 | Ricoh Aficio 1013F Copier
131 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
