Question about Brother HL-2040 Laser Printer
Brother HL 2040 out of paper light stays on
How do I clean/adjust the sensor? I think I may have jarred it when I made the mistake of pulling paper out during printing- now light stays on & I can't print.
  • 3 Answers
Sounds like it sensed this as a paper jam. If it is your Paper LED that is stuck on:
We have a few of the HL-2070N's and I have seen this issue on a few of them. Usually it indicates one of several instances that can be found on Brothers website in the FAQ's about what does the LED indicate area.
The main solution I have found is that depending on where the paper jammed it has affected the drum/toner cartridge assembly somehow or another.
  • I recommend taking the Toner Cartridge out of the drum unit
  • clean the corona wire by moving the blue tab at the front of the drum unit back and forth several times
  • I have even used can air here to get it even better all around the drum unit not just at the corona wire area
  • After make sure all is clean put all back together
This has cleared up most all of my paper jam LED issues and allowed for further printing.
Posted on Apr 03, 2008
SOURCE:
My printer hl 2040 keeps saying there is no paper but there is enoughin the tray
You have problem with sensor for detecting paper. Try to clean it. Remove paper and put inside again. Possible of restarting of printer can help. Electronic for sensor have wrong information.
Aug 25, 2011 | Brother HL-2040 Laser Printer
All the light flashing
Try this procedure as mentioned.if any mistake in trying the procedure then retry from first step again.so read it carefully and try it. Brother ML-2040 Toner Light Reset
When replacing the toner cartridge in the Brother HL-2040 with a new cartridge (compatible or remanufactured) the user may experience a problem with the toner light staying on, even with the new toner installed. The procedure below has worked for many folks, so give it a shot.
Open the front cover of the Brother HL-2040 and leave open while completing the following steps:
1.) Turn the printer off.
2.) Hold the ‘go’ button while turning the printer on. All panel lights should be on.
3.) Release the ‘go’ button once all lights are off.
4. )Press the ‘go’ button 2 times.
5.) Pause.
6.) Press the ‘go’ button 5 times.
7.) The toner light should be off.
8.) The paper light should be on.
9.) Close cover. The ready light should be the only light on.
Once all steps are successfully completed your “low toner” light should be fixed.
------------- From Brother Service Bulletin
1. Open the Front cover
2. Press and hold the GO button
3. Power ON the printer while continuing to hold the GO button
4. Once the 3 LED’s are lit, release the GO button
5. Press the GO button 2 times. This will cause the LED’s to light solid
6. With the LED’s lit solid, press the GO button 5 times
7. Toner Life End will then reset
8. Close the front cover.
----------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 02, 2010 | Brother HL-2040 Laser Printer
I have a Brother HL-2040. The "paper light is on & won't print.
Sounds like a paper jam. There's a flap at the back of the printer-once open you should be able to see if the paper is stuck there. (Exactly the problem I had yesterday-I didn't spot it at first and it nearly drove me mad! :)
Good luck,
Raf
Nov 13, 2009 | Brother HL-2040 Laser Printer
Same prob as sphil4988 11 Sep09 - RED PAPER LIGHT REMAINS ON EVEN IF NO PAPER JAM, THERE'S PAPER ON TRAY, UNIT IS CLEAN. THANKS FOR YOUR SUPPORT.
Check the Paper Sensor if it is in the Upright position or broken off it will keep asking for paper
check that sensor.
Sep 13, 2009 | Brother HL-2040 Laser Printer
Won't pull paper through. starts to then paper
Just clean up your paper feed tires witch are below the printer. u have to see it when u pull out the paper try!
Jul 14, 2009 | Brother HL-2040 Laser Printer
Brother HL-2040 laser printer
Make sure to clean all the rollers you can see and make sure to check the paper sensor, and clean all rollers and paper paths with some Isopropyl Alcohol (AKA rubbing alcohol)
Sep 04, 2008 | Brother HL-2040 Laser Printer
Flashing paper light after clearance
moz-screenshot-6.jpglet me see i think when you clean the jam you maybe damage the sensor arm or the arm stuck check the sensor carefully also check the front cover switch
Apr 02, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Flashing Paper LED
Try send one paper manually, then it will pick up paper from the try automatically.
Feb 06, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
359 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
