Question about Mitsubishi HC3000U Multimedia Projector
Mitsu hc3000 problem "red-green status light blinking and no input"
Has been working fine, only 8 months old, was getting lamp warning signal for 2 weeks then above happened, menu shows fine, no input but all cables working......changed bulb......still get lamp warning and no input with red green blinking status light .....any help please.....greatly appreciated..
doc
    Guru:
  • 147 Answers
Fyremd,
I had an older model (1500) and I think I read in the manual that it will shutdown @ 3000 hrs. You have to replace the lamp itself, not just the bulb. The average price (depending on where you shop) is around $200 dollars or more for a replacement lamp.
I hope this helps. Please let me know!
-Thanks
Posted on Mar 14, 2008
  • Alexander Kogl Mar 16, 2008
    fyre,
    Are our solutions helping any? Please let us know!
    -Chimpster
  • Mitsubishi Master
  • 13,433 Answers
Heres what the manual says about REd / green lights
Unplug the power cord from the wall outlet and contact your dealer
And also this:
Check that the lens cap is removed.
It may take about one minute for the lamp to light up.
The lamp fails to light up on rare occasions. In such a case, wait for a few minutes
and then try again.
If the projector was turned off before the lamp was cooled down suf? ciently last time,
the fan may start rotating and the POWER button may not work after the power cord
is plugged. After the fan stops rotating, press the POWER button to turn back on the
POWER indicator.
Check that the intake vent is clean.
Set SCART INPUT in the FEATURE menu to OFF. (See page 25.)
Check that the lamp cover is closed. (See page 33.)
Check that the cables connected to the external devices are not broken.
When an extension cable is being used, replace it with the supplied cable for check. When
images are displayed correctly, add an RGB signal ampli? er to the extension cable.
Check the operation manual of the video device for its connection.
  • Ekse Mar 14, 2008
    The also this part is when you dont get image.
    When its RED and blinking green, you might want to contact your dealer.
    If you need more assistance let me know.
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
Mitsubishi hc3000 wont start
this is a problem in your power board.
thi unit is getting OFF due to heating problem
Jun 29, 2008 | Mitsubishi Office Equipment & Supplies
Alternating power and lamp status lights
...replace the lamp. The lamp is most likely WAYYYYY past its prime so I suggest starting there. Sometimes even if you had just replaced the lamp the new lamp could've blown. When there is no signal running through the lamp circuit there is no signal to the display sensor, which means no image.
hope this helps!
Jan 28, 2009 | Mitsubishi XD300U Multimedia Projector
STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
The colorwheel is your problem. To confirm this, unplug the tv, then listen thru the air vents in the back as you plug the tv in. You will probably hear a ticking sound. If you do, that is the colrwheel. If the colrwheel is working, youwill be able to hear it "spin up". It will be a sudden high pitch whine. Let me know if I can be of further assistance
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Won't turn on. Green power light blinks for 30 seconds and then red lamp light blinks constantly
If the lamp light is lit, it is likely a bad lamp. If you remove the lamp from the set, you will either see shards of glass in the housing and/or a very cloudy reflector (it should look like a mirror). Be sure to use an original Sony lamp as the replacements are trouble makers. Please be sure to rate this solution. Thanks!
Oct 29, 2008 | Sony KDS-60A2000 60" HDTV
I have a LVP-HC3000 DLP projector. I bought it new, I use it for sports and movies. It is 2.5 years old but it has <1500 hours on it. I do run it in "brightest" mode as do not have great...
the bulbs arent hard to change but run about 100.00 have you checked the filter on it to see if it needs cleaned> its either on the back ot the side of the machine.i have one here too that i use and never an issue with it
Oct 15, 2008 | Mitsubishi Televison & Video
Status Light Flashes Red
first did you getthe lamp from miths and if notyou could have bought a bad lamp. you need to get a lamp form mits if you did not buy from them. if you did buy from mits have them replace the lamp it has a 90 day warranty. try hitting the menu and device / input buttons for 5 sec and repost the blink code. it is a 2 digits blink code. (ex. 23 or 33 or 26 like that)
Apr 20, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Lamp not lighting
Reset the lamp and try it.
Mar 28, 2008 | NEC VT660 Multimedia Projector
Solving a projector problem
if power lamp and status lamps are red change the lamp.
Jan 15, 2008 | Mitsubishi HC3000U Multimedia Projector
Mitsubishi HC3000U Multimedia Projector Logo
875 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
