Question about Sanyo CLT2054 20 in. EDTV-Ready LCD Television
On off on off piece of junk
Tv will turn on for only a split second and then shuts off repeatedly.
    Sergeant:
  • 308 Answers
The picture flashing that you are experiencing is likely due to a defective IC on the main PWB, IC802 is the one I would expect. This part is not available in the US that I know of and if it were, you would need a rebuilding service to replace it. The board that it is mounted on also is not available AFAIK.
Posted on Apr 01, 2008
SOURCE:
The on off button is red. when pushed it turns green for a split second. the audio comes on, but not the picture, and shuts off a split second later. the on off button turns red again.
Please let me know model number and brand of your tv to find out possible cause of problem and to suggest a solution.
Thanks.
Mar 18, 2011 | Televison & Video
The tv will come on for a split second then click and cut off its a mitsubusi projection ws-55809
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
SD TECH
May 11, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Tv will not turn on
Get a power extension cord to connect your TV power to another (zone)room by using a different outlet and see if that is still does it.
Remember when you unplug the TV,you want to give it 15-20 seconds first .
If it still have the same issue,i hope you have the warranty,you are going to need it for repair.
solutiondoct
Nov 11, 2008 | Hisense Televison & Video
Power Problem
Same problem as sweetpetny...blinking power button, won't on.
Jul 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
TV turns on for a split second then back to standyby
i think your capacitor is blown, do a google search for insignia, lcd, capacitor...
you can buy another one for about $2 but its a pain to install, you can also instead buy a new powerboard for about $80, its an east install and you wont blow more capacitors
bestbuy.partssearch.com
May 09, 2008 | Insignia IS-LCDTV32 32 in. Television
T.V. shuts off
try unplugging it from the wall for a day
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Jan 06, 2008 | Panasonic PV-C1321 13 in. TV/VCR Combo
Sleep timer not a fix
This Tv is a piece of junk I have 2 of them and I had to replace the first one with this same problem. The second one just broke is stuck in dvd mode. Company is out of buissness
Dec 06, 2007 | Sony KDE-50XS955 50 in. Plasma HDTV
TV turns itself off after a few seconds, no picture at all
As far as fixing goes, you might as well get a new TV... Unless its a LARGE EXPENSIVE HOLY $%^# TV, It will cost more to fix, than to just buy a new one, unless its under warranty, which being an older model as that (or so im reading) It may not be covered.
Try unplugging the TV, and while unplugged, hold down the power button for a full minute (yes, with the plug NOT in the wall) after a minute, plug it back in, and try. Its a hard reset. If it still does not work, and you've tried different outlets, It's probably a repair issue, and you'll need to get someone to fix it, or just junk it :-/
Nov 11, 2007 | Sylvania SST4322 32" TV
Sanyo CLT2054 20 in. EDTV-Ready LCD Television Logo
37 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
