Question about D-Link DKVM-2U 2-port KVM Switch
Laser mouse crash
I put a flash drive in the usb port and after that the laser mouse would not work
--even after a cold boot. Help
  • 38 Answers
Check after change the USB PORT
Posted on Mar 14, 2008
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have Model 1058 Mouse bought 12/09. Computer crashed (motherboard) and had to get new one. Can't find installation disk for mouse. Can you help?
change the mouse battery and there is a button named connect on mouse keep pressing the connect button for 3-4 minuts and keep mouse near wireless device which is connected to the computer in USB port then restart your computer and mouse will work fine.
Mar 30, 2010 | Microsoft Wireless Laser Desktop 4000...
Hello, i currently use a IBM desktop with IBM keyboard and mouse but i just bought a microsoft wireless keyboard and mouse which i just installed into my desktop using the installation CD. They are both...
Hi Tony,
It appears that you have an IBM desktop whose BIOS isn't capable of booting off of a USB keyboard and mouse device. Older computers used to require that a PS2 mouse and keyboard be attached before booting, to prevent you from booting a machine without any way of controlling it. You have 3 options:
1. leave the corded mouse and keyboard attached and never use them
2. update the BIOS for your desktop to the newest one in hopes that the updated BIOS will allow for USB mouse and keyboard operation
3. go to a computer store and get a PS2 to USB converter/adapter. They're small and relatively inexpensive. It plugs into the PS2 port, and makes your computer think that there's a PS2 device connected, when it's actually a USB device.
Mar 03, 2010 | Microsoft Wireless Laser Mouse 6000 v2.0
Computer boots up, but can't use keyboard or anything else
sounds like a problem in windows may have to reinstall the os
Mar 30, 2009 | Acer Aspire 5100 Notebook
USB drives Not working
this problem seems mostly with the usb mouse, the best solution is to plug the flash drive in one port and usb in other and restart the computer generally this always works but if it wont work then the best thing is i also did that, buy a 4-port usb hub and connect it with laptop and connect your usb mouse with this port not directly to your laptop and when you like to use your flash drive plug it in the laptop.
this is working with be perfectly and i hope it will do the same at your side.
Mar 23, 2009 | Toshiba Satellite A135-S2326 Notebook
Lock ups
Is the laser mouse USB? If so there is a grouping of settings in your BIOS that has to do with USB storage devices, mice, and keyboards. It would appear that your USB keyboard controller is already enabled but the mouse and USB storage devices are both disabled. If you need help navigating through the bios let me know or look it up on google.
Dec 19, 2008 | ASUS A7V8X-MX Motherboard
USB ports all seem troublesome
You cannot use wireless keyboard or USB keyboard in setting up the computer BIOS, what you need is a PS2 keyboard, if your motherboard supported USB booting, in Boot section of your BIOS change the Boot Priority to USB Generic Device, after you change the boot priority change the First Boot to Removable Device or USB Generic Device.. and after that save your configuration and restart the computer.. you must put the USB stick first before you configure the BIOS.. TY
HOPE I CAN HELP
Dec 05, 2008 | HP Pavilion (PN153AAR) PC Desktop
Aspire 3610 USB ports
I think you might have a loose cononection for the data ports. Try putting a little bit of force on the usb device. Up, down left right. NOT ALOT. If it starts working when force is used, i tihnk you should try to take it apart and resolder the connections. If it dosen't work, uninstalling the driver and installing.
Jun 01, 2008 | Acer Aspire 3680 Laptop
Device manager shows the USB port if they are attached to you notebook. And in your case they are attached. So it will show it. Now in your case the problem is in your USB. Get it changed. If it is in warranty peroid then dont u take any risk. Let it be replaced. Or give your notebook in warranty period to the company from which you bought.
Sep 26, 2007 | Acer Aspire 3610 Notebook
D-Link DKVM-2U 2-port KVM Switch Logo
101 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
