Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tv repair rca tv model d52w20 , no power and power lite blinks on and off three times or just no power. The cure book says to check certain caps in power supply, we've done that and hor. out. transistor is ok. What else have you found on these rca's that causes a no power situation. Thanks for any suggestions. Vegitek
  • 3 more comments
  • richard Mar 19, 2008
    I have three flashing lights then shuts off the tv. what do i do?
  • Djj502 Mar 24, 2008
    i have the rca senium 56 inch,and its just turning on and off by it,s self at first i thought it was a ghost but the ghost said he wasnt doing it.So now its just on for 30 seconds and then off.
  • J Holley Mar 27, 2008
    The set will have a blinking green light when turning on and then shuts off. If you warm the insides using a hair drier on the hottest setting, it will evenutally come on with horizontal banding from left to right which goes away after a few seconds. Now the banding occurs at certain times when the display shows dark scenes. We leave the set on all the time now. I suspect a capacitor or resister changing value. I don't have a manual. Has anyone found a solution. Thank you.
  • realmouse Mar 29, 2008
    the three previous responders described it well enough, but the solution is a little too coded... any chance we could get a better description for where these items are in the set, and a little more clarity on what to do. (not a tv repair tech, just an electronics nerd... usually computer perifs. so i don't speak the lingo)
  • ccso6 Apr 03, 2008
    same problem light blinks three times but set doesnt come on. Tried holding power button down and got a single blink followed by nine blinks but set still doesnt come on????????
  • RCA Master
  • 8,617 Answers
HV splitter and flyback are common failure items. Remove the HV lead from the HV splitter that comes from the flyback, Place that into a dry glass jar secured so it doesnt come out. Then try powering up the set if the set powers up without shutting down the splitter is bad.
Posted on Mar 14, 2008
  • martin Nov 02, 2012
    what if the tv set turns off, when testing the flyback, what to check next?
SOURCE:
Describe your D52W20 52 in. Rear Projection HDTV-Ready Television Problem the tv will not turn on the power light will blink three times then shut off
That could be caused by the CP150, CP120 and CP114 capacitors on the deflection board. Very famous issue. You can get the RCA repair kit by that same name from www.tvrepairworld.com which has the capacitors and the CD with repair instructions
Aug 27, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA D52W20 --> turns on sometimes, when it does, it blinks once, slow, and then after the 1 slow blink, blinks 9 times fast. now, i dont know whats wrong but sometimes the tv wont even blink to show...
Sounds like the Flyback needs resoldering then replace the Three caps CP150, CP120, and CP114. You can get the repair kit by that same name from www.tvrepairworld.com the kit also contains the CD with instructions.
Mar 28, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 Does not power on- what to check for?
Hi, if the capacitor has bulged out then its likely to have taken out a fuse on the board, they are not obvious to find as they surface mount them, they look like resistors, often a white body with a number on it eg, 5 for 5amps. With the power off, check around the componets for open resistance, set your meter at 10 or 100 ohms, analogue meters are better than digital for this analysis. Watch out for capacitance as ther could be several hundred volts stored in the circuit.
Mar 26, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv will not turn on
CK for Bad capacitors on your Deflection Board its the bottom board on left hand side cp150 cp114 cp120/ if (cp150)- 2200uf 16v is puffed up on top It is Bad replace all 3 capacitors 220uf 35v is the other 2.
Jan 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
The power button blinks 3x''s but the TV does not come on at all
This is most likely caused by leaky capacitors in the television. The power supply that feeds the startup voltage to the CCFL tubes usually contain shoddy caps, which in a few years usually bulge and leak. 8 times out of 10 this is the case, look for any bulging caps, and replace them with the same or a higher voltage rating.
Jun 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w20 does not turn on! power lite blinks 3 times and quits
You will meed to replace the Flyback number 259296 and CP150. You can get the parts at the following link and they provide step by step instructions with pictures of how to do the repair.
http://servicemanuals.vstore.ca/
Jun 14, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Jun 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Fixing a tv
57 inch rca....Sounds like you have a itc222 chasis but cant be sure... what is your model of the set. d52w20 maybe.. or something simular.. blinks green 3 times sound familar... get me that model number and we cant start the troubleshooting process
Mar 03, 2008 | Televison & Video
Tv will not turn on
Look on Deflection board 3 capacitors need replacing cp150---cp114----cp120 one is 2200uf 16v Two of them are 220uf 35v. Buy capacitors at Radio SHack. If cp150 is puffed up on top it is bad so replace other 2 caps as well.
Dec 18, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
453 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
