Question about Pioneer DEH-1600 CD Player
Amp cd proble3m
I cant get my amp to turn off when the deck turns off even tho i have a remote wire hooked to the blue and white wire at the back of my deck how do i get my amp to turn off?
I'm not entirely sure but i think that your only supposed to have the blue remote wire hooked up. but like i said i'm not sure. i hooked my amp up and somehow my remote wire shorted and fried my ignition switch so don't hold me to it, but maybe look into it. I think that you might have a constand power hooked up to a switched power cable for your amp so haveing the constant power to your amp, asied from your 12v at the battery, your amp might not even know when your car is on or off. hope this helps sorry for the open ender
Posted on May 26, 2008
I dont know how too hook up a remote wire for a amp for subs
there is a blue wire on back of deck with white stripe thst is the remote hook a wire to that and run to amp plug in to remote on amp and there you go i hope this helps you
Jul 10, 2011 | Pioneer DEH-P700BT Car CD Player
I'm looking for the remote wire on the back of the radio, it says there is a blue and white wire.... It's not there! How do I hook my amp up? I ran my remote wire, but there is no wire in the back of the...
It might be solid blue.All you need is a low ampere power supply that will turn on/off with the deck itself or the car in general.you can run your remote lead to the fusebox and tie it in on the radio fuse and when the car turns on so does the amp-and vice versa. Or just find the power antenna wire on the back of the deck-it does the same thing when the deck is on it sends juice telling the antenna to stay up. hope that helps
Dec 11, 2010 | JVC KD-G310 CD Player
Cd player plays, but no sound comes out of speakers.
Look at the enwood. I bet you have the remote wire hooked to the blue wire insted of the blue/white wire. The blue wire goes dad when you play a cd as it is for a power antenna. The blue/white wire is your amp turn on.
Now, if you do not have a blue/whie and only blue, then obviously that circuit in the radio is bad in whch case your only other option s are either connecting it to an accesory fuse or using a toggle switch connected to power.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Kenwood KDC-MP228 CD Player
Sony output problem
All i did was mess with the REM wire, and found out i had to hook the REM wire to the blue/white wire on the deck. Instead of the blue/white wire, i had it hooked up to the solid blue wire on the deck which was preventing my amp from playing on CD.
Nov 22, 2008 | Sony TA-E9000ES Amplifier
I cant get my subwoofer system to work
Do you use a amplifier to power the subs? If so, the amp needs a signal to turn on. This is supplied by the blue/white wire labeled 'system remote' in pioneer radio's.
Search for the next term on this site for more information about this wire:
Remote turn-on in car amplifiers is obligatory?
Sep 13, 2008 | Pioneer DEH-P4100
Amp connection
The only amp wires that connect to the Head Unit are:
Amplifier remote turn on wire to Blue/white at radio
and RCA audio cords to SUB or REAR output RCA jacks.
Aug 04, 2008 | Pioneer 50W x 4 MOSFET Apple iPod...
How connect amplifire ??
You hook the amp up to the deck with rca cables red and white. you have output rca on the back of the deck also the blue wire labled remote also goes to the amp to turn it on and off.
Jul 19, 2008 | Blaupunkt London MP37 CD Player
No sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Sep 02, 2007 | Alpine CDA-9827 CD Player
No Subs in CD mode??
Ah, common problem. You hooked up the remote turn on wire for the amp to the power antenna wire (solid blue). Hook up the remote turn on wire for the amp to the blue wire with white stripe. The power antenna only provides power when the deck is in tuner mode for the power antenna to be extended, intuitively, and cuts power in any other mode, because certainly it's only needed for AM/FM reception.
Sep 28, 2006 | Sony CDX-M8815X CD/Receiver/MP3 System
Pioneer DEH-1600 CD Player Logo
88 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
