Question about iLO 2600 Television
HDMI ON ILO 32HD
I don't know how to make the HDMI work on my TV. I have a HDMI cord connecting my PS3 to the TV, but when I select HDMI in the Videomenu a blue screen appears,a dn it says No Signal
don't know how to change hdmi input
  • 2 more comments
  • Anonymous Mar 19, 2008
    when i hook the hdmi up on my ilo 2600 then connect my audio cables. i get an excellent picture but no sound. what am i doing incorrect. please help me. thanks jimmy e-mail is [email protected]
  • jimmy6290 Mar 19, 2008
    the HDMI hookup gives a great picture but i cannot get sound when i hookup th audio cables. can u help me with this problem? jimmy
  • Anonymous Mar 23, 2014
    HDMI
  • Anonymous Mar 26, 2014
    something changed on my remote. tv doesn't start up HDMI
I use a Toshiba DVD Player SD-6100 and had the same problem when using a HDMI cable. The ILO TV kept saying no signal. I don't know how to make the PS3 change into sending the HDMI signal, I'm sure though that is is similar as to the dvd player simply changing it in a menu. All I had to do was use a component cable to access the dvd player menu and from there changed the video out signal to hdmi, thus sending a signal to the frikkin tv. It all works now.
The Ps3 should have a similar menu to select video signal output. Try accessing it using a previously working cable, then once changed, switch on the tv back to hdmi input and see if it worked.
Hope this helps
Cheers
CPL Avila
Posted on Nov 02, 2008
    Problem Solver:
  • 7 Answers
It sounds like there is a problem with either the output on the PS3 or the input on the circuit board of the TV. I would try a reset on the PS3 first. Also make sure that there are no other video or audio cords plugged into the PS3 because this will cause the PS3 not to send the signal via the HDMI.
Posted on Mar 17, 2008
SOURCE:
My emerson tv say device control inactive
John, I've ran into this issue a couple of times myself. In most cases, there are easy fixes to the issue. #1, Does your TV have multiple HDMI inputs? They may be labeled HDMI1, or HDMI2, etc. I know this sounds strange, but many people don't realize that the signal source is important. #2, Connect the cord, from another device that you know works(laptop-monitor) to eliminate the possibility that your HDMI cord is bad. #3, (Probably most common) The PS3 is not the most stable platform when using the HDMI cord. Remember that the PS3 was one of the "pioneering" platforms using the HDMI connection.As such, the "auto-detect" feature is sometimes confused when switching between RCA inputs, and HDMI input. (Happens every time actually) To fix this, try a video reset on your PS3 system. It's fast, easy, and doesn't effect anything except the video/audio settings. I'll put in a link to get you started in that direction. It is the same with all models of PS3. Good luck! ^^
How To Reset PS3 Video Settings PS3
May 06, 2013 | Sony Playstation 3 (PS3) Console
I have an ILO - 32HD Television but the cable cord that comes from the wall does not have a place on the TV to connect to. There is an indentation labeled ANT in the shape of a USB port which it isn't,...
Your TV comes with HDMI, DVI, Component In and S video in. Since it has no Tuner built in you will have to use a Set Top box with either component out or if you buy an HD Set Top box with HDMI out. The later will be in your favor so that you can use the only component video input for your old DVD player and not keep juggling pins at the back
Mar 07, 2011 | iLO 3200 32 in. LCD Television
How would i know if my HDMI ports are working or not?? Tried to connect a PS3 to it but nothing. Thought it may have been the cable so checked someones that i know is working and still nothing. Checked...
As you already checked PS3 and HDMI cable,
select HDMI input in TV and connect PS3 via HDMI cable. TV should show PS3 picture.
And if still no joy then HDMI input port in TV is bad and need to replace input board/ main board.
Jul 08, 2009 | LG M227WD-PZ LCD TV
Cracked lcd trying to buy a ilo-32 hd lcd
You do know that the LCD display will be a few dollars short of a new set ? If your still interested in it then let me know.
May 20, 2009 | iLO 3200 32 in. LCD Television
Can't watch dvds on playstation 3
No, but you do have to select HDMI output in the settings in the PS3 menu and make sure the TV is switched to the correct HDMI input ( Whatever one you plugged your PS3 into)
Mar 13, 2009 | Sony PlayStation® 3 (80GB) Console
Ilo-32hd tv only 1 chanel
dude it just happened to mine it sucks!
Aug 16, 2008 | iLO V27DMBX Television
Hook computer to ILO tv
The best way is to buy a graphics card with HDMI output. This will dsplay your PCs desktop the way it's supposed to look, and will appear much sharper and clearer than using vga, as the output is digital to begin with. If you don't need to play the latest games, you get get one for around $30. Add a wireless mouse and keyboard and you'll be able to control everything from your armchair. You can also then use your PC to download and watch films etc from the internet..
Jan 06, 2008 | iLO V27DMBX Television
Televison & Video Logo
2,038 people viewed this question
Top iLO Televison & Video Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
