Question about Intel D845GVSR Motherboard
Bios setup problem at booting.
Whenever I booted my pc, message say checksup error, no date/time set, press F4. Even after making changes in BIOS Setup, when I switch off the main supply, its again given same error. I change the CMOS battery also, but problem same.
  • Mahendra M Mhatre Mar 14, 2008
    Today I put another new one CMOS battery, it working fine now! Thanks
  • Anonymous Mar 15, 2014
    even after replacement of good and standard CMOS battery at the start up the battery failure message flashes and the date-time do not remain the same according to current settings.
    Scholar:
  • 104 Answers
Make sure the BIOS Configuration Jumper is in the 'Normal' position (pins 1 and 2) and not in the Config position (pins 2 and 3). It is located near the battery at the corner of the board. The Manual and Config information can be found here.
Posted on Mar 14, 2008
My date is not getting set in bios
Change the CMOS battery.
If you had taken the time to post the computer manufacturer name, and model number; I would know what motherboard we're dealing with, and what type of CMOS battery it uses.
Generally the battery is a CR2032.
A type of watch battery.
Positive ( + ) side ALWAYS goes UP
Post back in a Comment.
Regards,
joecoolvette
Apr 03, 2013 | Computers & Internet
Bios rom checksum error, boot block bios vI.0
Error BIOS ROM CHECKSUM - SYSTEM HALTED.
Cause Bad Hardware
Solution Unfortunately this indicates that your computer BIOS ROM chip or Motherboard is physically bad. It is recommended that you contact your computer manufacturer or take the computer into local service center for repair.
If you wish to repair this issue yourself the motherbard will need to be replaced.
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
hope this helps you
Apr 14, 2012 | ASUS A8N-E Motherboard
CMOS error
Diagnosis: The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent hardware or software change
If you don't know the settings you should be one for optimal defaults - use that one. You will also need to reset the time and date.
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps you
Dec 07, 2011 | Intel Desktop Board DH61WW Classic Series...
Bad check sum cmos
hope this helps you
Nov 18, 2011 | Toshiba Equium 2000 (PV1065E0-011FR) PC...
Reason for showing "check main
your bios has been damaged the bios chip on your motherboard could be damaged to check it
restart your compuetr during the boot up process you will see a certain key to press to enter set up (bios) press and hold that key to enter bios using the arrow keys scroll to load optimised defaults
hope this helps you
Sep 23, 2011 | Gigabyte GA-G31M-ES2L Motherboard
Please run setup invalid configuration information
If this error message comes up when you boot up the computer, it means the BIOS requires configuration, usually the Time and Date is wrong.
If this occurs every time you boot up your computer and have changed the Date and Time then this could be caused by a flat BIOS battery.
If so, replace the BIOS battery and then configure the Date and Time and you won't get this error again.
May 14, 2011 | Dell INSPIRON 6000 CENTRINO...
Bios date and time problem
You need to replace the cmos battery in your computer. Theu are usually Cr2032 batteries which you should be able to pick up for about £1.
unplug your computer and open the case.
When you look at the motherboard you should be able to easily locate the cmos battery cliped onto the mobo.
Take the old battery out and insert the new one.
put the case back on and plug the pc into the mains again.
You will need to re-enter the date etc the next time you boot up, but the settings should be retained after that.
Ian
Mar 09, 2009 | Dell OPTIPLEX GX150 PIII-1.0GHz 256MB 40GB...
My computer went back to older clock date as 1610
try starting your computer in safe mode and see if you can do anything productive there, like scanning for viruses or spyware. also check if you can do the following:
CTRL+ALT+DEL (open task manager)
goto Start>Run>Regedit (open registry editor)
goto Start>Control Panel>Display>Properties (change display settings)
right click on clock at tray and change the current time to correct settings
if you cannot do any of these activities, then your computer may probably been compromised by a virus or malware.
Jan 02, 2008 | Dell OPTIPLEX GX150 PIII-1.0GHz 256MB 40GB...
Intel D845GVSR Motherboard Logo
163 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
