Sansa e280R Software
I have the Sansa e280R MP3 player that I found stuck in the seat of a plane (!). Really!!! Now, I'd like to get the CD with the proper software/driver and install it on my laptop. Help!
  • ayalchrist Sep 08, 2008
    I have sansa e280R.when i inserted amemo card into it,the whole musics became blured & got stucked. now it doesn't take any file yet i'm listening by useing memo card with my sansa.Is there a software repair or any way to resolve/
SOURCE:
  • 133 Answers
SOURCE: Refresh Database
This is happening alot aparently, Sandisk is telling everyone to just reset it but that aparently isnt really working. only suggestion is to set the USB mode to MTP and try it.
Posted on Aug 02, 2007
mixmaster
  • 626 Answers
SOURCE: How to download the software of SanDisk Sansa m240 MP3
You dont need any specific drivers. As long as you have Windows XP / SP2 and Windows Media Player 10 or higher. The drivers are part of these required components. Best of Luck.
Posted on Sep 06, 2007
  • 10 Answers
SOURCE: Sansa e280r "not enough space for music db. please free 6mb."
RECOVERY MODE
Switch your Sansa E260 to its Recovery Mode:
1. Make sure the player is powered off
2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface
3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button.
4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode"
5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above)
6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6.
Next, Apply the firmware for the E260 (your player should be connected to your PC at this time):
Step 1:
Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop":
http://www.sandisk.com/Assets/File/Downl...
Step 2:
Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the player to keep resetting.
Step 3:
When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch
Step 4:
Power up your E260 and 90-99% of the time, it would boot up successfully. If not, try to repeat steps 1-4 again.
I hope this helps.
Posted on Dec 01, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: i lost the disk for my sansa c200 1 gb mp3 player
Here is the website:
http://www.sandisk.com/driverdownload/drlogin.asp?driverId=184
Posted on Mar 07, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: I lost my installation cd
Yes - it is available from the Sandisk Website --> Support --> Mp3 players --> Sansa -- > Software & downloads
Posted on Jun 23, 2008
E280R was froozen and is still froozen even with it plugged in pc
i'm sorry to hear that. Now, my friend u may go this site for help:
http://kb.sandisk.com/app/answers/list/
Feb 26, 2010 | SanDisk Sansa E280 MP3 Player
How do i get the videos to play on my sansa e280r
Sansa Video Converter is the first professional Sansa MediaConverter software. It will help you to convert video and audio filesto Sandisk Sansa compatible format, including MP4, MP3, WAV, etc. Itaccepts a wide range of video formats - 3GPP, 3GPP2, ASF, AVI, DAT(VCD), DivX, MOV, MP4, MPEG-1, WMV and Xvid, and output to Quicktimemovie supported by Sansa.
Dec 09, 2009 | SanDisk Sansa E280 MP3 Player
I have a SanDisk Sansa model e280r that has frozen. Music was put on there and then it was disconnected from the computer. The player began to refresh and has now stuck.
if this is happening frequently, then you must connect your mp3 player to the computer, then format it. after formatting, connect it to the computer then transfer all the songs. this should fix your problem.
Oct 29, 2009 | SanDisk Sansa E280 MP3 Player
How can you tell if it is a version 1 or 2?
Sansa e200 series has 3 not interchangeable versions of firmware:
  • version 1: e200, firmware starts with v1.xx.xxx
  • version 2: e200v2, firmware starts with v3.xx.xxx
  • version rhapsody: e200r, firmware starts with v1.xx.xxx
Site for the difference between these versions:
http://kb.sandisk.com/app/answers/detail/a_id/193
The exact type should be on the back of the player: model e280R.
For the rhapsody there is only 1 firmware available.
The zip file can be downloaded here:
http://mp3support.sandisk.com/firmware/rhapsody-1.0.2.165.zip
When another firmware is needed, go to the download firmware wizard on next page and select your model:
http://www.sandisk.com/sandisk-support/driver-download-wizard.aspx
Sep 25, 2009 | SanDisk Sansa E280 MP3 Player
Sansa e280r wont connect with laptop
On your Sansa, go to "Settings," then "System Settings," then USB Mode, change the mode to MSC, then try it. If that doesn't work try the other modes just in case.
Hope this helps!
May 06, 2009 | SanDisk Sansa e200 MP3 Player
Load main image failed SunDisk Sansa e280r rhapsody Refurb
load main image failed Switch to recovery mode e260
Aug 05, 2008 | SanDisk Sansa e260 MP3 Player
Can't download files from Overdrive files
Make sure that either your Rhapsody or Overdrive subscription is still good and resync all files in Windows Media Player.
If that fails, you'll have to start from scratch:
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Apr 13, 2008 | SanDisk Sansa E280 MP3 Player
Some songs sound lifeless on my e280r
There are many settings in Windows Media Player for Ripping music. Make sure yours are set to WMA with 192kbps or higher..
Windows Media Player>Tools>Options>Rip Music (Copy CD).
Best of Luck.
Oct 14, 2007 | SanDisk Sansa E280 MP3 Player
Refresh Database
Aug 02, 2007 | SanDisk Sansa e260 MP3 Player
625 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
