Question about Philips Magnavox MT1340B 13" TV
Magnavox MT1340B Service menu
I need to enter the service menu on the MT1340B to adjust the horizontal frequency which is slightly off. I tried 062596 and menu and also 061596 and menu to no avail. Is there another code I can use on this model?
  • 1 more comment
  • frankie57pr Mar 15, 2008
    I tried but no luck. I also tried other buttons on the remote after the number sequence and no luck. I'll keep searching on the web to see if some has the solution to this and if I find it I'll post it here.
    Thanx Guru.
    Thanx avid_imps...that was it. Its tricky to navigate thru the options but I got lucky and found the horiz freq by pressing the number 2 button a couple of times.
    This is what I figured out so far:
    Use the number 2 button to select agc & horiz freq.
    3 = VCO
    6 = B-S and B-SZ
    8 = Horiz pos
    9 = Vert pos and size
    Alt/chan button to go back to main screen
    Menu button to navigate and adjust bright,sharp,color,
    tint,v-tint,contrast.
Magnavox mt1340B cual es el valor del zener que va en la fuente D657
Posted on Jun 26, 2011
  • 476 Answers
Try:
0 6 2 5 9 6 i
Where i is the i+ or info button.
Posted on Mar 14, 2008
  • David Simpson Mar 15, 2008
    Looks like this model doesn't use the 062596i method.
    Try this:
    1. Use the remote control unit.
    2. Turn the power on.
    3. Turn the power off.
    4. Press the 2, 7, 1 and then the MUTE button.
    5. These steps must be done within 5 seconds.
    (Version of microcomputer will display on the CRT. Ex: 050-0.08)
Menu segreto hannspree hsg1113
http://translate.google.com
Secret service menu Hannspree HSG1113
https://electronicshelponline.blogspot.com/2015/03/hannspree-lcd-tv-how-to-enter-service.html
Possible menu - Quoting from link above:
SERVICE MODE [Hanspree AT06 42" LCD TV] (Horizontal Frequency 31.5KHz to 48KHz)
* In the TV mode, adjust volume to Zero and press number keys 9 > 8 > 7 > 6 to enter service mode.
* To exit, press the EXIT button on the remote control.
SERVICE MODE (Hanhspree GT02 32E - GT03-37E1)
1 Switch on the LCD TV .
2 Press 9-9-1 on the remote control to enter the internal Service menu.
3 Press MENU to switch the service mode pages.
4 Press ?? to scroll through the various menu options.
5 Press ?? to change the menu settings.
6 Press MENUto save the new settings and switch to next page and press EXITto exit from service mode to normal mode.
TV / AV / S-VIDEO / WHITE BALANCE / BRIGHTNESS & CONTRAST ADJUSTMENTS
WHITE BALANCE ADJUSTMENT
1 Press 991 on the remote control to enter the internal Service menu.
2 Press MENU to switch to the PW106 Scaler Menu page
3 Press ?? to scroll to Page 2-3 options
4 Press ??
to adjust the Offset Red, Offset Blue, Gain Red, Gain Blue menu settings.
5 Press EXIT to save the new settings and exit. [Don't adjust others setting in page 2-3]
Click on the Pictures to Zoom In
BRIGHTNESS ADJUSTMENT
1 Repeat the above mentioned step 1 to 2
2 Press ?? to scroll to PW106 FE VDC Menu Page 2-1 options
3 Press ?? adjust the Brightness setting.
4 Press ?? to scroll to TV/AV/S Parameter=AV1 setting and pressuto run the setting. (This procedure will copy the settings of AV1 to S & TV)
ATSC DTV WHITE BALANCE / BRIGHTNESS / CONTRAST ADJUSTMENT
2 Press ?? to scroll to PW106 Scaler Menu Page 2-3 options
3 Press ?,? to adjust the Offset Red, Offset Blue, Gain Red, Gain Blue menu settings
4 Press to save the new settings and exit. [Don't adjust others settings in page 2-3]
YCbCr & YpbPr of COMPONENT 1, 2 WHITE BALANCE/BRIGHTNESS/CONTRAST ADJUSTMENT
Getting COMPONENT-1 connect to 1080i signal. (The settings could not be saved if signals input from COMPONENT 2 or connect to other sources such as 720P, 480P, 480i,etc.
WHITE BALANCE ADJUSTMENT OF Component
1] Repeat the above mentioned step 1 to 2
2] Press ?? to scroll to PE106 FE ADC page 2-3 options
3] Press ?? to adjust the Offset Red and Off Blue settings.
4] Press ??to adjust the Offset Green setting.
5] Press ?? to adjust the Gain Green setting.
6] Press ?? to scroll to 480i/480P/720P Parameter=1080i setting and press ? to run the setting. (This procedure will copy the setting of 1080i to 480i/480P/720P)
7] Press EXIT to save the new settings and exit.
WHITE BALANCE ADJUSTMENT OF PC INPUT
1.Connecting to VGA Timing mode
2.Under service mode, Press ?? to scroll to PE106 FE ADC page 2-2 options
3.Press ?? to adjust the Offset Red, Offset Green and Off Blue settings.
4.Press ??
to adjust the Gain Red and Gain Blue settings.
5.Press EXIT to save the new settings and exit.
May 14, 2018 | Hannspree Televison & Video
Philips magavox model 19pr15
1. To enter the Service Alignment Mode (SAM), press the following key sequence on the remote control transmitter: 0-6-2-5-9-6-Status.
2. From the top level SAM menu, use the Menu Up/Down keys to highlight the Geometry sub menu.
3. Use the Menu Left/Right keys to enter the Geometry sub menu.
4. In the Geometry sub-menu, use the Menu Up/Down buttons to select VAM.
5. Using the Menu Left/Right keys, adjust VSH so that the horizontal bar is properly centered, top to bottom.
6. Using the cursor up/down keys, select VAM from the Geometry sub-menu, and use the Menu Right key to
increase the value to obtain a slight overscan.
7. If other Geometry adjustments are needed, proceed to the necessary adjustment using the Menu Up/Down
buttons.
8. Upon completion of Geometry adjustments, press the Menu button to return to the top level SAM menu.
9. To exit the Service Alignment Mode, turn the set off with the Power button on the remote control.
Oct 30, 2007 | Philips 19PR19 19" TV
I need the code for ptv915
Service & Alignment mode enter: 062596+Index or Status
Digital Convergence mode enter:062597+Index or Status
HBSkirmit
Mar 02, 2009 | Philips Magnavox 27MS343S 27" TV
Philips 23PF9966/37 color problem!
Try to adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5
WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
Jan 04, 2009 | Philips 26PF9966 26 in. LCD Television
Service Menu Code
Its unlikely that the purple splotches can be cured from the service menu.
Assuming your TV is the Magnavox 20MC4304 combi, then the tv does not have a service code. There is an alternative though.
Details can be found in the service manual:
https://www.p4c.philips.com/cgi-bin/dcbint/sget?url=/mprdata/051111/0511110565_sma.zip&ofn=20mc4304_17.zip
May 21, 2008 | Philips Magnavox 20MC4304 20 in....
Color has too much red
Is this happening when you are switching between color tempature (Normal,Warm, and Cool). You wont be able to access it in normal menu.
You will have to accesss the service tech menu. enter "062596 then info", if u enter the code correct at bottom of screen you will see a warning menu only access by a service tech , continue in menu you will see on main option screen "alignment" enter this. Go to white point adjust the three temp settings (Normal, Warm, and Cool) settings as follows.
Color Temp. I Red I Green I Blue I
Cool 122 120 121
Normal 125 118 108
Warm 127 110 75
( These are factory specs u can tweak them to your own perference)
After u set these press left on remote and exit back to main service menu and store these setting before turning TV off set these settings
I see this alot when Philips manufactured the TV. The did store the settings.
Jan 22, 2008 | Philips 50PFP5332D 50 in. Plasma...
Horiz adjustment on magnavox 20ms233s
I can tell you genericaly what the fault is. I have not worked on your particular model, or have the service manual for it.
It is not an adjustment. There are some electrolytic capacitors that typicaly go off value with age. These would be located in the horizontal scan amplifier area.
The set will have to be properly serviced in order to bring it back to normal operation. This is not something you can fix yourself.
Jerry G.
Dec 12, 2007 | Philips Magnavox 20MS233S 20" TV
I need to no the code to the convergince eprom
The convergence is adjustable from the customer menu. If you cannot adjust the convergence properly you may have a bad convergence IC if either the red or blue wont move in any or only one direction or line up with the green. Remember, convergence on a Picture Tube Projector is never 100%. However, if you have a template and want to do a total setup you can enter the service adjustment menu by using the origonal philips remote pressing 062596 INFO. Take extreem caution not to mess with any adjustments without writing down the values first.
Oct 31, 2007 | Philips 50P8341 50" Rear Projection...
Overscan is off a bit
Does's the set have a repair history? If it was previously serviced , the capacitor which is connected between the emitter and the collector of the horizontal output transistor transistor might have been changed with the wrong value, which would cause and overscan situation.The service menu for this set is even hard for technicians to use. It' my opinion if the service manual will not correct the horizontal width, the wrong capacitor was probably installed. Scrivitron (also these sets are known for the forementioned capacitor to short , flame or open.
Jul 09, 2007 | Philips Magnavox 27MS343S 27" TV
Geometry settings all wrong
I wish I could help you but you will more than likely have to take your set to an authorized service center. Philips doesn't like to send service manuals to anyone except their service centers. Stargazer
Feb 20, 2007 | Philips Magnavox 32PS55S 32" TV
Philips Magnavox MT1340B 13" TV Logo
159 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
