Question about LG WM1814CW Front Load Washer
LG WD-8074fhb machine wont complete washing cycle, gets down to 8 mins left and wont progress, while the pump keeps running.
  • 489 Answers
Your problem is either in the control board or the water level switch.  The computer can't tell if the water has drained or the control board is stuck in the 8 minute drain cycle.  Recommend pulling the plug and wait 5 minutes to reset the computer.  If the problem persists, it will require an LG experienced tech to see what's going on.
Posted on Apr 27, 2008
I have an LG front loader - model WD - 804 90TP and the machine is working but it gets down to 6 mins to run the spin cycle and then goes up to 14 mins and then back down again and carries on in that cycle...
You need to check the inlet valve for good flow of the water as a SLOW water pressure can increase the timing for rinse and spin.
Similarily the DRAIN pump/valve must be checked as if this is clogged then the drain flow will be LOW and the timing will extend for full drain. Remove and clean the drain pump and it can be the reason that the clothes are still wet.
Finally check on the controller for the proper timing of the cycle.
Tips on Cleaning a pump:
Sep 15, 2011 | LG Washing Machines
All the cycles are working but the washing machine will not rinse the excess water left. I have tried to take out the filter but this is stuck and will not move so the water sits in the washing machine. ...
Do not run the machine until you have cleared the filter or you will burn the pump out. You need to keep working the filter until you are able to get it opened and cleared.
Dec 31, 2010 | Baumatic BTWM4 Front Load Washer
Washing machine pumps intermittedly when filling up and then wont progress to the next cycle it stats beeping and 2 lights come on one each end of lights board
Hi just read your posting.Could you please confirm the model number of your machine for me.Now you mentioned in your posting the 2 lights that are lit when the machine is beeping are the 1st in the row and last.These lights are in a row of 8 lights so starting from the left to right the lights that are lit are 1 and 8.Is this correct?Please reply with aditional information on the questions and I am sure I can help you.Looking forward to your reply.
Oct 03, 2010 | Fisher and Paykel Fisher & Paykel Washer
I own a lg fully automatic washing machine front loader (model:WD-8074FHB)i dont have an owners manual. My question: There are 3 sections. 1st section is for washing detergent. Which of the other 2 are...
Hi Anna, As you face the machine the left section of the draw is for the main load washing powder, the middle section is for fabric softener and the right section is for the pre wash powde.
Hope this helped :-)
May 21, 2010 | Washing Machines
LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Apr 07, 2010 | Washing Machines
LG WM1814CW Front Load Washer Logo
813 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
