Question about Maytag Neptune MAH5500B Front Load Washer
Nd error essage
Our neptune washing machine displays a nd error message after cycling for several minutes. washer does not drain and makes a loud buzzing noise as it cycles. any help would be appreciated.
  • Anonymous Mar 29, 2014
    The message comes up - 'motor was not working etc' and then the message 'speed indicator error'. Thank you!
    President:
  • Maytag Master
  • 2,651 Answers
Nd= no drain. loud buzzing noise sounds like something stuck in pump assy.remove the door(2screws) adn other 2 screws oppisite side, and hte front panel comes off giving you acess to the drain pump, pull the hoses and look for the obstruction
Posted on Mar 14, 2008
How can you reset the suds error code message on a may tag Neptune washer?
Try running a load without adding anymore additional soap and see if you can get it to go through the cycle, you may have to try it several times. I would also suggest cutting the amount of soap down to help prevent this in the future.
Jun 23, 2015 | Maytag MAH6700AWW Neptune Front-Load...
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
My washing machine is displaying the letters "nd",
ND is no drain error code for the FAV6800A and most Maytag machines.
Is there water in the Wash Basket. If not this could be a stuck Pressure Switch. If there is water in the Wash Basket then there could be a Drain Pump issue/Drain Line clog.
If you want to DIY I can help you.
Feb 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Has 33 minutes and a error message of nd--maytag Neptune tl
What is the Model number of your machine if its a FAV6800A or FAV9800A please read on.
The ND error code means No Drain.
You could have a drain line clog or a stuck Pressure Switch contacts.
See this post for past troubleshooting;
http://www.fixya.com/support/t2209123-code_nd_fav6800aww_serial_number_10
There are links to the Service Manual and I go over how to put the machine in Service Mode to check that the Pressure Switch is signaling properly.
Do you want to DIY the repair?
Let me know.........Rich
May 19, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Nd in the display
nd stands for no drain check for a restriction in your drain line and in your pump assembly
May 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Stops mid-cycle, does not drain, displays nd error code?
Hello.
That code is telling you that the unit is draining to slow. After 15 minutes it is not below the low water level and will not spin out. The best repair for this is to replaced the pump on your unit.
Jul 15, 2009 | Maytag Neptune MAH9700 Front Load Washer
What does the code ND mean?
ND - No Drain
Machine control board monitors water level in washer during and at the end of pump out. If wash level does not reset pressure switch, it will see water left in the washer.
1.Check for pump/drain restriction.
2.Check pump operation.
3.Check pressure switch for open contacts.
4.Check inputs and outputs at machine control board.
5.Replace responsible component.
Apr 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
804 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
