Question about Dryers
HELP Does the tumbler on dryer turn clockwise or counterclockwise
    Novelist:
  • 142 Answers
In general, front load dryers turn clockwise when looking at the basket from the front.
Posted on Mar 14, 2008
Ghw9150pwo drum will not spin counterclockwise during step C:07 of diagnostic test
the metal of the tub is digging in to the metal or plastic frame holding the tub
Oct 03, 2013 | Dryers
Dryer makes a buzzing noise when I turn it on but it doesn't come on, just buzzes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
What is the model number?
Nov 06, 2012 | Dryers
My dryer knob has broken again. Wich direction should I be turning the knob when choosing a drying cycle? I was told I was turning wrong direction.
GE dryers turn in the clockwise direction and if you turn in the counterclockwise direction you could break the stops off the switch.
Jun 20, 2011 | GE Dryers
Start button buzzes when pressed, dryer doesn't start.
I assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Apr 26, 2011 | GE DVL223EBWW Electric Dryer
Tumbler belt came off
  • Unplug your dryer from the electrical outlet. Remove the lint trap by lifting its cover and sliding it out. Use a screwdriver to unscrew the two screws that hold in the housing of the lint trap.Lift up the top panel of the dryer and take off the holder for the door switch wire. Look for the screws that hold in the front panel of the dryer, located on top of the front panel, and unscrew them. Take the panel off the dryer by lifting it off.Look inside the dryer, find the broken dryer belt, and before taking it off, note the way it is routed around the pulleys, then take it off. Install a new Whirlpool dryer belt by slipping it around the tumbler with the grooves facing the surface of the tumbler. Ask an assistant to hold up the tumbler while you move the belt into the proper place, aligned with the black line around the width of the tumbler.Wrap the new dryer belt around the pulleys as noted in Step 3. If you don't remember how, or the old belt was snapped and not aligned properly, look at the dryer belt diagram in your user's manual.Align the front panel of the dryer with the tumbler. Put back in the two screws that hold the panel in place. Open the door of your dryer and with your hand, turn the spinner one time counterclockwise. Reconnect the holder for the door switch wire, being careful that it doesn't touch any moving parts.Use the screwdriver to carefully position the rubber seal along the back of the tumbler. Make sure the seal is on the outside of the tumbler and that none of it sticks to the inside of the tumbler.Slide the lint filter and housing back into place, and screw in the two screws that hold it in. Plug the cord of the dryer back into the electrical outlet and check that it spins properly.
  • Oct 11, 2010 | Whirlpool Dryers
    I need the owners manual. I need to know if it makes a difference which direction you turn the dial when setting for drying time. Clockwise? counterclockwise?
    Since you haven't stated a model # I can give you a generalization - that manual timers are designed to turn counterclockwise ONLY. Most will not even spin counterclockwise when you try.
    If you pass by the setting - you should go around again.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Feb 21, 2010 | Dryers
    How do you remove fan blade from dryer motor.Do you turn it clockwise or counterclockwise
    Hi, If you are looking at the blower from the rear of the dryer, the blower needs to turn clockwise to be removed.
    Jun 25, 2009 | Whirlpool LER5636P Electric Dryer
    Drum wont turn
    Is your motor working? How about your belt? Is it broken?
    Jan 24, 2009 | Dryers
    Dryer drum won't spin
    remove rear panel remove screws in blower housing ck for objects in blower ..if you still have dryer apart remove belt from motor pulley and try turning by hand
    Nov 15, 2008 | Estate TEDS840JQ Electric Dryer
    Dryer won't start, Simpson Eziloader 4kg
    Yes, the knobs don't like to be turned counterclockwise. Spin the knob clockwise to reinstall tightly, then move to set a dry time. Make sure half load button is pressed.
    Jan 24, 2008 | Whirlpool GEW9250 Electric Dryer
    Dryers Logo
    95 people viewed this question
    Top Dryers Experts
