I have a 2000 Plym Neon just bought the radio I have the correct mounting kit and what I thought was the aftermarket wire config. It isnt correct and doesnt fit the back of the radio. Does anyone know which connection kit to buy? Thanks
D
What kind of radio did you get-if it is a new aftermarket radio it would come with a plug that you must wire to the aftermarket wiring harness you bought then if you got the correct harness it should plug into the Car- Metra has the correct harness it is part #70-1770
Radio, aftermarket radio kit(used to mount the radio), and an aftermarket wire plug. This plugs into the radio and your existing harness. Otherwise you have to cut and splice wires. I use a volt /ohm meter to cut and splice.
It appears to be that the radio clock display has malfunctioned, and is due for a replacement radio, which could be an aftermarket or oem radio, maybe found at a junk yard.
Tools required for oem replacement radio, torx keys set.
Before working on the radio or other electronics, disconnect the battery cables with 8mm wrench.
Replacing the oem radio is much easier, if you obtain oem radio, compared to aftermarket radio, due to being direct fit.
The radio is same for 1995 to 1999 Pontiac Sunfire and the Chevy Cavalier, regardless of sub models, such as SE,GT, VL,VLX,Z24. etc.
Parts needed for the the aftermarket radio install :Stereo assembly, stereo wiring harness adapter, radio antenna adapter, and dash install kit.wiring diagram for the wire colors / functions, along with tools, such as torx key set, screwdrivers,wire crimper, wire stripper, double ended wiring connectors, hair dryer.
The oem stereo removal video is for the 2000 to 2005 Sunfire / Cavalier, but are the same or very similar procedures.
THIS IS A COPY OF A POST I SUBMITTED TO SOMEONE WHO HAD A SIMULAR QUESTION REGARDING AN ALPINE BRAND RADIO ISTTALLATION. THE PROCESS IS THE SAME NO MATTER WHAT BRAND THE AFTERMARKET RADIO IS.
Go to the store and buy a mounting kit and wiring harness adapter that are for your car. There are alot to choose from and most are universal and come with instructions. You can get these at wal-mart or best buy. The mounting kit is meant to fill in the empty space left by the new aftermarket radio (your alpine). The alpine will have a metal sleeve around it. take this off and put it in the mounting bracket so it is flush. The sleeve will have little triangle shaped tabs on it. Bend these out so the sleeve cant fall out of the bracket or someone will be able to pull out your radio. Remove your stock radio by pulling off the trim around the radio. This is held on by clips, so be careful. There will be a couple of screws holding in the radio. Remove these and pull the radio out. Behind the radio there will be 1 or 2 wiring harnesses plugged into the radio. Unplug these. Then attach the wiring harness adapters you bought. These plug into the stock harness and have wires at the other end that are labeled. Wire the alpine wiring harness into the harness adapters that you plugged into the stock harness. If you want to you can unplug the harness from the alpine and wire it to the harness adapter before plugging it into the stock harness. The wiring diagram should be on the radio. If not the colors are pretty common. RED = SWITCHED PWR LEAD (IGNITION) ORANGE = ILLUMINATION BLACK = GND YELLOW = BATTERY LEAD GREY = FNT SPKR RIGHT(+) GREY/BLACK STRIPE = FNT SPKR RIGHT(-) WHITE = FNT SPKR LEFT (+) WHITE/BLACK STRIPE = FNT SPKR LEFT (-) VIOLET = REAR SPKR RIGHT (+) VIOLET/BLACK STRIPE = REAR SPKR RIGHT (-) GREEN = REAR SPKR LEFT (+) GREEN/BLACK STRIPE = REAR SPKR LEFT (-) BLUE = PWR ANTENNA LEAD BLUE/WHITE STRIPE = REMOTE TURN ON LEAD(FOR SUBWOOFER AMPLIFIER) There may be RCA jack inputs in the back and these are for the subwoofer amp. There will be a large black cable in the back and this is the antenna wire. Plug in the antenna wire from the back of the stock radio here. Yu may or may not need an adapter for this depending on the size difference between the wire and the hole it plugs into. **Please note: if your car has a "premium" sound system that comes stock with an amplifier you will need to attach the power antenna lead from the alpine to the remote turn on lead on the harness adapter. If not when you turn on the radio/cd it will not turn on the stock amplifier and the speakers will not work. I found this out with my 99 dodge avenger which has an Infinity stock radio. You can pop the trunk and look up at the back dash and see the small amplifier. Once the radio is wired and the mounting bracket is installed, connect the harness adapter as well as the antenna wire. The new wiring harness adapter makes the wiring a little longer so you may have to stuff them back a little bit. Connect the harness from the alpine back into the back of the radio and slide the head unit into the metal sleeve until you hear a click. Before sucuring the mounting bracket and putting the trim back on it is a good idae to try the radio out so if there is something wrong you dont have to disassemble it again. When you buy the harness and bracket it will say on the packaging "nissan 84-94" or "Honda 83-99" or something similar. Look on the back for a complete list of compatable models
BLACK = GND
Once the radio is wired and the mounting bracket is installed, connect the harness adapter as well as the antenna wire. The new wiring harness adapter makes the wiring a little longer so you may have to stuff them back a little bit. Connect the harness from the alpine back into the back of the radio and slide the head unit into the metal sleeve until you hear a click. Before sucuring the mounting bracket and putting the trim back on it is a good idae to try the radio out so if there is something wrong you dont have to disassemble it again. When you buy the harness and bracket it will say on the packaging "nissan 84-94" or "Honda 83-99" or something similar. Look on the back for a complete list of compatable models.
you need to get the adapter from best buy for about 20 bucks... then find the correct wire code for you head unit and splice into these wires with the "RCA line out adapter" i will be happy to assist you more if you can provide more detail
Get a wiring harness adapter kit (about $10) from a stereo shop. It has harness plugs that will plug directly into your harnesses in the dash, and has color-coded wires that you will color-match to the wires on the aftermarket deck's harness. You may need an antenna adapter as well. If your stock stereo face is taller than the aftermarket one, you'll need a dashboard adapter kit to take up the extra space.
Sounds like an internal problem with the radio. There are places that repair factor radios, but for the money, you are better off buying an aftermarket radio. There is a company called Scoche (spelling) that sells a good line of wiring adapters and mounts for aftermarket radios so you can install them yourself. You can get a good radio (some with the new HD radio) and CD player for under $150. The mount kits run about $15 and the wiring harness runs about $10....all abailable at Best Buy or Wal Mart
