Question about Dell Inspiron 1150 Latitude D600 14.1 LCD Display-LP141X14 CD-ROM Drive
Inspiron 1150 My Dell Inspiron 1150 will not start up windows xp. I get the white bar at the bottom of the screen then after about 15-20 seconds I get this message the divise in the system modular Bay cannot be identified. It may not be inserted or may have some other problem. Also, the dvd light does not shows. Doris
  • tigerjr Apr 06, 2008
    I can turn the laptop on ,but I have no start indicator on left down line.all my desk tops are ther but when I click on it nothing is happening.
    please e-mail me if you have any solution or support
    [email protected]
    thank you
WHAT ABOUT IT SHUTTING DOWN IF YOU MOVE IT OR TAP ON IT? I heard Dell claims it not repairable and what to soak you for another mother board
Posted on May 08, 2008
    Scholar:
  • 94 Answers
Chances are you DVD drive failed - test below will determine if it is the drive or the controller on the motherboard.
Remove DVD/CD ROM
Remove Battery
Remove Harddrive
then...
Try pressing and holding the f12 key when turning on and doing the diagnostic. It may show where the failure is.
Posted on Mar 16, 2008
    Novelist:
  • 104 Answers
Without the windows xp installation cd there is not much you can do, but if you have it... you can do this.
REMEMBER: all this is considering you have a normal computer, with a normal system and your hardware is not damaged.
Your problem is very generic and the information you are providing is very poor...
boot with that installation cd
let windows xp installation start and when it prompts you to choose between installing or repairing by pressing "R" key, choose this second one and wait till the system shows you a black screen with some lines of white text on it.
you will be now able to write on that console DOS like... type this three commands and when the firsts two ask you, choose YES.
1. fixboot
2. fixmbr
3. chkdsk
the last one will check the hd and will tell you if you have problems in that hd... if it shows problems, after this, you should replace HD so...
after that just reboot your system and see if it works...
TIP: BOOT UP WITHOUT ANY THING BUT KEYBOARD AND MOUSE, disconnect printers, scanners, any usb dispositive, just keyboard and mouse...
if not give me more info on this please.
Posted on Mar 15, 2008
SOURCE:
Inspiron 1150 Latitude D600 14.1 LCD Display-LP141X14 CD-ROM Drive: I installed window xp on my DELL inspiron 1150 lap...
you need the drivers...look here...http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
you will need a computer thats online to download them,, put them on cd or flash drive
May 17, 2010 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
After installing XP pro on a Dell Inspiron 1150
Per the manual, the Insp 1150 doesn't have an integrated microphone
Apr 03, 2010 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell inspiron 1150 network cable unpluged.
simple there might be settings problem . go to the network places icon in start bar and do a right click then choose Diagnose and repair..then it will works but if it says that there is a device problem then might be your router is not working correctly
Mar 17, 2010 | Dell Inspiron 1150 Notebook
Windows xp pro hangs during device installation dell inspiron 1150.
comment reboot cd windows pour installe xp2 a mon pc itech
Sep 24, 2009 | Dell Inspiron 1150 Notebook
My dell inspirion screen is blank.... when you start the computer u do see the windows xp but then it goes blank and all u see is the curser?
one possibility is your windows xp might be corrupted. Try formatting your system and install a fresh copy of xp. or there might be a problem with your RAM.
Aug 26, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Inspiron 1150 won't boot up. Makes a
it may come from viruses that attacked your comptr..in start up, pressing F8 to run safe mode n try to scan your compter using good anti virus software
Apr 09, 2009 | Dell Inspiron 1150 Notebook
Have dell inspiron 1150 shows windows did not start properly. went to start up and ran diagnostics, shows error in dst short scan. changed hard drive and reloaded xp with disc. computer loaded fine and...
Dell inspiron has a lot of promlem most are power adapter related ,Check and see if the power port is loose if you have tec savie repair the port .If you dont know how to repair the port your local computer guy will fix it about $100 at most places
Feb 19, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell inspiron 1150 won't turn on
Remove the battery the memory the ac adapter,the hard drive, the cd rom.Press and hold the power button down for twenty seconds.try again if no go you will have to replace the systemboard.
Good luck
Jan 13, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Windows could not start
you can use any xp disk.re install fresh copy not repair.im sure you know someone who could lend you a copy for couple of hours
Feb 20, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Inspiron 1150 Latitude D600 14.1 LCD Display-LP141X14 CD-ROM Drive Logo
159 people viewed this question
Ekse
Clive
Clive
