Mackie 450, signal light off, Sound only comes out when amp. turned up above 75%, when usually used at 40-50%. too loud at 75% and UP, does not Work at ALL below 75%. only 2 years old, with 25 uses... i must have unplugged it while it was still on! is this a Simple problem?? just a fuse?
    Brigadier General:
  • 6,966 Answers
If the receiver uses a rotary type volume control then it is a problem with the carbon pads inside. A simple temporary workaround is to spray the insides of the volume control with electronic contact cleaner. Of course best would be to replace it. This is not a critical job and would only require basic knowledge of soldering.and nearby electronics parts store. Pls note down which wire go to which pin/terminal.before removing the old volume control.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 14, 2008
  • Louie  Role
    Louie Role Mar 14, 2008
    Hi MrSoundman7,
    Guess we're on the same track. Cheers.
  • Louie  Role
    Louie Role Mar 20, 2008
    Hi again,
    Any developments with your concern?
    Novelist:
  • 142 Answers
Doesn't sound like a fuse. They don't fix themselves when you reach 75%.
Try shaking the volume knob while in the 30-50% range and/or try (with the power off) rotating the volume knob numerous times from 0% to 100%. If when you plug it back in it responds ANY differently, you might have a bad volume potentiometer. If when you shake the knob you hear static or intermittent sound, you have a bad volume pot.
The only other thing I can think of is that the wiper of the volume pot is not in contact with the windings inside the pot until you reach the 75% mark. When the volume comes on at 75%, does it start off kind of "static" then come in loud and clear? Also try this.... adjust the volume pot to 74% (or when the sound just begins to come on). At this point shake the knob. If you hear static, replace the volume pot.
Unplugging it when still on shouldn't cause any damage... in fact it probably hasn't considering it works at 75% plus.
Reason and fix for distorted sound?
Your amplifier circuit is in serious need of repair. If both amps are responding the same, then the likelihood of two separate amps going bad at same time is remote. Look at something they both share in common such as the power supply. If you do not feed the amp the correct "juice" it is not going to do squat!
Apr 06, 2015 | Mackie SRM-450 System
My Mackie 450 turns itself off why
Be aware that TIMED TURNOFF button at the back of the speaker is off otherwise every time sound level is low the speaker can go off by itself.
Dec 16, 2012 | Mackie SRM-450 System
Mackie 450v1 when i turn on low cut switch the sound stops turn off low cut and sound returns
Dusty/Faulty switch and/or opamp inside pcb, let me know to help more/.
Jan 03, 2012 | Mackie SRM-450 System
The tweeter of my mackie srm 450 V2 makes a quite loud noise (humm). this nois was there right from the beginning, and mackie told me, that this was usual....the older 450´s did not make this kind of...
The latest 450v2 include this metal portion 1 to isolate AC lines over IC's, metal part 2 is include in all versions, some technician remove them and that creates more hum at idle levels, by having both the latest 450v2's are the quietest of the v2's.
V1 did not use switching power supply, they use discrete circuit and that is why they are a bit quieter
Aug 04, 2010 | Mackie SRM-450 System
No sound from horn of mackie SRM-450
http://www.youtube.com/watch?v=8jYY3kHj1U0
Apr 04, 2010 | Mackie SRM-450 System
Humming speakers
If you disconnect the signal leads and the hum is away, it's probably a groundloop problem, or your equipment is generating the hum.
If it does not go away, the amps are defective
Sep 23, 2009 | Mackie SRM-450 System
SRM 450 stopped working, all three lights in back on, red ligh
I suspect the unit is in protection mode due to an amp failure.
Mar 30, 2009 | Mackie SRM-450 System
No sound
Willing to bet you've blown the amp, or fused the coil. I've had it happen twice, apparently when running off a power source that apparently couldn't handle the load. Hope it's under warranty - if so Loud Technologies (deals with all Mackies warranty stuff) should be able to replace the unit. Otherwise, you'll need to take it in to a service department and have it checked out.
Good luck, you'll have to arm wrestle with them to get them to replace it.
Jun 12, 2008 | Mackie SWA1801 Subwoofer
94 people viewed this question
 Grubhead
Grubhead
