Question about Logitech SoundMan X2 Computer Speakers
Onboard Sound Problem
This is rare case as i was looking for post throughout d net. this is an issue on "speaker jack" failure. this is exactly the problem i have right now. those who have d same problem, pls follow up. this is the case.. when i plug d my speaker to the "speaker out" jack, it only produce sound on single speaker. pulling the plug halfway out temporarily correct problem. this is not a problem on driver, etc... this is my main concern, is it safe if i remove the onboard audio ports and replace one from another motherboard? i know its not easy, i thinkin of taking the risk.
  • totolits Mar 14, 2008
    as ive said, its not a problem with driver, etc.(wires,speakers,jack). i already tested amplifier((sound system), headfons, desktop speakers. came same result. its on the "contacts". one thing i really dont understand is when i remove the wires from front audio, no sound at all. strange right? i know it is better to buy separate card. "for the record", ill give it a try, its an old board anyway. ill kip u posted for the result. :P
    Problem Solver:
  • 9 Answers
No you will run into alot of problems and you will destroy *********** board.My advice is that you get a different set of speakers that have a pin with suited size for your sound card.
the problem is that the pin of your current speakers is too long for the jack and as a result only contacts for one speaker are fully connected.
Your sound card has no problem,but if you realy want these speakers just buy another sound card and install it and hopefully it will work.
DONT REMOVE YOUR SOUND PORT
it is very risky
Posted on Mar 14, 2008
OptiPlex 780 has weak volume
Typically, PC sound chips, especially those integrated on the motherboard, are relatively low power-out devices. You can use headphones with them usually fairly well, but to really generate any sound quality and/or volume, you need a set of amplified speakers to accompany it. That said, if you are using the proper delivery equipment, and you know there are no issue with the speakers, low volume then does become an issue. You have few options if the sound chip on your motherboard is going south. You can buy another PC (not cost effective usually), or you can buy a replacement sound card to install in the device. You must be sure that you get one that works in your machine. Many Dell machines use low-profile cards so a full-height one may not work. Also, ensure that that if you get a PCI sound card that there is an available PCI slot for it. You may , in some cases, have a free PCIe x1 slot. They make sound cards that fit those as well. Once you get the new card, you will need to go to the setup menu (CMOS), and disable the onboard sound. After installing the new card, then load the drivers for it. Ensure you connect your front panel jacks cable to the sound card if the card supports it, otherwise you may lose the use of the front panel sound jacks. Lastly make sure to transfer the speaker connections from the motherboard jacks to the sound card jacks.
Nov 05, 2016 | Computers & Internet
My new Vidwo carde disabled my PC sound jack, but I have audio from my USB headset. How do I get my audio jack and external speakers to work.
Find and Try reinstalling Driver for onboard audio look in device manager and see if there is an exclamation mark next to your sound hardware, also there maybe an audio out jack on your vid card that has priority over your onboard since its hd
Jun 19, 2012 | Compaq Computers & Internet
My speakers sounded distorted, so I thought that perhaps my kids had turned the volume too high and blew them out, So I just bought new speakers and they're exactly the same. Sounds tinny. Is this a...
could be a driver issue, but I'm inclined to suspect damaged sound chip. I would personally install a separate sound card, in most cases, better quality sound anyway
Jul 18, 2011 | Audio Players & Recorders
How to use speaker in computer?
Does your motherboard has an onboard sound card? If it has then read your motherboard manual especially the audio section of the manual where the topic is described how and where to plug in which audio jacks coming out from you speakers (speaker system) to which part of the external audio ports usually located at the rear end of your computer case. You need to install the sound card drivers to activate audio properties of your computer of course, to actually use the speakers.
You can also use the front panel audio port of your computer case where you can connect your speakers to as well.
In case your motherboard did not come up with sound card installed you can always install an external sound card and then connect the speakers to the proper external audio ports of the card. Just read your motherboard or sound card manual. It is all there.
Jun 03, 2011 | Audio Players & Recorders
Is there a replaceable sound card or is it intergrated into the mobo? My connector in the headphone jack is broken and my notebook always says there are headphones in. Now, the onboard speaker will not...
Hello bp-pro,
Unfortunately there is no separate sound card for notbooks and it is on board itself.
Local repiaring guys can make it for you and the issue will be resolved.
Thanks
Jun 25, 2010 | ASUS G51JXA1 PC Notebook
How to connect a microphone to Logictech z-340 ?
Hi there and happy new Year , Your Microphone has to be connect to your PC in the Red or Orange Color COded Jack Input , it cannot connect too your Speaker System ...
Hope this helped bud
Dec 26, 2009 | Logitech Z-340 Computer Speakers
Bad front audio jack
In most cases the front jacks are in addition to the rear ones. It's not an either/or situation. If the speakers are connected to the rear jacks (usually green for speakers and pink for mic) and there is no sound, you might have a problem with the onboard sound. Try connecting to the rear jacks with a good set of speakers and try it out. If this doesn't work then we can go from there.
Dec 29, 2008 | E-Machines W3107 (RBW3107) PC Desktop
Sound not working properly
Hi ragnar590,
Please go over pages 5-12 to 5-17 in your manual.
Allow Realtek's auto jack-sensing software to detect your sound jack. If this software is not installed, install it. (Double check your speaker system by plugging into another PC). If after doing all this & you still have intermittent sound, either the jack coming off the board is bad or the onboard sound chip is bad. The Asus P5ND2-SLI was made in 2005 & is no longer in warranty. You can also try setting up the front panel audio coming off the board if your case has front or side audio/mic jacks. See page 2-31 in your manual.
It this options works than the problem is with the rear sound jack.
If this does not give you sound than the audio chip is the problem. Suggest you buy a PCI sound card & disable the onboard ALC850 within the bios.
Good luck ragnar590!
Mike
Dec 11, 2008 | ASUS P5ND2-SLI (890552603831) Motherboard
No Sound
it may look fine, but i think there is some trouble with the installation of motherboard on the new case take a review on it.
it happened to me before.I just reinstall it to the new nase and chechk for any lose connection or any busted chips. in that case try some new motherboard
Apr 07, 2008 | ASUS P4C800 Deluxe Motherboard
Sound output is veryless in msi pvpm4 motherboard
Hi, having used MSI boards myself I found their website very useful. Open your case, locate and right down your board serial number and revision number, Logon to the website [Google MSI] go to downloads. and locate the latest audio drivers for your board. This should fix the problem, if not then you have a failure on the onboard sound. At boot up go to bios and disable onboard sound. Install a PCI sound card with drivers and that will then give you sound again. Regards mistyman
Aug 27, 2007 | Computers & Internet
Logitech SoundMan X2 Computer Speakers Logo
117 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
