Question about Kenwood KDC-MP235 CD Player
Display on a Kenwood KDC-MP532U radio
The display on our car radio one day didn't show up. We thought the display was dead, but sometimes when you get in to drive it lights up just fine. It just seems to depend on the day. Nothing else seems to be effected, just the display. Is this a common problem? Any thoughts?
  • 1 more comment
  • ALMIR1977 Apr 08, 2008
    KDC-MP532U DISPLAY IS NOT WORKING (RADIO WORKS BUT DISPLAY IS BLANK)
  • moely Jun 01, 2008
    My kenwood kdc-mp532u radio don't work that I just brough 30th of May 08.Maybe because I am in Germany maybe the frequency is differant Idon't know.I need the radio to play.
  • wendiyking Jun 12, 2008
    I had the same problem that started happening this week... let me know if you figure it out. wendiyking@gmail.com
  • 73 Answers
Not grounded well at all ground it man form main bolt on back to car chisis bet wont happen again
Posted on Mar 14, 2008
Replaced truck battery---now faceplate will not display
you could have blow a fuse on radio or in fuse panel. check fuse panel in your car or truck for a radio fuse to see if it is blown .
this is what it sounds like to me you blew the factory fuse use a digital volt meter to see by chance to see if you get 12 volts on both side of radio fuse when ignition is on ....
http://www.tintingbyfredjohnson.com
Dec 28, 2010 | Kenwood KDC-MP532U
Hi, my battery went dead, after boosting it my radio needs the code, it has been 3 years since I put it in and I don't remember it can anyone help me with this??? It's a Kenwood KDC-MP532u
If you have never set the code - try KCAR or 1111 as a factory default
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 30, 2009 | Kenwood KDC-MP528 CD Player
I have a Kenwood KDC MP532U. The face plate will not display.
it more than likely has bad solder connections inside the radio on some surface mount resistors usually located on the right front of the radio as it faces you.
Sep 16, 2009 | Car Audio & Video
Security code?
you cant you have to call kenwood with your serial and model number and where you purchased it from they prob charge you $25
Jan 06, 2009 | Kenwood KDC-MP532U
Kenwood kdc-mp532u Auxiliary?
http://inform3.kenwoodusa.com/manuals/KDCX590.pdf - Manual
iPod Adapter Compatible: Using the KCA-iP500 iPod Control Interface, you can connect your Apple iPod digital music player to this receiver. The interface (item # 113IP500) plugs into the receiver's 13-pin CD changer input and controls the iPod through the receiver's controls, as well as displays the iPod's text information right on the receiver's display.
Dec 30, 2008 | Kenwood KDC-MP532U
KDC-MP532U (Lost ESN # ??)
That will be a problem with the XM box you connected to it, call xm see if thay can help, the radio is just liike a screen for the XM nothing more the box controlls all of it.
Don
Jul 09, 2008 | Kenwood KDC-X590 CD Player
Display on Kenwood Out
I am not sure exactly what solution you are reffering to, but the KDC-MP532U has a problem with the display going out that is the result of heat stressed solder on the main board. The surface mount resistors that are located on the right side near the front of the unit, as you look into it with the display facing you, are the culprits. This is common in about 3 or 4 Kenwood models. These surface mount resistors are on the top of the board, so the board doesn't need to be taken out to fix it. Just the CD mech does. The surface mount resistors just need the solder reflowed, an easy enough job if you know how to solder. They are all lined up connected to each other, I don't remember the reference numbers, but if you can recognize what a surface mount resistor looks like, you should be able to find them very easy.
Thanks for the compliment on the other post, it is appreciated. A good rating would also be appreciated.
Thanks and good luck,
Dave
Jun 30, 2008 | Kenwood KDC-X590 CD Player
Kdc mp532u
Hello, I have kenwood kdc-mp535u with the word protect in the display….I do not have the code nor the control, that I can do?
May 10, 2008 | Kenwood KDC-MP535U CD Player
No display on my kenwood kdc-mp532u
I read up on this and saw Tech48's post related to a different model. He's the one who deserves the credit. I'm just the rookie who has the soldering iron. However, here's a picture of the 5 resistors that you need to reflow and "top up"
My model is the KDC-MP532U (same as the 532, but with the USB option).
Here's the overall view. The CD-Player is standing on its edge at the bottom. The resistors are on the bottom right by the brass screw post.
...and here's a close up of the board and the resistors....
Hope it helps. Thanks Tech48!!!! It's like I've got a new stereo!!
Apr 29, 2008 | Kenwood DPX-4030 CD / Cassette Player
Kenwood KDC-MP235 CD Player Logo
306 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
