Question about KitchenAid KBFA20ER Bottom Freezer French Door Refrigerator
No water from dispenser
I verified that water is coming in at the source. When I removed the water line from the back it spit as if pressure was coming from inside the refrigerator - seems like a clog somewhere.
I also replaced the filter thinking that may have been clogged, but that didn't make a difference.
Any help would be appreciated!
    President:
  • KitchenAid Master
  • 2,651 Answers
Remove the crispers, youl find a water tank. chances are its frozen, somtimes thers a fitting right there to disconnect and try. IF not, it discharges from the left side of tank.Hold a hair dryer on that goose neck top portion of tank for a few minutes. water shloud start flowin now. if thats the case:::::
Order and install Water Reservoir Anti-Freeze Kit PN W10177505. Follow the instructions supplied with the kit.
Posted on Mar 14, 2008
6ya staff
SOURCE:
Kenmore washer Top Loading HE Low-water washer 02/28102 4.5o purchased 10/10/14 Does not drain when it gets to the 13 min mark. LF error comes up.
stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
Slow Fill- low water pressure reduces the speed at which water flows into the machine.
Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
Contact the water company to verify the pressure being supplied to the house.
dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
A plumber may need to be consulted if the pressure is found to be too low.
Things you can check
Are the Hot and Cold water faucets turned on
Are the water hoses kinked
Make sure all the hose are straight and able to flow water
Are the screen inside the water valve plugged
Inlet valve should be free of debris and rust.
Turn off water and remove the inlet hoses from washer.
Remove any accumulated film or particles.
Assure rubber washers are in the end of each inlet hose.
Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
Unplug or turn the circuit breaker off for 30 seconds.
Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
Press the Pause/Cancel/Stop button twice to clear the display.
Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts by Manage My Life September 2nd, 2009
Jul 24, 2017 | Kenmore Washing Machines
Spitting sputtering
Your water solenoid is sticking. It is drawing air back through it when off then the pressure of the water is keeping it open. I would replace the solenoid valve.
Apr 14, 2014 | Amana Refrigerators
The washer as a code LF what can I do to fix it or do I need a repair man to come?
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
Thanks for using FixYa!!
Jan 29, 2011 | Kenmore Elite 45986 Front Load Washer
Display LF and the washer is not filling with water, I really hope this doesn't mean the Line is Frozen....
Dec 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport front load doesn't wash and shows code F2O and some times F13
f13 is a Dispenser circuit error
If the dispenser motor is not able to be driven to it's proper position.
Check mechanical linkage from dispenser motor to the top of the dispenser.
Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
Check Dispenser Motor
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch - remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) - with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water runs very slowly from dispenser and i chnaged dual solenoid valve but problem remains
Hi, Check the water pressure to the inlet valve you changed. Remove the water line and put the end in a bucket. Have someone turn the source valve on and see if the pressure to the inlet valve is strong enough. When the water is on, there should be enough pressure to force the line out of the bucket. Sometimes the source valve gets plugged with rust or lime. You might have to sht the water off to the house and clean the source valve port.
If the pressure seem to be ok, there might be a need to change the filter (costly so be sure the filter needs changed) or check the hose end inside the dispenser and se if it is plugged at all.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 10, 2009 | Jenn-Air JSD2690HE Side by Side...
Kenmore elite front load washer has LF error message
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
Jenn Air fridge water dispensor stopped working
Hi: You press the switch and it makes a faint humming noise. That tells me the switch on the front panel is ok. The switch for the ice and water is actually on the bottom of the ref. The internal system of the ref is not under city water pressure. Ice is made so that's ok. There is a solenoid where the water attaches to the fridge down below which can fail. Just for giggles try tapping the switch with the plastic handle of a screwdriver. To loosen any scale that might have built up. As I'm unemployed also I'm giving you that trick. Otherwise I would just say replace it. I hope this helps, Jeff
Jun 09, 2009 | Jenn-Air JBR2088HES Stainless Steel Bottom...
JCD2389GES water dispenser over-runs and also starts on own
Low water pressure can be very problematic when it comes to icemaker/water dispenser water inlet valves. If there is low water pressure to the valve, the valve may not seat correctly causing icemaker fill tubes to freeze, icemakers to over/under fill or water dispensers to leak or not shut off fast enough. Check the water pressure to the valve like this:
Turn off the water supply to the refrigerator and remove the water supply line from the water inlet valve behind the refrigerator.
Put the end of the water line in a bucket and turn the water supply on. There should be a good stream of water jetting from the tube. If there is not, the water supply shut off valve is probably plugged and needs to be replaced or there could be an in-line water filter that needs to be replaced. Only use a drill style (non-self piercing) saddle valve http://www.repairclinic.com/SSPartDetail.aspx?s=t-584723-%3d%3di584723&PartID=584723 for the water supply.
If there is a good stream, the water inlet valve that the water line connects to at the back of the refrigerator should be replaced.
*Note: Reverse Osmosis (R/O) systems should never be used to supply water to icemakers.
TheRepairGuru --- www.repairclinic.com
Jan 27, 2009 | Jenn-Air JCD2389G Side by Side...
Have a samsung American style fridge/freezer with water and ice dispenser. Water gets to the water dispenser but not to the ice cube maker. can not see anyway of getting to the pipe inside the...
verify on the back side of fridge sometimes you will see the water lines if not there's like a a cover that goes vertically if removed, probably you'll have access to water line its probably plugged up...
or sometimes air gets trapped in the supply line to purge just simply loosen the nut or fitting it should spit some water do this just enough to let air out about after 30 sec. if there was some air in the water line i should start to spit water...
hope i could be of help
Apr 13, 2008 | Refrigerators
KitchenAid KBFA20ER Bottom Freezer French Door Refrigerator Logo
160 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
