Question about Bosch 24 in. SHU43 Built-in Dishwasher
Miele Incognito G643 SCVI
I keep getting the intake/drain trouble code I have to cycle the on/off button twice to get it thru a complete cycle I have check the drain line and intake valve but see no obvious problems. the pump appears to be moving water satisfactory because the machine will periodically complete a full cycle with out a problem. Whats next?
tony
  • Anonymous Mar 16, 2008
    After further T/S, I found out that the intake/Drain lite came on mid cycle(between interim and final rince) during the economy wash. I tried annother setting (nornal wash) and the cycle completed without a problem. I then followed this with two more economy wash cycles with no problems. I have eliminated any blocked lines issue 9by the fact it completes cycles on other settings)Before I pursue the potential faulty wiring issue any futher( which would mean taking apart stufff!) I want to be sure we are on the right track. Comments?
  • 4,889 Answers
It sounds like there are some faulty wiring connections to the motor.
You will have to check your wiring from the timer to the motor.
Does it do the same thing if you select a different cycle on the push buttons?
The wiring diagram should be in the bottom access panel of the dishwasher or in the control panel.
Posted on Mar 14, 2008
  • eagle338
    eagle338 Mar 18, 2008
    your last comment has suggested that it might be a wiring error.. you can proceed.. Dont forget to switch off the unit and disconnect it completely from power supply.. Exercise caution. Your life and limb is worth much more than this!
  • 818 Answers
– Turn off the dishwasher.
– Open the water valve.
– Clean the water inlet
filter, see maintenance
instructions.
The waterproof system
has activated.
– Call the Miele Technical
Service Department
see this manual for help
http://www.miele.com/manuals/search_manuals.asp?nav=19&oT=56
Sergio
    Genius:
  • 1,226 Answers
Hello!
Unplug it in the wall to get hard reset and plug it back after some minutes and turn it on. you will be ok.
melnavz
  • Anonymous Mar 17, 2008
    Hello!
    It seems that you solve the problems. You should do what is your findings that could resolve the issue.
    thanks for using fixya. melnavz
SOURCE:
How do I fix a Miele G2470 SCVi with an intake/drain fault
Look for item(s) blocking the drain, inside bottom, and remove them.
May 24, 2014 | Miele Dishwashers
Red intake light comes on and dishwasher will not drain, model g 843 scvi
The manual is available here: http://www.miele.ca/miele/canada/OperatingInstructions/manuals.asp?ParFolder=Dishwashers&SubFolder=Previous%20models . Scroll down through the list to the G643 G843 Incognito. The maintenance items listed below are detailed on page 44 and beyond of the manual.
The Intake light is also the Drain error light. If the light is flashing, then turn off the dishwasher and clean the triple filter, the drain pump and the non return valve and make sure that there are no kinks in the drain hose.
Make sure the water is ccoming in at a pressure above 4.5 psi. Also make sure that the water valve is open and clean the water intake filter.
The final possibility is that the Waterproof system has tripped and you need a Miele technician to service the unit.
I hope this helps.
Feb 19, 2011 | Miele 24 in. Incognito G843SCVi Built-In...
We've got an Meile Incognito dishwasher, model G 843 SCVi plus. It purges at the begining of the cycle and then seems to fill with water, but then the red Intake/Drain light starts to flash and the cycle...
I would start by checking the drain line where it is connected to the garbage disposal. Check and make sure there is no solid build up obstructing the discharge into the garbage disposal. You can go a step further by removing the dishwasher drain line for thorough check up
If it has been establish that there is no obstruction by other means. There may be a problem with the control board.
I would suggest cautious approach in making rush decision on replacing the board.
Here is a link to the manual
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G843%20Vi-SCVi.pdf
Aug 02, 2017 | Miele 24 in. Incognito G843SCVi Built-In...
Miele Icognito G683 SCVI Plus. Residual water seems to be standing under the base guard and lots of moisture remains in the dishwasher?
Many dishwashers intentionally leave a bit of water in them to keep the seals from drying out...
if there is more there now then ther used to be then check this out...
Dishwasher Problems - Water will not drain out
heatman101
Jan 21, 2011 | Miele 24 in. Incognito G863 SCVi Built-In...
I have a Miele Incognito G843 SCVi Plus. In a wash mode, the cycle stops in the first serveral minutes before soap is dispensed and the Drain/Intake light flashes. In Rinse and Hold mode the unit makes...
Hi
First check if the drain hose is not clogged and try to clean it as it can be that the hose is clogged and the water is not draining properly. After that check if the drain pump filter is fine and not clogged, try to clean that as well. After this check the metal filter, impeller cover and the air gap unit. After checking this you can reset the error as follows: turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again. Hope this helps...please post back for further assistance.
Daniel
Dec 30, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Miele incognito won't drain. Intake drain blinking
i also found my miele wouldn't drain after replacing a garbage disposal. it turned out I forgot to knock out the plug on the disposal where the diswasher discharges....Doh !....
Nov 24, 2010 | Miele Incognito G818SCVi Built-in...
Dishwaser problems
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Jul 18, 2010 | Miele 24 in. Incognito G863 SCVi Built-In...
Will not complete cycle
check if kitchen sink downpipe is clogged
Jul 06, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Miele Dishwasher is not cleaning dishes
check the filters. also check drain. Sounds like it's not fully draining and/or there is not enough water (ie. when filter are clogged)curculating to wash the dishes properly
Jun 08, 2009 | Miele 24 in. Incognito G843SCVi Built-In...
Intake Drain Light
My Miele Incognito dishwasher kept getting an error with intake/drain light. The light flashed 5 times. Phoned Miele Technical Support to investigate the problem. The problem is that a seal in the bottom of the dishwasher has failed and there was water in the motor pan. Currently, $175 service charge for the technician to come look at it.
I don't want to spend $175+ to have them replace a 75 cent rubber gasket that I could replace on my own.
Feb 20, 2008 | Miele 24 in. G892SCU Plus Built-in...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
895 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
