Question about Samsung HLN4365W 43" Rear Projection HDTV-Ready Television
HLN4365W need to reset the time on a HLN4365W HDTV
  • Samsung Master
  • 8,617 Answers
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Posted on Mar 14, 2008
  • George Paphitis Aug 13, 2012
    Dumb? Which is the split key on the remote?
SOURCE:
Hln4365w samsung tv
DLPs have had terrible reputation for faulty power supplies. Does the power light flash when it shuts down? How many hours are on the lamp?
Nov 08, 2013 | Samsung Hln4365w 43-inch Widescreen...
I have a samsung tv model #hln4365w. it turns on but the lamp light blinks and cycles through about 3 times, then the three lights come on including tempature and all shuts down. Is this the sign to...
The projection lamp has not been replaced like 1 1/2 or 2 years and tv on and used like 4 or 5 hours a day on this tv?yes,than the projection lamp life is over.Require a new projection lamp.
Sep 13, 2010 | Samsung HLN4365W 43" Rear Projection...
Sound quit on Samsung rear projection TV
We solved the problem by purchasing a surround sound system and hooked it up to the Cable box thus bypassing the TV speakers. It was a cheaper fix than having a TV repair service guy come out and we have even better sound! Thanks anyway!
Jan 13, 2010 | Samsung HLN4365W 43" Rear Projection...
How to replace samsung hln4365w lamp
It is fairly simple to do. Just remember to turn OFF the tv, and DO NOT TOUCH THE LAMP ITSELF. Here is an online manual that has the instructions on page 10 of the manual. Just copy and paste this into your browser navigation bar.
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=ca&CttFileID=158034&CDCttType=UM&ModelType=C&ModelName=HLN4365W&VPath=UM/200312/20031210182549750_BP68-00188A-00Eng.pdf
Aug 07, 2009 | Samsung HLN4365W 43" Rear Projection...
Samsung HLN4365W picture not centered
turn the tv off, hit mute 1 8 2 power, the tv will come on in the service menue, look in that menue for vertival and horizontal adjust, after you adjust it, just turn the tv back off, it will save your changes
Jan 07, 2009 | Samsung HLN4365W 43" Rear Projection...
Hdtv but has no inlet for the cord.
Hi..
That set has 2 DVI connectors in the back. Either one will work if you have a cable that matches.
The manual is available online too
http://www.usersmanualguide.com/samsung/tv__projection/hln4365w
Jan 05, 2009 | Samsung HLN4365W 43" Rear Projection...
HLN4365W Start-up Issue
the main power supply may be getting weak. if so it will delay the time it takes it to come on and eventually it wont come on at all
Jun 27, 2008 | Samsung HLN4365W 43" Rear Projection...
Samsung hln4365w - no pic. or sound. it whistles a few times when powered on
We have the same DLP set and had the same problem. The Color Wheel, P/N BP96-00250A, a $200 part needs replacement to eliminate your problem.
May 24, 2008 | Samsung HLN4365W 43" Rear Projection...
HLN4365W
That could either be the cooling fan bad or the light engine assembly as they both can exhibit the sympton your describing. Can you haer this sound as soon as the power is pushed or does it take a moment. If its instantly chances are its the fan.
May 03, 2008 | Samsung HLN4365W 43" Rear Projection...
No picture, new lamp
Did you reset the hours on the lamp with the menu options on your set? Sometimes, if you do not do that it can mess with the tv performance thinking that its over hours. It needs to be reset to 0 again...
Sep 24, 2007 | Samsung HLN4365W 43" Rear Projection...
Samsung HLN4365W 43" Rear Projection HDTV-Ready Television Logo
1,146 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
