Question about Samsung Propel A767 Cell Phone
Can you save a text template to be put on your texts every time
Can you save a text template to be put on your text massages every time
    President:
  • 1,738 Answers
Using Message Templates on the Propel A767
Your phone has Text and Multimedia message templates that you
can retrieve and apply when creating a message. You can change the applied template as needed before sending a
message.
1. In Idle mode, press the Menu soft key, then select
Messaging ? Templates.
2. Select a template type (Text Templates or Multimedia Message Templates).
3. Highlight a current template message and press the Options soft key to access the following options:
• Send: allows you to create and send a message using the selected template.
_________________________________
• Add New: allows you to add a new template to the list.
• Edit: allows you to change the currently selected template.
• Insert to Message: opens a new message using the template.
• Delete: deletes the currently selected template.
When finished press the Power On/Off/Menu Exit key:( Ends a call or exits a program.)
Posted on Mar 28, 2010
  • 58 Answers
Yes, it is actually called a signature. Go to your message settings and you should see signature option, select that and then add the text you want to be on your messages. But make sure that your signature is turned ON in your message settings. Hope this helps!
SOURCE:
How do I set up an out of office message in Outlook 2010?
You can create part-time or temporary 'Out of Office' automated replies in Microsoft Outlook. These can be set so that whenever you leave the office, an auto reply is sent.
This is useful if you have a high volume of e-mail messages and are expected to reply to them quickly.
You can fully customize your auto reply in Microsoft Outlook 2010.
Launch Microsoft Outlook from the Start Menu.
Click "New E-mail." Click "Plain Text."
Enter the message for your out-of-office reply in the main body of the text.
Click "File," then "Save As." Click the "Save as type" list and select "Outlook Template." Enter a name such as "out of office" and click "Save."
Click "File," then "Info." Click "Rules and Alerts," then "New Rule."
Click "Start from a blank rule," then "Check messages when they arrive," then "Next." Set "Sent Only to Me" in the conditions list and click "Next."
Select "Reply using a specific template," then choose "Specific template" on the next page as well.
Click "Select a Reply Template." Choose the template you already created and click "Open." Click "Finish," then "OK." All e-mails will now have the out-of-office reply. Disable it in "Rules" to switch it off.
Hope this helps
Oct 26, 2012 | Microsoft Outlook 2010
How do i put a signature on a pantech link
Text message signatures are the post scripts at the end of text messages. Some people use text message signatures to provide an unrelated, off-top status update to the recipients of their text messages. Other people use text message signatures to attach a favorite quote with every outgoing message. If you own Pantech's Link handset, you use the device's messaging templates to attach a signature to your text messages.
steps:
  • Press the right "-" button to access the Link's menu. Use the handset's directional pad to navigate to "Messaging" option in the menu. Press the center of the directional pad, the "OK" button, to select the "Messaging" option.
  • 2
    Select the "Templates" option from the "Messaging" menu, using the directional keypad. Select "Options" from the "Templates" menu, using the left "-" button and then select "Add New."
  • 3
    Key in your text message signature using the Link's QWERTY keypad. Select "Options" with the left "-" and then select "Save" from the "Options" menu.
  • 4
    Press the red "End" button to exit the "Templates" menu. Press the right "-" button to return to the Link's main menu. Select the "Messaging" option from the menu.
  • 5
    Select the "Create Message" option in the "Messaging" menu. Compose your message with the Link's QWERTY keypad.
  • 6
    Select the "Insert" option before sending your text message. Select the "Templates" from the "Insert" menu. Select your text signature from the list of available templates and then select the "Send" option to transmit your text message.
  • Dec 02, 2011 | Pantech Link P7040 Black Rubber Feel Hard...
    How do i set up my signature?
    You cant write a signature but you can save what you want under text templates. Then every time you send a text insert it in there! Hope that helped! I had the same problem!
    Jun 28, 2011 | Samsung Gravity SGH-T459 Cell Phone
    How to add signature on text messages
    There isnt an exact way to add a signature at the end of the txt. In order to do so, you have to create a template with your signature, then insert the template at the end of your txt. However, know that it will count towards the 160 character limit. Instruction from the user manual (pg 38-39) below. Hope it helps!
    Message templates
    When you often use the same phrases, you can save the message under template messages. Adding the message as a template
    1. Press Menu > Messaging > Templates.
    2. Press Options > Add New.
    3. Write the frequently used message > Options > Save.
    Sending a message with template
    2. Select the message to send.
    3. Edit the message > Options > Send.
    note: You can add a template while writing message. Write a message > Options > Add Template. Choose Text or Multimedia and select the message to add.
    Mar 08, 2011 | Pantech Cell Phones
    How do I change the size of the print on the label
    Using the software that came with it modify the font settings.
    Changing the Default Font Settings in DYMO Label Software Answer 299 ' Applies To DYMO ' Published 07/20/2005 10:16 AM EDT ' Updated 08/31/2010 05:05 PM EDTHow do I change the default font settings in the DYMO Label Software (DLS)?
    Font settings can be adjusted for individual label templates and for the DLS application. Please note, changing the font settings for the DLS application will only affect the creation of new label templates. It does not change the font settings of any previously created and saved label templates.
    Changing the Default Font Settings for Individual Label Templates in DLS
    1. Open DLS.
    2. In DLS, click and highlight the text on the label template.
    3. The tool bar above the label template allows you to change various font and justification settings. To change font type and font size you must click on the Font Settings icon: f_f.jpg
    4. Make the necessary changes to the font settings. The Sample field indicates how the text will appear on the label. Please note, the text will automatically shrink to fit if you select a font size that is too large for the address or text object on the label to accommodate.
    5. Click OK after making the necessary changes.
    6. Save the label template. Click on the File menu in DLS and select either Save or Save As. Selecting Save will save the label template with its existing name. Selecting Save As will allow you to enter a new name and create a new label template.
    Mar 01, 2011 | Dymo LetraTag QX50 Thermal Label Printer
    How do you find signature on LG Neon
    you can not find the signature because there is know signature that you can put at the end of messages unless you make a template with your signature and add it to messages or you can save your signature into a draft and make new messages from their
    Nov 24, 2009 | LG Neon GT365 Cell Phone
    I can't figure out how to create a a signature for a text.
    Putting a signature on your text is not an option on this phone. Sorry
    Mar 28, 2009 | Pantech Matrix Cell Phone
    HOW DO I PUT A SIGNATURE AT THE END OF MY TEXT MASSAGES ON MY G1
    You have to download an application called text easy bt that will only give u a signature for every new message. In order to get a signture under your original text message is you have to go into text easy, select the person or perons you want to send a text to ( bt dnt write nothn) Then jus go back and it will be saved in your drafts into the messaging icon
    Mar 25, 2009 | Google Android
    I want to create an excel template that can automatically update the invoice number once i save it. say i have the excel template open with the curent invoice numbe as 5. once i save this file and i open...
    Is it in a single-user environment? You can save the current invoice number to a text file then ope that and +1 (which is the way that the demonstartion Invoice in Excel 97 / 2000 used to do it ).
    Feb 26, 2009 | Microsoft Excel 2000 Step by Step...
    Sentbox
    press options after typing message and select "save and send". that will save your text messages in the sent itmems folder.
    Sep 01, 2007 | Samsung SGH-D900 Cellular Phone
    Samsung Propel A767 Cell Phone Logo
    369 people viewed this question
    Top Samsung Cell Phones Experts
    Felizardo Erilla
    Felizardo Erilla
    Bill Long
    Donni Steen
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
