Question about RCA HD52W59 HDTV Projection Television
Convergence Problem Just to follow up a bit the board I tap on to straighten out the picture has two large red wires coming from what looks to be a transformer and has a sticker with part # 56096260 is this the power supply board I need to repair the problem? You referenced part # 271860 didnt want to order the wrong part must be crossed referenced.
  • RCA Master
  • 8,617 Answers
The 271860 is a convergence power supply IC. Exactly what was your problem, and could you please include the chassis number from your set, as rca has to be diagnosed by chassis number.
Posted on Mar 14, 2008
Samsung tv model # HCP4363WX Ghosting
The convergence board that you replaced will not correct the issue that your describing as your model has the convergence amp circuits located on the Deflection board. You would need the deflection board which is available at the following link. It also has a picture of the board which is in your model its the large board on the right with the Flyback and both Convergence ICs on it.
http://servicemanuals.vstore.ca/product_info.php/pName/p59a-pwr-def-board/cName/samsung-parts
Dec 16, 2009 | Televison & Video
P58a red convergance is bowed down on top and bottom
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 12, 2009 | Akai PT5598HD 55" Rear Projection...
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
Colours red and green are out of sync
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Apr 18, 2009 | Philips 55PP9363 55" Rear Projection...
Convergence problem
your model has two boards that control convergence. One is the convergence board. the other is the convergence board power supply, usually when more than one color is off its the Convergence power supply that is bad. You can get replacement circuit boards at the following link.
Jul 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence problem?
The convergence anp ICs are usually what go bad in that unit. They are two ICs both are STK392-040 and they are at board location ICZ103 and IZC103 on the Sub Board attached to large heat sinks. You can get replacements with free installation instructions and free on line tech support at the following link.
let me know if you need further assistance.
Apr 10, 2008 | Samsung HCL4715W 47" Rear Projection...
Tv wouldn't turn on, unplugged convergence board, turned on, replaced STKs, still have convergence problem
*Screen Looks 3-D
*Colors wont align
Feb 07, 2008 | Samsung HCM4215W 42" Rear Projection...
MITSUBISHI 48" TV
You probably need to re solder the convergence output IC`s. They will be mounted vertically on a large aluminum heat sink. You can also tap gently with the plastic end of your screwdriver on the PC board to find the area where it is most sensitive. Visually inspect the bottom side of the board for noticeable rings around the solder points. Good luck
Dec 14, 2007 | Mitsubishi VS-50605 50" Rear Projection...
CONVERGENCE PROBLEM IN TOSHIBA 43H70
Hello Renee, You have a convergence problem, but you are adjusting the wrong system. You need to adjust the convergence rings first ok You need a dot and crosshatch generator to properly set convergence for this set. Connect the generator set the TV to channel 3 and turn on the generator set it to dots adjusting the convergence try to get the center dot RGB all together and then adjust for the outer edges using the convergence board. the use the crosshatch to adjust convergence along the lines of the crosshatch pattern. Remember use the rings first and the the convergence board adjustments.
Sep 24, 2007 | Toshiba 43H70 43" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
116 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
