Question about Kenmore 46462 Front Load Washer
Replace shock Hi, We have a 2 years old Kenmore HE2 (46462). I think the shocks are goner. The spin cycle shakes really bad. How easy is it to replace the shocks? Do I need to remove the drum and rest of the other stuffs to replace 3 shocks on the bottom of the washer? Also, do I need any special tool to uncompress the shocks? Thanks, jeio
  • jeio Mar 14, 2008
    Do you know if I can jack up the drum or hang it from the top then replace the shocks?
    Or do I need to remove everything?
  • Anonymous May 11, 2009
    How to remove plastic pins on shocks on kenmore front load washer to replace shocks
    President:
  • Kenmore Master
  • 2,651 Answers
No special tools are required. also remove the top of washer and check the 2 springs that are holding from above,as faar as acessing the should have a removable back panel, sometimes an opening on bottom of machine
Posted on Mar 14, 2008
  • Ron Coons
    Ron Coons Mar 15, 2008
    shouldn't have to lift up much, but if nessecary thinknin jackin from underneath easier then trying to hang the drum
SOURCE:
My 7 year old he3 has a terible thumping noise when in the very fast spin cycle it is like the tub is coming out. The spin cycle before last is not as bad. the shock absorber are ok I can take the front of...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 11, 2011 | Kenmore HE2 Plus Front Load Washer
Loud shaking in the spin cycle
Washer Problems
heatman101
Jan 19, 2011 | Kenmore HE2 Plus Front Load Washer
Washing machine shakes excessivley and the washing cycles are stopping mid use.
Washer Problems Washer noise when spinning
heatman101
Jan 06, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washing machines knocks
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 25, 2010 | Kenmore HE2 Plus Front Load Washer
Front loading machine shakes violently during spin
heatman101
May 14, 2010 | Washing Machines
Shakes violently during spin cycle from back to
I had this problem with my front loader as well. It is probably the mounts or "level shocks" on the bottom of the unit under the tub. I have a Kenmore by Frigidaire and had to replace the "level shocks". I only paid about $43.00 and was not that hard to put on. Look under your machine and see if the shocks are connected to the tub. Check under the top panel also to see if that particular model has mounts up there too.
Mar 12, 2010 | Maytag NFW7200TW Front Load Washer
Loud noise kenmore washer
  • Hi,
  • try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 22, 2009 | Kenmore Washing Machines
Kenmore front loader washer squeaks in washer mode and shakes in spin.
shocks made of plastic squeaks, a little greese may help
Nov 08, 2008 | Washing Machines
Kenmore washing machine shakes when spinning out
our's did this, it shook horribly. it turns out one (or more) of the shocks had come out and the technician had to come out and replace the shocks.
Nov 03, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 46462 Front Load Washer Logo
223 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
