Question about Hampton Bay 52 In. Black Huntington III with Quick Install Fan
Ceiling fan light bulbs rouotinely burn out in less than 4 hours of use
I installed a new ceiling fan. It has 4 60-watt incandescent candelabra bulbs and I've replaced each bulb one or two times. They blow out after only a few hours use, and since I've gone through more than one package of bulbs I don't think it a matter of a defective batch of bulbs. The bulbs are are the maximum wattage the fan specs call for and they are open to air circulation. The house is brand new and pre-wired by a major builder (Pulte) who should have the wiring down pat. One wall switch works the fan, and one works the light kit via a dimmer (slider) and on/off toggle combo. Both the fan and light switches seem to work. I do keep the dimmer on max for maximum illumination but wouldn't think more current gets delivered than the bulbs draw(?) The fan was a floor model at Home Depot and it worked fine in the store and was lit up there (they even gave me the initial set of bulbs). I'm not popping any circuit breaker. I'm at a complete loss and would appreciate any help or insight to what the problem is or how to isolate the cause.
(I'm not actually sure of the model number of the fan, so I guessed at the product description to pass the system check. I don't think it matters.)
  • Steve in CA Mar 14, 2008
    I'm confused on your comments re "the switch is off" and "the bulb is not burning when it blows". Not the case. I only see the problem when the switch is on, and I can only assume current or voltage causes the problem. I actually saw a lit bulb blow out the other day - I turned it on and watched carefully - one fizzled out in maybe 1-2 seconds; not the usual bright explosion but it just kind of blinked off. When I removed the bulb, the filament was clearly fried. I don't ever recall the usual bright explosion associated with most incadesent bulb failures, if that helps, but then again only 1 in 4 fails at a given time so maybe it's not that noticeable.
  • 4,889 Answers
Looks like some kind of high voltage problem. The smart thing to do would be to install a fuse that can withstand 220-230volts(the max that a bulb can take) in the circuit between the fan and the bulb.The fuse should blow out if it crosses 245V the. If it blows out then it out indicates any high voltage problems. I would put my money on bad wiring though..
Posted on Mar 14, 2008
  • 19,396 Answers
"The only things I know of that cause bulbs to blow are, defective product, has been used its average life span, over voltage, heat and vibration.
The implication is that this has happened repeatedly so defective product is unlikely.
If it had lasted its normal life span you would not be asking the question.
Over voltage is out because the switch is off.
Heat is out because the the bulb is not burning when it blows.
That leaves vibration. Some types of candelabrum bulbs seem to quite sensitive.
What's above the ceiling The tink you hear is the filament breaking This most often happens when the bulb is hot. Very unusual to break when cold unless dropped or mistreated.
Don't see a fire hazard because switch is off."
  • 1 more comment
  • Ginko
    Ginko Mar 14, 2008
    130 volt Rough Service bulbs can provide more life than standard.
  • Ginko
    Ginko Mar 14, 2008
    In any case It seems like you have a problem in your supply or house wiring. If the problem persists better to talk to your builder's electrician and to the power company.
    regards
  • Ginko
    Ginko Mar 14, 2008
    Sorry, my first comment was general solution for same problem reported from fixya, infact it is within quots. Clearly bulbs blow only when your switch is on, this is probably because of a problem with your house wiring. You should test volts and amps out from your power outlets are ok. Also test power leading to ceiling fan. If electric plant in your house is ok then test power out from fan leading to one of bulb. If power intensity is ok during a certain amount of time (you told me it takes couple of hours for bulbs to burn).
    If you still find that everything is ok in your plant, then in this case the cause for bulbs blowing up must be a short inside the fan that occurr occasionally every couple of hours (lose wire etc). In this case if the fan is still garanteed send it back to shop/service, if not then you will need to open it and find the eventual short.
    Regards
What type of light bulb do I need for a minkaAire ceiling fan. It is about 7 years old
It all depends on which light kit was installed on your fan. As you described the fixture as requiring a "light bulb" meaning a singular bulb, Minka Aire usually uses several different types.
The most common is either a 40-watt or 60-watt Candelabra Bulbs.
(The designation "Candelabra" refers to its screw base. You can buy these in clear or frosted, torpedo or globe with a straight tip or curved. Etc.
Here's an example of a torpedo globe:
Sunlite 60 Watt Torpedo Tip Chandelier Candelabra Base Frost 48 Pack
And here's an example of a Candelabra globe:
Sunlite 60 Watt G16 5 Globe Candelabra Base Clear 48 Pack
Some of their fixtures use a 50-watt Mini-Can Xenon Bulb.
Satco S1914 50W MINI CAN FROSTED 120V
And other use a 3w CFL Medium Base Bulb.
3W CFL Deco 2700K Medium Base
When installing a CFL, Halogen or Xenon bulb, I recommend cleaning the glass with an alcohol wipe to remove any oil from fingerprints. Due to the very high temperatures these lamps operate at, the oil from your fingers will cause a hot-spot on the glass and can shorten the life of the bulb dramatically.
If none of the references I offered match the bulb in your actual fixture, you might be able to more closely match the fixture from one on the following page. The recommended bulb for each fixture is listed in the description of the fixture.
https://www.ceilingfan.com/Minka-Aire-Fan-Lights-s/2082.htm
And as always, NEVER over-lamp a fixture with a bulb rated at a higher wattage than what's shown on the base of the fixture. That is, never use a 60-watt bulb in a fixture rated at 40-watts. The additional heat of the bulb may harden the insulation of the wiring in the fixture creating, causing the insulation to fail and create a fire hazard. Also for fixtures located tight to the ceiling, higher temperatures can dry out the gypsum ceiling material, causing it to crack and deteriorate.
Feb 09, 2018 | Dryers
I just replaced my bulbs on my ceiling fan light fixture with the compact flourescent bulbs 13 watt to replace the regular 60 watt bulbs but they are flickering now. Could there be a problem with wiring...
Your remote control I would assume includes a dimmer for the light. CFL bulbs are not compatible with dimmers. If it has a dimmer, you must use incandescent bulbs.
Feb 14, 2011 | Hampton Bay 52 In. White Redington...
Ceiling fans not bright enough
In this case, probably not. The issue is heat, and the limit is space. One suggestion, new fluorescent bulbs give more light with less wattage. If you can find one that will physically fit in the space, this might get you more light.
Oct 19, 2009 | Aloha Housewares Dryers
Question about light bulb problem in ceiling fan
Check wiring @ ceiling. Should b a black, white, green & red wire coming frm fan. Green is ground. Black & Red is power. White is neutral. Black provides power to fan, red provides lat power 4 lights. Remove light assembly, blue wire provides power. B sure 2 turn off power 2 fan b 4 working on it w/switch & breaker. Maybe lose wire connection or pinched wire grounding out. Fans require vibration proof bulbs regular bulb elements will break after short time use. Fan bulbs have larger filiments inside bulb.
Aug 23, 2009 | Aloha Housewares (93645) Ceiling Fan
Light kit has light bulb size that I cannot find bulbs for
Melanie, you must have gotten a bad batch of bulbs. I have installed over 100 Hampton Bay ceiling fans and I have dropped them from up the ladder and have them bounce across the floor with no damage. I think they must have allowed a substandard batch to go out.
Home Depot is where I buy my replacement bulbs. Hampton Bay make fans exclusively for HD.
You can easily change lighting bases, as the wiring is the same for all Hampton Bay. You may even appeal to Hampton Bay on the internet and they might send you the kits. But I don't think you'd have success in a store.
If you try replacing them with bulbs from another Home Depot you may find them much hardier. I wish you the best of luck, and if you need additional help please write back.
Sirwriter
May 25, 2009 | Hampton Bay 24750 Huntington III Ceiling...
40 watt just not bright enough?
60 watts could be fine and you may never have a problem, but it says 40 watts for a reason. So you don't burn your house down. See "To reduce the risk of fire....". The better option here would be to buy 23watt compact fluorescent light bulbs. They give off less heat than a 40 watt incandescent and the same light output of a 100watt incandescent. I'm guessing that you don't currently have the light on a dimmer, but if you wanted to, make sure you get cfl's that are made to be used on a dimmer.
Jan 08, 2009 | Hampton Bay 24002 Ceiling Fan
MAXIMUM WATTAGE FOR FAN LIGHTS??????
those bulbs are candelabra type. if they came with the fixture then I wouldn't go to a higher wattage bulb. the sockets are probably bakelite and mounted with the base up so any heat off the lamps would be directed upwards. higher wattage bulbs may shorten the lifespan of the sockets. bakelite is a modified plastic. it won't melt but it will get brittle.
Jan 08, 2007 | Hampton Bay 04379 Madison Avenue Ceiling...
Hampton Bay 52 In. Black Huntington III with Quick Install Fan Logo
1,342 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
