Question about RCA 32V420T 32" TV
32 RCA Telvision With Picture Stretch
Manual read
TOCOM 1616262B
The picture is stretched horizontal. Cutting off Some of the picture just wonderin if there is a way to get into service menu or do ratio change or something. In picture setup it is very basic just color,contrast and tilit that type of thing. No pincushon or anyhting any info would be great thanks for the help!
    Genius:
  • 1,694 Answers
Mis-shaped pix is often a bad capacitor in scan circuit or a bad
solder connect on a shaping capacitor lead...............T.
Posted on Apr 06, 2008
SOURCE:
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Picture too big for screen; cutting off top of heads and bottom of screen
Go to the picture setup of your settings menu.
Somewhere in there are options for selecting picture size.
The options will be similar to: Normal, Wide, Zoom, Stretch
You have probably selected Zoom, try Normal.
May 18, 2011 | Hyundai Q321 32 in. LCD Television
I do not have a full screen with most channels even with view mode set to stretch oe S.stretch
most channel are broadcast in 16:9 format. you can stretch the picture somewhat but it wouldnt look right on fullscreen anyway.
Nov 28, 2010 | Sharp LC32D47U 32 in. LCD TV
Do not have full picture
Not all programs display in correct format. Chosing a stretch option from the TV remote or Cable remote is usually the only option. Aside from going into the menu settings and changing the Horizontal & Vertical axis.
Sep 30, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Good evening, I've gone through the manual and I can't get my TV to show 100hz (always 50hz), also on some channels I cannot get the picture to fit the screen (it's 32''). Any help would be greatly...
Well, first the 100Hz issue. Your TV will display a descriptor or the signal it is receiving, not a descriptor of the picture you are watching. Your TV panel has a native resolution and frequency. In your case, that frequency is 100Hz. Everything, like it or not, must be converted to 100Hz for the TV to work. In your manual, you are simply adjusting setting which smooth the picture and make it flow better than it would at 50Hz. This feature is slight of hand and is probably working just fine. As for the picture fitting the screen; HD programs fill the screen of HD channels.... SD (Standard Definition) programs use black bars on each side when on HD channels. You can use any available wide or picture size feature your TV may have to stretch the picture. You may be unable to stretch the picture, due to restrictions (some TVs will not resize HD formats).
Mar 15, 2010 | Televison & Video
I can't see the whole picture. the tops of everyone's heads are cut off. Normal, stretch, zoom format does not fix it
check to see if tv has a function call aspect ratio
that should take down the picture size not screen size
Aug 17, 2009 | RCA F32650 32" TV
My sony tv problem is that the picture is stretch horizontally..
If you have a DVR too, there is a pound (#) button on the beside the zero on the DVR remote that stretches my screen off and on. Try that.
Jan 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The positioning of my desktop's imageis still distorted despite running the easy tune display wizard and my using the auto tune keys on the side of the monitor.
Use the manual methods on your monitor (horizontal and vertical size and position), not the auto tune and see if you can get it to improve.
Try using a different desktop picture as well.
Right click on the desktop where there are no icons, and change the picture. Also, play with Stretch/Center/Tile - stretch will distort a file if it doesn't exactly match your screen settings.
Jul 17, 2008 | Gateway Computers & Internet
32" rca picture stretched
Before you fool around with this, it may be under warranty. Check that first. Second, does the picture stretch in both directions or just vertically? If just vertically is it more pronounced at the top?
Thanks,
Dan
Apr 03, 2008 | RCA 32V420T 32" TV
Adjust manual picture on TV
Sounds like you may have caps going bad . Adjusting may tend to only stretch the the picture too much . Also when you say horizontal are you saying the top and bottom are closing in ? If yes then your problem is in the vertical section . If side to side then check the horizontal section . Good luck
Mar 01, 2008 | Televison & Video
RCA 32V420T 32" TV Logo
79 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
