Question about Transcend TS AKT4/A Motherboard
Transcend TS-AKT/B This board has jumper jp7 at end of memory slots. There is no referance as to what this jumper does. Also the system locks up randomly. It will even lock up when in BIOS. It is completely random, no pattern. Any ideas? I would like to get updated bios for this /B board. It's running a 950 mhz Duron.
  • 88 Answers
BIOS available here:
http://www.ecsusa.com/ECSWebSite/Products/ProductList.aspx?CategoryID=1&MenuID=7&LanID=9
I couldn't locate iny info on jumper JP7. If it's not listed on the documentation it's a safe bet that you'd be best leaving it well alone.
Hope this helps,
erch.
Posted on Mar 18, 2008
  • Steve Carpenter Mar 18, 2008
    Sorry, wrong board.
    BIOS no longer supported by manufacturer:
    http://www.transcendusa.com/Support/Sear...
    And yes, it's a truly horrible site to use.
Replacing a defunct AC97 Audio devise card with PCI sound card. Told to disable onboard audio with jumper. cannot find manual to locate JP7 devise looking for mainboard manual.
The manual can be found here.
Normally, the onboard audio is disabled through the BIOS settings.
Check your "integrated Peripherals" tab in the BIOS for your on-board audio device settings.
I did not see anything about JP7 when I skimmed the maual.
Aug 10, 2010 | AcerPower F1 PC Desktop
When powering on gives 3 beeps and nothing else happens
Three beeps usually indicates a memory problem. Try removing the memory and booting with only one in at a time.
Dec 02, 2009 | Toshiba Satellite M55-S3512 Notebook
It will not boot up, fans spin, no video and 3-4 beeps
If you have encounter this kind of trouble this is a RAM problem which is beeping. B
Beep code pattern on a PhoenixBIOS system means that there has been an issue while testing the DRAM refresh. This could be a problem with the system memory, an expansion card, or the motherboard.
Random Access Memory (RAM) is the "working memory" in a computer. Additional RAM allows a computer to work with more information at the same time which can have a dramatic effect on total system performance.
RAM is typically referred to simply as "memory" even though other types of memory may exist inside a computer.
At this time you need to check the memory. Remove the memory and turn it on identify in there is sound provided.
Memory is installed in the memory module slots located in the motherboard. These slots are easily locatable by looking for the small hinges on either side that lock the memory in place. Certain sizes of modules may need to be installed in certain slots so always check with your motherboard manufacturer before purchase or installation.
Oct 07, 2009 | ASUS A8N-E Motherboard
Presario won't recognize second 256 RAM
Remove the original module, install just the new one and then start your computer. If it doesn't start, the memory you bought is bad. The system boards used in the Compaqs will auto-detect memory, and there are no jumpers or BIOS settings needed.
Apr 09, 2009 | Compaq Presario 5000 PC Desktop
Memory Upgrade - from 256DDR1 to 1GB DDR1
sysa007,
EliteGroup makes two mother boards, P4VMM2, (No Revisions) & (P4VMM2 revision 8.1). Since your question states your memory is 184 pin DIMM your board must be, v 8.1. What does not make sense is the motherboard has two memory slots total.
(If you have 4 memory slots on the MB than the MB can not be the P4VMM2). Below is the link for the P4VMM2 (v8.1).
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&TypeID=1&DetailID=436&DetailName=Feature&MenuID=45&LanID=9
The P4VMM2 v 8.1 can only use, two Double Data Rate (DDR) SDRAM memory modules. These sockets support up to 1GB system memory using 184-pin unbuffered non-ECC PC2100 or PC1600 DDR DIMMs. The two DIMMS you are using must run at the same speed.
Example PC2100 266MHz. OR PC1600 266MHz.
Continuous beeping means the memory is not seated correctly.
When using only one DIMM it should be inserted in the slot closest to the CPU. Re-check your memory. Remove & reseat. Make sure the latches snap closed on each stick of memory while inserting. Below is all of ECS P4VMM motherboards;
http://www.ecsusa.com/ECSWebSite/SearchResult.aspx?q=P4VMM2&f=Products&MenuID=104&LanID=9
Good luck sysa007!
More question, post here.
Thank you for using fixya.
If you find this helpful, please vote.
Mike
Jan 31, 2009 | EliteGroup P4VMM2 Motherboard
1111111111111111111111111111111111111111
THE BATTERY FOR THE CMOS IS PROBILY THE PROBLEM 3-6V BATTERY PACK PLUG IN OR OPEN THE CASE ROUND DISC SHAPE SILVE IN COLOR SHINNY + PLUS SIGN ON ONE SIDE WITH NUMBERS AND OTHER SIDE MY BE BLANK,
BATTERY PACK BAY AT ANY COMPUTER STORE RED BLACK WIRE WITH PLUG ON ONE END AND THE OTHER END WILL HAVE BATTERY.
ON THE MOTHERBOARD WILL HAVE A 2-3 JUMPER ON IT IT MY SAY BATT. 1 HOT,
2 GROUND, 3 GROUND.
ALL MOTHERBOARDS ARE DIFFERENT
IF YOU KNOW THE MANUFACTURE THAN GO ON LINE AND TYPE IN MOTHERBAORD MANIFACTURES NAME AND FIND THE NAME OF ALL MOTHERBAORD MANUFACTURE LISTED AND THERE WEB SITES FOR MORE INFORMATIUON.
ROD
Jan 23, 2009 | Compaq Presario 5000 PC Desktop
MEMORY INSTALLATION
just insert in the black coloured slot while insering see the cuts below the ram should coincide with the black coloured memory slots thats it just keep correctly on the slot and press it the white locks will lock at the end of the slot at both the side
Note wile putting insert from the end of the slots tht is u have gap at the end of the slot the RAM should go there properly
Aug 02, 2008 | E-Machines eMachines Refurbished EMA...
RE: mother board not going on
Hi marlonvig, what type of memory (PC3200? or PC2700) memory are you using? What type in which slot?
The decription (In you're manual), refering to you're memory can be confusing.
You're manual says you can use up to 1GB of
PC3200 DDR400MHz only in Slot 1.
If you add DDR400MHz into slot 2. The board will not support it. (weird)!
If you want to reach 2GB of memory. You must use PC2700 (DDR333)MHz. 2x1GB PC2700 = 1GB DIMMS in both DIMM 1 & 2. You're board does not support DDR2 type memory.
Need you're manual? Download it from this link. Click on it.
http://www.asrock.com/mb/manual.asp?Model=775VM800
Asrock's home page for you're 775VM800 board.
http://www.asrock.com/mb/overview.asp?Model=775VM800
Mike
Apr 28, 2008 | Asrock 775VM800 Motherboard
CHANGING CPU'S TYPES AND SPEEDS
On these old motherboard there is usually one switch that is used to change the CPU type - from Slot to Socket, in this case. But there are usually a different set of jumpers that control the CPU speed. And usually another set to control the bus speed, assuming it supports more than one. In this case it might support 100 or 133, depending on the CPU.
In some cases, you can set the jumpers to "AUTO", which automatically selects the bus and CPU speed. This was only available on the higher end, newer and more expensive boards.
Nov 07, 2007 | Pc Ware M748LMRT Motherboard
NFORCE3-A Won't post with 2 sticks of 512MB DDR RAM, only if 1 stick used :-(
U cannot use 2 identical DIMMs of RAM Memory, find two same and faster, couse 233 or 300 is too slow for nForce3 motherboard.
Aug 30, 2007 | EliteGroup nForce3-A Motherboard
Transcend TS AKT4/A Motherboard Logo
188 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
pankaj rautela
pankaj rautela
Alun Cox
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
