Question about Amana DLW330RA Top Load Washer
Springs how to place the springs on the outer tub
    President:
  • Amana Master
  • 2,651 Answers
In order the replace the springs on the outer tub no special tool required, just a little patience and finesse. thinking there are 6 springs? you need to hook them 2 to a hole on bottom of machine, i usually set them all up before starting except for one of the front ones. you use the front spring as your spring tool. with the spare spring youll be able to grab the spring and pull it up and into the hole in the tub, starting with back springs working froward. when its time to secure the final spring i usually use a length of cord kept in my tool bag for this reason.
Posted on Mar 14, 2008
2 Suggested Answers
  • 1462 Answers
SOURCE: Washer Tub Gasket
remove gasket from cabinet - just held onto cabinet by a simple clamp and fold gasket inside drum. this will give you enough room to access the retainer. you may find it easier to remove the top as well
Posted on Sep 09, 2008
My Clamp, bellows to outer tub has came off was wondering how to put it back on???
just snap the bellows back unto the outer tub. the clamp should have a spring on it. place the clamp over the bellow and onto tub. take a needle nose pliers and pull the spring so that it stretches, it should go right on, then just release the spring and you should be good.
Feb 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My front load washer's tub has dropped down on to the bottom of the washer
If you are talking about the entire assy. basket and outer tub your support springs have broken,they hold the weight of the tub and basket. For the entire assy. to be laying in the bottom it also had to have the shock absorbers come loose or break..Now if you are saying that the basket is loose inside the outer tub that's much worse than a broken tub support and most likely a rear tub half with bearing assy.You can easily remove the 3 screws on the back of the TOP slide toward the rear and look inside their should be 2 large springs 1 on the left and 1 on the right
Sep 23, 2010 | Kenmore Front Load Washer
Cannot locate proper spring placements
The tub springs are attached to the slot on the base of the washer just under the rear edge of the tub while the other ends are attached in a V-position to the slots on the flange at the bottom edge of the tub. Attach the springs upsidedown to avoid the possibility of rubbing each other and result in a noisy operation of the washer.
Apr 04, 2010 | Maytag SAV4655A Top Load Washer
The tub is off center & is rocking around and leaks when filling.
Sounds like you are missing a spring or two on the bottom of the machine. Lean the machine back so that you can look under it. There should be two springs on each corner that attach from the frame that sits on the floor and the bottom edge of the outer tub. (Each corner pulls against the opposite corner holding the tub in the center) On the outer edge of the tub there is a piece that the spring attach to each end. If one or two are not in place the tub will sit to one side. You will proberly find that some of the springs on the back corners are not attached, causing the tub to be pulled forward or away from the fill spout.
Please rate this submission. Thanks
Aug 19, 2009 | Kenmore Washing Machines
RUBBER RING
Assuming you are talking about the boot seal that attaches from the tub to the door of the unit.
There is an inner and outer spring that holds the boot into place.
There is no easy way to do this.
Best way to do this is to replace the boot on the inside of the of the body, (Tub first) This will snap into place around the outer ring of the tub. The spring will be really hard to get into place. suggest something that will not cut to use and istall the spring,
Out is the same effect with the smaller spring match arrows.
Hope this helps.
May 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore HE2 plus 11047532601
If it's stackable, you'll want to start by removing the dryer.
Open the door and remove the outer bellow spring around the bellow to release it from the cabinet lip. At this point lean the machine back to give more space between the drum and the cabinet.
Remove the kickplate for easier access and to visually check for leaks later.
At the top/right of the bellows (close to the tub) loosen the bellow to tub clamp and pull out the bellow.
Install the new bellow starting at the top by aligning the marks. Work your way around until bellows is properly seated snug against the tub.
Replace the tub to bellow clamp and tighten it (make sure the bellow stays snug against the tub while tightening the clamp). Once in place, lay the machine back to level and reinstall the front of the bellows to the cabinet with the outer bellow spring clamp.
With towels handy (just in case), let the machine fill and agitate for a few minutes and check for water leaks. If all is well, re-install the kickplate and wash some laundry.
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
Frigidaire gltf1670a front door seal instalation
Open the door and remove either the outer bellows spring (newer models) or use a putty knife to scrape the glue around the bellows to release it from the cabinet lip. At this point lean the machine back to give more space between the drum and the cabinet.
Starting at the top, pull on the bellows firmly (close to the tub) until it comes out of the groove. Once it comes off you will see the bellows spring.
Install the new bellows starting at the top by aligning the marks (arrow on the bellows top and arrow on the tub lip). Work your way around until bellows is properly seated snug against the tub.
Here it gets tricky, it might be easier with an extra pair of hands but there's less room. Some bellows kits contain spacers/plugs which will help to "hold" the spring as you stretch it back in place. Work from the top down on both sides at once. Either use the spacers/plugs or have someone hold the spring in place as you work your way around.
Once in place, lay the machine back to level and reinstall the front of the bellows to the cabinet. Either re-install the outer bellows spring or re-glue the bellows to the cabinet. If this is not done you risk a water leak.
With towels handy (just in case), let the machine fill and agitate for a few minutes and check for water leakage. If all is well, make sure machine is still level by try to rock it diagonally from the top (if it rocks, lower the leg that is lifting). Re-install the kickplate and wash some laundry!
Feb 08, 2009 | Frigidaire GLTF1670A Front Load Washer
The tub @ my Fisher&Paykel model #GWL-08-US1 is off balance
you can lift the top and get a closer l;ook, by opening lid and looking approx, 4 inches back along side rail, youll see a rubber plug, remove the plugs toreveal the screws hoding down the main top. after emoving screw lift the top back and you see the 4 suspension bars tha hold the machine, either one "popped" or the left front corner should have a sdpring attached form it to the tub( clips on to the red little bracket on side of outer tub). either of thesse swill fixyour problem
Dec 03, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washer Tub Gasket
Sep 09, 2008 | Whirlpool GHW9400 Front Load Washer
Amana washer model# LW8203L2 leaks from bottom when spinning.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Jul 14, 2008 | Amana Washing Machines
Amana DLW330RA Top Load Washer Logo
229 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Sal De
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
