Question about Necchi 3102 Mechanical Sewing Machine
Needle touches a metal part and makes a weird noise!
My Necchi 3102 sewing machine makes a clicking noise when i sew, when i move the hand winder to feel what is the problem, it feels as if the needle is hitting something and making the clicking noise! What could this be, and how do i fix this?
  • rawls240 May 21, 2009
    My I hear the needed hitting metal.... My needle is also very close to the hole...My needle has vered towards the left... It is near the edge....While at the same time is making this weird noise and hitting meatal but at a different spot...
Check your bobbin...make sure the handle is pointing upward.
Posted on Apr 07, 2009
You could have your needle in backwards-- thats been the problem when mine did that
Posted on Jul 07, 2008
My Necchi Sofia 300. When winding bobbin the needle doesn't disengage and the matching makes a dreadful grinding noise as it winds the bobbin
Try putting a small drop of oil on the the metal shaft of the bobbin winder if it is not moving freely. The grinding noise implicates the winder tire may be ground from the locked winder shaft. The needle not disengaging requires oil in the shaft bushing. On this machine it appears you would have to remove the covers to access the appropriate areas.
Dec 05, 2016 | Necchi Sewing Machines
Necchi supernova manual
Most sewing machines can use a double needle, the one with the single mounting shank and it turns into two needles.
MAKE sure you have Zig Zag needle plate installed to accomodate the double needle.
Turn hand wheel slowly to test then use thread and fabric and turn flywheel by hand to test sew.
Jul 19, 2014 | Necchi Sewing Machines
Sewing machine locked up
Sewing machines need to be worked periodically even if you aren't sewing a lot. The oils and greases inside get all gummed up and literally will seize them up. Your best bet is to take it to the pro, pay the $$$ and have them, clean, oil, grease, replace belts, and adjust. OR if you want to give it a try.. DIY... kerosene based cleaner. Clean it well, then oil it properly. Make sure the machine is UNPLUGGED while cleaning.
Jun 02, 2014 | Necchi 3102 Mechanical Sewing Machine
Need manual for 3102FB Necchi
I found a 3102 here - http://www.sewingstyle.com/Necchi-Sewing-Manuals.html
However, I would check with the merchant before ordering to be sure it is the correct manual for your machine.
Apr 29, 2010 | Necchi 3102 Mechanical Sewing Machine
Bobbin thread will not pick up
Ensure the bobbin thread is mounted on correctly and using your right hand turn the gear that makes the needle go up and down until it catches the thread.
Apr 08, 2010 | Necchi 3102 Mechanical Sewing Machine
Cant get machine out of neutral after threading the bobbin
there should be a way to disengage the bobbin winder. I had a machine that had a switch in the center of the handwheel and even though it would be in the off position I still had to turn the handwheel till it clicked.
Dec 15, 2008 | Necchi 3537 Mechanical Sewing Machine
Necchi 3102 Mechanical Sewing Machine Logo
203 people viewed this question
Top Necchi Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Derek Massey
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
